Commit 81ae794e authored by Noah Wolfe's avatar Noah Wolfe Committed by Nikhil
Squashed Warnings
parent 3957a80e
#include <ross.h> #include <ross.h>
#include "codes/jenkins-hash.h"
#include "codes/codes_mapping.h" #include "codes/codes_mapping.h"
#include "codes/codes.h" #include "codes/codes.h"
#include "codes/model-net.h" #include "codes/model-net.h"
...@@ -8,6 +9,7 @@ ...@@ -8,6 +9,7 @@
#include "codes/net/fattree.h" #include "codes/net/fattree.h"
#include "sys/file.h" #include "sys/file.h"
#include "codes/quickhash.h" #include "codes/quickhash.h"
#include "codes/rc-stack.h"
//#include "codes/map_messages.h" //#include "codes/map_messages.h"
#define CREDIT_SIZE 8 #define CREDIT_SIZE 8
...@@ -22,7 +24,7 @@ ...@@ -22,7 +24,7 @@
#define FATTREE_DEBUG 0 #define FATTREE_DEBUG 0
#define FATTREE_CONNECTIONS 0 #define FATTREE_CONNECTIONS 0
#define FATTREE_MSG 0 #define FATTREE_MSG 0
#define DEBUG_RC 0 #define DEBUG_RC 1
#define LP_CONFIG_NM (model_net_lp_config_names[FATTREE]) #define LP_CONFIG_NM (model_net_lp_config_names[FATTREE])
#define LP_METHOD_NM (model_net_method_names[FATTREE]) #define LP_METHOD_NM (model_net_method_names[FATTREE])
...@@ -59,7 +61,7 @@ typedef struct fattree_param fattree_param; ...@@ -59,7 +61,7 @@ typedef struct fattree_param fattree_param;
* last index) */ * last index) */
static uint64_t num_params = 0; static uint64_t num_params = 0;
static fattree_param * all_params = NULL; static fattree_param * all_params = NULL;
static config_anno_map_t * anno_map = NULL; static const config_anno_map_t * anno_map = NULL;
/* global variables for codes mapping */ /* global variables for codes mapping */
static char lp_group_name[MAX_NAME_LENGTH]; static char lp_group_name[MAX_NAME_LENGTH];
...@@ -381,7 +383,7 @@ static int fattree_get_msg_sz(void) ...@@ -381,7 +383,7 @@ static int fattree_get_msg_sz(void)
return sizeof(fattree_message); return sizeof(fattree_message);
static void fattree_read_config(char * anno, fattree_param *p){ static void fattree_read_config(const char * anno, fattree_param *p){
int i; int i;
p->ft_type = 0; p->ft_type = 0;
...@@ -540,8 +542,8 @@ static void fattree_configure(){ ...@@ -540,8 +542,8 @@ static void fattree_configure(){
num_params = anno_map->num_annos + (anno_map->has_unanno_lp > 0); num_params = anno_map->num_annos + (anno_map->has_unanno_lp > 0);
all_params = malloc(num_params * sizeof(*all_params)); all_params = malloc(num_params * sizeof(*all_params));
for (uint64_t i = 0; i < anno_map->num_annos; i++){ for (int i = 0; i < anno_map->num_annos; i++){
char * anno = anno_map->annotations[i].ptr; const char * anno = anno_map->annotations[i].ptr;
fattree_read_config(anno, &all_params[i]); fattree_read_config(anno, &all_params[i]);
if (anno_map->has_unanno_lp > 0){ if (anno_map->has_unanno_lp > 0){
...@@ -558,7 +560,6 @@ void ft_terminal_init( ft_terminal_state * s, tw_lp * lp ) ...@@ -558,7 +560,6 @@ void ft_terminal_init( ft_terminal_state * s, tw_lp * lp )
bj_hashlittle2(LP_METHOD_NM, strlen(LP_METHOD_NM), &h1, &h2); bj_hashlittle2(LP_METHOD_NM, strlen(LP_METHOD_NM), &h1, &h2);
fattree_terminal_magic_num = h1 + h2; fattree_terminal_magic_num = h1 + h2;
int i;
char anno[MAX_NAME_LENGTH]; char anno[MAX_NAME_LENGTH];
if(def_gname_set == 0) { if(def_gname_set == 0) {
...@@ -628,7 +629,7 @@ void ft_terminal_init( ft_terminal_state * s, tw_lp * lp ) ...@@ -628,7 +629,7 @@ void ft_terminal_init( ft_terminal_state * s, tw_lp * lp )
void switch_init(switch_state * r, tw_lp * lp) void switch_init(switch_state * r, tw_lp * lp)
int num_terminals = -1, num_lps; int num_terminals = -1;
def_gname_set = 1; def_gname_set = 1;
...@@ -636,8 +637,8 @@ void switch_init(switch_state * r, tw_lp * lp) ...@@ -636,8 +637,8 @@ void switch_init(switch_state * r, tw_lp * lp)
&mapping_type_id, anno, &mapping_rep_id, &mapping_offset); &mapping_type_id, anno, &mapping_rep_id, &mapping_offset);
num_terminals = codes_mapping_get_lp_count(def_group_name, 0, num_terminals = codes_mapping_get_lp_count(def_group_name, 0,
LP_CONFIG_NM, anno, 0); LP_CONFIG_NM, anno, 0);
num_lps = codes_mapping_get_lp_count(def_group_name, 1, LP_CONFIG_NM, // num_lps = codes_mapping_get_lp_count(def_group_name, 1, LP_CONFIG_NM,
anno, 0); // anno, 0);
codes_mapping_get_lp_info(lp->gid, lp_group_name, &mapping_grp_id, NULL, codes_mapping_get_lp_info(lp->gid, lp_group_name, &mapping_grp_id, NULL,
...@@ -802,7 +803,7 @@ void switch_init(switch_state * r, tw_lp * lp) ...@@ -802,7 +803,7 @@ void switch_init(switch_state * r, tw_lp * lp)
/* not true anymore */ /* not true anymore */
r->start_uneigh = p->num_switches[0] + l2_base; r->start_uneigh = p->num_switches[0] + l2_base;
r->con_per_uneigh = 1; r->con_per_uneigh = 1;
if((r->switch_id - p->num_switches[0]) % p->l1_set_size >= if(((int)r->switch_id - p->num_switches[0]) % p->l1_set_size >=
p->l1_set_size/2) { p->l1_set_size/2) {
l2_base += (p->num_switches[2]/2); l2_base += (p->num_switches[2]/2);
...@@ -845,7 +846,7 @@ void switch_init(switch_state * r, tw_lp * lp) ...@@ -845,7 +846,7 @@ void switch_init(switch_state * r, tw_lp * lp)
r->start_lneigh = p->num_switches[0]; r->start_lneigh = p->num_switches[0];
r->end_lneigh = r->start_lneigh + p->num_switches[1]; r->end_lneigh = r->start_lneigh + p->num_switches[1];
int l1 = 0; int l1 = 0;
if(r->switch_id - p->num_switches[0] - p->num_switches[1] >= if((int)r->switch_id - p->num_switches[0] - p->num_switches[1] >=
(p->num_switches[2]/2)) { (p->num_switches[2]/2)) {
l1 += (p->l1_set_size/2); l1 += (p->l1_set_size/2);
...@@ -991,6 +992,8 @@ static tw_stime fattree_packet_event( ...@@ -991,6 +992,8 @@ static tw_stime fattree_packet_event(
packet_event_f++; packet_event_f++;
#endif #endif
(void)message_offset;
(void)sched_params;
tw_event * e_new; tw_event * e_new;
tw_stime xfer_to_nic_time; tw_stime xfer_to_nic_time;
fattree_message * msg; fattree_message * msg;
Markdown is supported
0% or
Please register or to comment
