Commit 857baa59 authored by Neil McGlohon's avatar Neil McGlohon
Fix Static Routing & make adaptive routing stats define toggle: SHOW_ADAPTIVE_STATS
parent e6f95a18
...@@ -34,6 +34,7 @@ ...@@ -34,6 +34,7 @@
#define DUMP_CONNECTIONS 0 #define DUMP_CONNECTIONS 0
#define CREDIT_SIZE 8 #define CREDIT_SIZE 8
#define DFLY_HASH_TABLE_SIZE 4999 #define DFLY_HASH_TABLE_SIZE 4999
#define SHOW_ADAPTIVE_STATS 1
// debugging parameters // debugging parameters
#define TRACK -1 #define TRACK -1
...@@ -868,7 +869,7 @@ void dragonfly_plus_report_stats() ...@@ -868,7 +869,7 @@ void dragonfly_plus_report_stats()
MPI_Reduce( &num_local_packets_sr, &total_local_packets_sr, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce( &num_local_packets_sr, &total_local_packets_sr, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES);
MPI_Reduce( &num_local_packets_sg, &total_local_packets_sg, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce( &num_local_packets_sg, &total_local_packets_sg, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES);
MPI_Reduce( &num_remote_packets, &total_remote_packets, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce( &num_remote_packets, &total_remote_packets, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES);
if(isRoutingAdaptive(routing)) { if(isRoutingAdaptive(routing) || SHOW_ADAPTIVE_STATS) {
MPI_Reduce(&minimal_count, &total_minimal_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce(&minimal_count, &total_minimal_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_CODES);
MPI_Reduce(&nonmin_count, &total_nonmin_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce(&nonmin_count, &total_nonmin_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_CODES);
...@@ -881,7 +882,7 @@ void dragonfly_plus_report_stats() ...@@ -881,7 +882,7 @@ void dragonfly_plus_report_stats()
(float) avg_hops / total_finished_chunks, avg_time / (total_finished_chunks * 1000), (float) avg_hops / total_finished_chunks, avg_time / (total_finished_chunks * 1000),
max_time / 1000, (float) final_msg_sz / total_finished_msgs, total_finished_msgs, max_time / 1000, (float) final_msg_sz / total_finished_msgs, total_finished_msgs,
total_finished_chunks); total_finished_chunks);
printf("\n ADAPTIVE ROUTING STATS: %d chunks routed minimally %d chunks routed non-minimally completed packets %lld \n", printf("\n ADAPTIVE ROUTING STATS: %d chunks routed minimally %d chunks routed non-minimally completed packets %lld \n",
total_minimal_packets, total_nonmin_packets, total_finished_chunks); total_minimal_packets, total_nonmin_packets, total_finished_chunks);
...@@ -2617,32 +2618,34 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2617,32 +2618,34 @@ static Connection do_dfp_routing(router_state *s,
theConn = selected_nonminimal_conns[best_non_min_score_index]; theConn = selected_nonminimal_conns[best_non_min_score_index];
else { //routing algorithm is specified in routing
else { //routing algorithm is specified in msg->path_type
bool choose_minimal = false; bool choose_minimal = false;
if ( msg->path_type == MINIMAL || msg->dfp_upward_channel_flag == 1 || (my_group_id == fdest_group_id) ) if (isRoutingMinimal(routing) || msg->dfp_upward_channel_flag == 1 || (my_group_id == fdest_group_id))
choose_minimal = true; choose_minimal = true;
else { else {
if (in_intermediate_group) { if (in_intermediate_group) {
if (s->dfp_router_type == SPINE) { //INTERMEDIATE SPINE if (s->dfp_router_type == SPINE) { //INTERMEDIATE SPINE
if (msg->path_type == NON_MINIMAL_SPINE) { if (routing == NON_MINIMAL_SPINE) {
//we then follow minimal //from here we follow minimal
msg->dfp_upward_channel_flag = 1; msg->dfp_upward_channel_flag = 1;
else { else {
assert(msg->path_type == NON_MINIMAL_LEAF); assert(routing == NON_MINIMAL_LEAF);
//from here we have to go to a leaf
choose_minimal = false; choose_minimal = false;
else { //INTERMEDIATE LEAF else { //INTERMEDIATE LEAF
assert(s->dfp_router_type == LEAF);
//from here we have to follow minimal
else { //must be in source group else { //must be in source group
assert(my_group_id == origin_grp_id); assert(my_group_id == origin_grp_id);
choose_minimal = false; choose_minimal = false; //if routing were MINIMAL, then we'd have hit the conditional above and chosen minimal already.
...@@ -2652,10 +2655,12 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2652,10 +2655,12 @@ static Connection do_dfp_routing(router_state *s,
theConn = poss_min_next_stops[rand_sel]; theConn = poss_min_next_stops[rand_sel];
else { else {
msg->path_type = NON_MINIMAL;
assert(poss_non_min_next_stops.size() > 0); assert(poss_non_min_next_stops.size() > 0);
int rand_sel = tw_rand_integer(lp->rng, 0, poss_non_min_next_stops.size()-1); int rand_sel = tw_rand_integer(lp->rng, 0, poss_non_min_next_stops.size()-1);
theConn = poss_non_min_next_stops[rand_sel]; theConn = poss_non_min_next_stops[rand_sel];
return theConn; return theConn;
...@@ -2723,16 +2728,11 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -2723,16 +2728,11 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
(terminal_plus_message_list *) malloc(sizeof(terminal_plus_message_list)); (terminal_plus_message_list *) malloc(sizeof(terminal_plus_message_list));
init_terminal_plus_message_list(cur_chunk, msg); init_terminal_plus_message_list(cur_chunk, msg);
// Set the default route as minimal for adaptive routing on the first router, else leave unchanged // packets start out as minimal when received from a terminal. The path type is changed off of minimal if/when the packet takes a nonminimal path during routing
if( isRoutingAdaptive(routing) && cur_chunk->msg.last_hop == TERMINAL) { if( cur_chunk->msg.last_hop == TERMINAL) {
cur_chunk->msg.path_type = MINIMAL; cur_chunk->msg.path_type = MINIMAL;
if( !isRoutingAdaptive(routing) )
cur_chunk->msg.path_type = routing; //defaults to the routing algorihtm if we don't have adaptive or prog-adaptive routing here
Connection next_stop_conn = do_dfp_routing(s, bf, &(cur_chunk->msg), lp, dest_router_id); Connection next_stop_conn = do_dfp_routing(s, bf, &(cur_chunk->msg), lp, dest_router_id);
output_port = next_stop_conn.port; output_port = next_stop_conn.port;
Markdown is supported
0% or
Please register or to comment
