Commit 84b7e9fb authored by Neil McGlohon's avatar Neil McGlohon
latest work to fix dfp routing
parent e6ab9e42
......@@ -333,7 +333,8 @@ typedef enum dfp_path_hop_t
INTERMEDIATE_LEAF, //a leaf router not in the packets originating group or destination group
INTERMEDIATE_SPINE, //a spine router not in the packets originating group or destination group
DESTINATION_LEAF, //a leaf router in the packets destination group
DESTINATION_SPINE //a spine router in the packets destination group
DESTINATION_SPINE, //a spine router in the packets destination group
FINAL_DESTINATION //the leaf router that has a connection to the destination terminal
} dfp_path_hop_t;
typedef enum routing_alg_t
......@@ -872,8 +873,16 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
connManagerList[i].print_connections();
printf("Does spine 479 have conn to group 27?\n");
for(int i = 0; i < connectionList[479/p->num_routers][27].size(); i++)
printf("%d\n",connectionList[479/p->num_routers][27][i]);
// exit(1);
if (!myRank) {
printf("\n Total nodes %d routers %d groups %d routers per group %d radix %d\n",
p->num_cn * p->num_router_leaf * p->num_groups, p->total_routers, p->num_groups, p->num_routers, p->radix);
......@@ -2467,7 +2476,116 @@ static vector< Connection > get_possible_next_stops_to_specific_router(router_st
// return possible_next_conns;
static vector< Connection > get_possible_stops_to_intermediate_router(router_state *s,
tw_bf *bf,
terminal_plus_message *msg,
tw_lp *lp,
dfp_path_hop_t my_hop_type,
int specific_router_id)
int local_router_id = s->router_id;
int my_group_id = s->router_id / s->params->num_routers;
int specific_group_id = specific_router_id / s->params->num_routers;
vector< Connection > possible_next_conns;
switch (my_hop_type) {
case SOURCE_LEAF :
//possible minimal connections are to spines that have a connection to the dest router
set<int> poss_router_id_set;
for(int i = 0; i < connectionList[my_group_id][specific_group_id].size(); i++)
int poss_router_id = connectionList[my_group_id][specific_group_id][i];
if (poss_router_id_set.count(poss_router_id) == 0) { //if we haven't added the connections from poss_router_id yet
vector< Connection > conns = s->connMan->get_connections_to_gid(poss_router_id, CONN_LOCAL);
poss_router_id_set.insert(poss_router_id);
possible_next_conns.insert(possible_next_conns.end(), conns.begin(), conns.end());
} break;
case SOURCE_SPINE :
//possible minimal connections are to spines in the destination group
possible_next_conns = s->connMan->get_connections_to_group(specific_group_id);
} break;
case INTERMEDIATE_SPINE :
possible_next_conns = s->connMan->get_connections_to_gid(specific_router_id, CONN_LOCAL);
} break;
case INTERMEDIATE_LEAF :
case DESTINATION_LEAF :
case DESTINATION_SPINE :
case FINAL_DESTINATION :
default :
tw_error(TW_LOC, "Incorrectly handled hop type\n");
static vector< Connection > get_possible_minimal_stops_to_destination(router_state *s,
tw_bf *bf,
tw_lp *lp,
int fdest_router_id)
int my_router_id = s->router_id;
int dest_group_id = fdest_router_id / s->params->num_routers;
case SOURCE_LEAF :
assert(s->dfp_router_type == LEAF);
//possible minimal connections are to spines that have a connection to the dest router group
for(int i = 0; i < connectionList[my_group_id][dest_group_id].size(); i++)
int poss_router_id = connectionList[my_group_id][dest_group_id][i];
// printf("%d\n",poss_router_id);
} break;
case SOURCE_SPINE :
assert(s->dfp_router_type == SPINE);
possible_next_conns = s->connMan->get_connections_to_group(dest_group_id);
printf("%d connections from spine %d to group %d for %d\n",possible_next_conns.size(), my_router_id, dest_group_id, fdest_router_id);
} break;
possible_next_conns = s->connMan->get_connections_by_type(CONN_LOCAL);
} break;
possible_next_conns = s->connMan->get_connections_to_gid(fdest_router_id, CONN_LOCAL);
} break;
possible_next_conns = s->connMan->get_connections_to_gid(msg->dfp_dest_terminal_id, CONN_TERMINAL);
} break;
default :
static int get_min_hops_to_dest_from_conn(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, Connection conn)
......@@ -2786,8 +2904,12 @@ static Connection do_dfp_routing(router_state *s,
if (my_group_id == fdest_group_id) {
if (s->dfp_router_type == SPINE)
my_hop_type = DESTINATION_SPINE;
else
my_hop_type = DESTINATION_LEAF;
else {
if (s->router_id == fdest_router_id)
my_hop_type = FINAL_DESTINATION;
else
else if (my_group_id == origin_group_id) {
......@@ -2804,123 +2926,110 @@ static Connection do_dfp_routing(router_state *s,
Connection nextStopConn; //the connection that we will forward the packet to
if (local_router_id == fdest_router_id) {
vector< Connection > poss_next_stops = s->connMan->get_connections_to_gid(msg->dfp_dest_terminal_id, CONN_TERMINAL);
if (poss_next_stops.size() < 1)
tw_error(TW_LOC, "Destination Router: No connection to destination terminal\n");
nextStopConn = get_best_connection_from_conns(s, bf, msg, lp, poss_next_stops, C_MIN);
return nextStopConn;
// if (local_router_id == fdest_router_id) {
// printf("loc\n");
// vector< Connection > poss_next_stops = s->connMan->get_connections_to_gid(msg->dfp_dest_terminal_id, CONN_TERMINAL);
// if (poss_next_stops.size() < 1)
// tw_error(TW_LOC, "Destination Router: No connection to destination terminal\n");
// nextStopConn = get_best_connection_from_conns(s, bf, msg, lp, poss_next_stops, C_MIN);
// return nextStopConn;
if (isRoutingAdaptive(routing)) {
if (routing == PROG_ADAPTIVE)
nextStopConn = do_dfp_prog_adaptive_routing(s, bf, msg, lp, my_hop_type, fdest_router_id);
else if (isRoutingMinimal(routing)) {
vector< Connection > poss_next_stops = get_possible_next_stops_to_specific_router(s, bf, msg, lp, my_hop_type, fdest_router_id);
vector< Connection > poss_next_stops = get_possible_minimal_stops_to_destination(s, bf, msg, lp ,my_hop_type, fdest_router_id);
if (poss_next_stops.size() < 0)
tw_error(TW_LOC, "MINIMAL DEAD END\n");
else { //routing algorithm is specified in routing
assert( (routing == NON_MINIMAL_LEAF) || (routing == NON_MINIMAL_SPINE) );
switch ( my_hop_type ) {
case SOURCE_LEAF :
// printf("Begin Source Leaf\n");
int intm_router_id = dfp_pick_intermediate_router(s, bf, msg, lp, origin_group_id, fdest_group_id); //technically only picks a leaf router, so it's too far for non_minimal_spine but we'll handle that at INTERMEDIATE_SPINE
vector< Connection > poss_intm_next_stops = get_possible_next_stops_to_specific_router(s, bf, msg, lp, my_hop_type, intm_router_id);
if (poss_intm_next_stops.size() < 1)
tw_error(TW_LOC, "SOURCE LEAF: poss next stops is empty?!?\n");
Connection best_intm_conn = get_best_connection_from_conns(s, bf, msg, lp, poss_intm_next_stops, C_NONMIN);
msg->path_type = NON_MINIMAL;
printf("source leaf\n");
//pick an intermediate leaf router to forward to
msg->intm_rtr_id = intm_router_id;
nextStopConn = best_intm_conn;
// printf("End Source leaf\n");
break;
//forward to a spine router that has a connection to that router's group
vector< Connection > poss_next_stops = get_possible_stops_to_intermediate_router(s, bf, msg, lp, my_hop_type, intm_router_id);
nextStopConn = poss_next_stops[0]; //TODO randomize this
} break;
case SOURCE_SPINE :
// printf("Begin Source Spine\n");
vector< Connection > poss_next_stops = get_possible_next_stops_to_specific_router(s, bf, msg, lp, my_hop_type, msg->intm_rtr_id);
tw_error(TW_LOC, "SOURCE SPINE: poss next stops is empty?!?\n");
Connection best_conn = get_best_connection_from_conns(s, bf, msg, lp, poss_next_stops, C_NONMIN);
nextStopConn = best_conn;
// printf("End Source Spine\n");
break;
printf("source spine\n");
int intm_router_id = msg->intm_rtr_id;
} break;
// printf("Begin Int Leaf\n");
printf("int leaf\n");
msg->dfp_upward_channel_flag = 1;
tw_error(TW_LOC, "INT LEAF: poss next stops is empty?!?\n");
// printf("Begin Ing Leaf\n");
break;
vector< Connection > poss_next_stops = get_possible_minimal_stops_to_destination(s, bf, msg, lp, my_hop_type, fdest_router_id);
printf("%d: Int leaf sending to %d to go to %d for router %d\n", local_router_id, nextStopConn.dest_gid, fdest_group_id, fdest_router_id);
} break;
// printf("Begin Int Spine\n");
if (routing == NON_MINIMAL_SPINE) { //then foward on to destination group
tw_error(TW_LOC, "INT SPINE: TO DEST GROUP poss next stops is empty?!?\n");
else {
assert(routing == NON_MINIMAL_LEAF);
if (msg->dfp_upward_channel_flag == 1) { //then we need to be heading toward the destination!
printf("int spine to dest\n");
tw_error(TW_LOC, "%d: INT SPINE: TO DEST GROUP poss next stops is empty?!? fdest = %d\n",s->router_id, fdest_router_id);
printf("fuck\n");
else {
tw_error(TW_LOC, "INT SPINE: TO INT LEAF poss next stops is empty?!?\n");
printf("int spine to int leaf\n");
// printf("End Int Spine\n");
break;
} break;
// printf("Begin Dest Leaf\n");
tw_error(TW_LOC, "DEST LEAF: poss next stops is empty?!?\n");
// printf("End Dest Leaf\n");
break;
} break;
// printf("Begin Dest Spine\n");
// printf("End Dest Spine\n");
break;
printf("dest spine\n");
} break;
} break;
default :
tw_error(TW_LOC,"Improperly handled hop type in do routing");
Markdown is supported
0%
or
Please register or to comment
