Commit 918e23dc authored by Philip Carns's avatar Philip Carns
change reverse computation strategy for simplenet
- save previous cumulative time values rather than actually reversing
  calculation in order to avoid minor discrepancies introduced by
  rounding error
parent caac4e98
...@@ -52,6 +52,8 @@ struct sn_message ...@@ -52,6 +52,8 @@ struct sn_message
/* for reverse computation */ /* for reverse computation */
tw_stime net_send_next_idle_saved; tw_stime net_send_next_idle_saved;
tw_stime net_recv_next_idle_saved; tw_stime net_recv_next_idle_saved;
tw_stime send_time_saved;
tw_stime recv_time_saved;
/* net startup cost, ns */ /* net startup cost, ns */
static double global_net_startup_ns = 0; static double global_net_startup_ns = 0;
...@@ -312,7 +314,7 @@ static void handle_msg_ready_rev_event( ...@@ -312,7 +314,7 @@ static void handle_msg_ready_rev_event(
stat = model_net_find_stats(m->category, ns->sn_stats_array); stat = model_net_find_stats(m->category, ns->sn_stats_array);
stat->recv_count--; stat->recv_count--;
stat->recv_bytes -= m->net_msg_size_bytes; stat->recv_bytes -= m->net_msg_size_bytes;
stat->recv_time -= rate_to_ns(m->net_msg_size_bytes, global_net_bw_mbs); stat->recv_time = m->recv_time_saved;
return; return;
...@@ -336,6 +338,7 @@ static void handle_msg_ready_event( ...@@ -336,6 +338,7 @@ static void handle_msg_ready_event(
stat->recv_count++; stat->recv_count++;
stat->recv_bytes += m->net_msg_size_bytes; stat->recv_bytes += m->net_msg_size_bytes;
m->recv_time_saved = stat->recv_time;
stat->recv_time += rate_to_ns(m->net_msg_size_bytes, global_net_bw_mbs); stat->recv_time += rate_to_ns(m->net_msg_size_bytes, global_net_bw_mbs);
/* are we available to recv the msg? */ /* are we available to recv the msg? */
...@@ -385,7 +388,7 @@ static void handle_msg_start_rev_event( ...@@ -385,7 +388,7 @@ static void handle_msg_start_rev_event(
stat->send_count--; stat->send_count--;
stat->send_bytes -= m->net_msg_size_bytes; stat->send_bytes -= m->net_msg_size_bytes;
stat->send_time -= (global_net_startup_ns + rate_to_ns(m->net_msg_size_bytes, global_net_bw_mbs)); stat->send_time = m->send_time_saved;
return; return;
...@@ -415,6 +418,7 @@ static void handle_msg_start_event( ...@@ -415,6 +418,7 @@ static void handle_msg_start_event(
stat->send_count++; stat->send_count++;
stat->send_bytes += m->net_msg_size_bytes; stat->send_bytes += m->net_msg_size_bytes;
m->send_time_saved = stat->send_time;
stat->send_time += (global_net_startup_ns + rate_to_ns(m->net_msg_size_bytes, global_net_bw_mbs)); stat->send_time += (global_net_startup_ns + rate_to_ns(m->net_msg_size_bytes, global_net_bw_mbs));
if(stat->max_event_size < total_event_size) if(stat->max_event_size < total_event_size)
stat->max_event_size = total_event_size; stat->max_event_size = total_event_size;
Markdown is supported
0% or
Please register or to comment
