Commit 8123fb24 authored by Philip Carns's avatar Philip Carns
convert test scripts to use $srcdir
parent 5c0e95f9
...@@ -24,8 +24,6 @@ ...@@ -24,8 +24,6 @@
.dirstamp .dirstamp
*.o *.o
*.a *.a
/tests/modelnet-test
/tests/modelnet-test.sh
# hide backups # hide backups
...@@ -66,9 +66,4 @@ AC_SUBST(CODES_BASE_CFLAGS) ...@@ -66,9 +66,4 @@ AC_SUBST(CODES_BASE_CFLAGS)
includedir="${includedir}/codes" includedir="${includedir}/codes"
AC_CONFIG_FILES([Makefile]) AC_CONFIG_FILES([Makefile])
AC_CONFIG_FILES([tests/modelnet-test.sh],[chmod +x tests/modelnet-test.sh])
AC_CONFIG_FILES([tests/modelnet-test-dragonfly.sh],[chmod +x tests/modelnet-test-dragonfly.sh])
AC_CONFIG_FILES([tests/modelnet-test-torus.sh],[chmod +x tests/modelnet-test-torus.sh])
AC_CONFIG_FILES([tests/modelnet-test-loggp.sh],[chmod +x tests/modelnet-test-loggp.sh])
AC_CONFIG_FILES([tests/modelnet-p2p-bw-loggp.sh],[chmod +x tests/modelnet-p2p-bw-loggp.sh])
AC_OUTPUT(maint/codes-net.pc tests/modelnet-p2p-bw-loggp.conf tests/modelnet-test-loggp.conf) AC_OUTPUT(maint/codes-net.pc tests/modelnet-p2p-bw-loggp.conf tests/modelnet-test-loggp.conf)
#!/bin/bash #!/bin/bash
abs_srcdir=@abs_srcdir@
tests/modelnet-p2p-bw --sync=1 -- tests/modelnet-p2p-bw-loggp.conf tests/modelnet-p2p-bw --sync=1 -- tests/modelnet-p2p-bw-loggp.conf
#!/bin/bash
if [ -z $srcdir ]; then
echo srcdir variable not set.
exit 1
fi
tests/modelnet-test --sync=1 -- $srcdir/tests/modelnet-test-dragonfly.conf
#!/bin/bash
tests/modelnet-test --sync=1 -- $abs_srcdir/modelnet-test-dragonfly.conf
tests/modelnet-test --sync=1 -- tests/modelnet-test-loggp.conf tests/modelnet-test --sync=1 -- tests/modelnet-test-loggp.conf
#!/bin/bash
exit 1
fi
tests/modelnet-test --sync=1 -- $srcdir/tests/modelnet-test-torus.conf
#!/bin/bash
tests/modelnet-test --sync=1 -- $abs_srcdir/modelnet-test-torus.conf
#!/bin/bash
exit 1
fi
tests/modelnet-test --sync=1 -- $srcdir/tests/modelnet-test.conf
#!/bin/bash
tests/modelnet-test --sync=1 -- $abs_srcdir/modelnet-test.conf
Markdown is supported
0% or
Please register or to comment
