Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project
Project
Details
Activity
Releases
Cycle Analytics
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Charts
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Charts
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
79735b3b
Commit
79735b3b
authored
May 11, 2018
by
Neil McGlohon
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Fixing the poor merge
parent
8f244fa3
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
72 additions
and
10 deletions
+72
-10
dragonfly-plus.C
src/networks/model-net/dragonfly-plus.C
+72
-10
No files found.
View file @
79735b3b
@@ -32,6 +32,7 @@
#endif
#define DUMP_CONNECTIONS 0
#define PRINT_CONFIG 1
#define CREDIT_SIZE 8
#define DFLY_HASH_TABLE_SIZE 4999
#define SHOW_ADAPTIVE_STATS 1
@@ -570,6 +571,43 @@ static terminal_plus_message_list *return_tail(terminal_plus_message_list **this
return
tail
void
dragonfly_plus_print_params
dragonfly_plus_param
p
int
myRank
MPI_Comm_rank
MPI_COMM_CODES
myRank
if
myRank
printf
"--------- Dragonfly Plus Parameters ---------
\n
printf
"num_routers = %d
\n
p
num_routers
printf
"local_bandwidth = %.2f
\n
p
local_bandwidth
printf
"global_bandwidth = %.2f
\n
p
global_bandwidth
printf
"cn_bandwidth = %.2f
\n
p
cn_bandwidth
printf
"num_vcs = %d
\n
p
num_vcs
printf
"local_vc_size = %d
\n
p
local_vc_size
printf
"global_vc_size = %d
\n
p
global_vc_size
printf
"cn_vc_size = %d
\n
p
cn_vc_size
printf
"num_cn = %d
\n
p
num_cn
printf
"intra_grp_radix = %d
\n
p
intra_grp_radix
printf
"num_level_chans = %d
\n
p
num_level_chans
printf
"num_router_spine = %d
\n
p
num_router_spine
printf
"num_router_leaf = %d
\n
p
num_router_leaf
printf
"adaptive_threshold = %d
\n
p
adaptive_threshold
printf
"max_port_score = %d
\n
p
max_port_score
printf
"num_groups = %d
\n
p
num_groups
printf
"radix = %d
\n
p
radix
printf
"total_routers = %d
\n
p
total_routers
printf
"total_terminals = %d
\n
p
total_terminals
printf
"num_global_connections = %d
\n
p
printf
"cn_delay = %.2f
\n
p
cn_delay
printf
"local_delay = %.2f
\n
p
local_delay
printf
"global_delay = %.2f
\n
p
global_delay
printf
"credit_delay = %.2f
\n
p
credit_delay
printf
"router_delay = %.2f
\n
p
router_delay
printf
"scoring = %d
\n
scoring
printf
"routing = %d
\n
routing
printf
\n
static
void
dragonfly_read_config
const
char
anno
params
/*Adding init for router magic number*/
@@ -820,6 +858,16 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
if
DUMP_CONNECTIONS
if
myRank
for
int
i
0
i
connManagerList
size
i
connManagerList
i
print_connections
if
myRank
printf
\n
Total nodes %d routers %d groups %d routers per group %d radix %d
\n
p
num_cn
p
num_router_leaf
p
num_groups
p
total_routers
p
num_groups
p
num_routers
p
radix
@@ -829,6 +877,9 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
p
local_delay
bytes_to_ns
p
chunk_size
p
local_bandwidth
p
global_delay
bytes_to_ns
p
chunk_size
p
global_bandwidth
p
credit_delay
bytes_to_ns
CREDIT_SIZE
p
local_bandwidth
// assume 8 bytes packet
if
PRINT_CONFIG
p
void
dragonfly_plus_configure
@@ -887,10 +938,10 @@ void dragonfly_plus_report_stats()
max_time
1000
float
final_msg_sz
total_finished_msgs
total_finished_msgs
total_finished_chunks
if
isRoutingAdaptive
routing
SHOW_ADAPTIVE_STATS
printf
\n
ADAPTIVE ROUTING STATS: %d chunks routed minimally %d chunks routed non-minimally
completed packets
%lld
\n
printf
\n
- completed packets:
%lld
\n
total_minimal_packets
total_nonmin_packets
printf
\n
Total packets generated
%ld finished %ld Locally routed- same router %ld different-router %ld Remote (inter-group)
%ld
\n
total_gen
total_fin
total_local_packets_sr
total_local_packets_sg
total_remote_packets
printf
\n
: %ld; finished: %ld; Locally routed: same router: %ld, different-router: %ld; Remote (inter-group):
%ld
\n
total_gen
total_fin
return
@@ -1285,8 +1336,8 @@ static void packet_generate(terminal_state *s, tw_bf *bf, terminal_plus_message
double
cn_delay
s
params
cn_delay
int
dest_router_id
dragonfly_plus_get_assigned_router_id
msg
dfp_dest_terminal_id
s
params
int
dest_grp_id
dest_router_id
s
params
num_routers
int
src_grp_id
s
router_id
s
params
num_routers
int
dest_grp_id
dest_router_id
s
params
num_routers
int
src_grp_id
s
router_id
s
params
num_routers
if
src_grp_id
dest_grp_id
@@ -1740,6 +1791,11 @@ static void packet_arrive(terminal_state *s, tw_bf *bf, terminal_plus_message *m
/* WE do not allow self messages through dragonfly */
assert
lp
gid
msg
src_terminal_id
// Verify that the router that send the packet to this terminal is the router assigned to this terminal
int
dest_router_id
s
terminal_id
s
params
int
received_from_rel_id
codes_mapping_get_lp_relative_id
msg
intm_lp_id
0
0
assert
dest_router_id
uint64_t
num_chunks
msg
packet_size
s
params
chunk_size
if
msg
packet_size
s
params
chunk_size
num_chunks
@@ -2287,7 +2343,7 @@ static int get_min_hops_to_dest_from_conn(router_state *s, tw_bf *bf, terminal_p
vector
Connection
cons_to_dest_group
connManagerList
conn
dest_gid
get_connections_to_group
fdest_group_id
if
cons_to_dest_group
size
0
return
5
//Next Spine -> Leaf -> Spine -> Spine -> Leaf -> dest_term
else
else
return
3
//Next Spine -> Spine -> Leaf -> dest_term
else
@@ -2306,6 +2362,13 @@ static int dfp_score_connection(router_state *s, tw_bf *bf, terminal_plus_messag
int
score
0
//can't forget to initialize this to zero.
int
port
conn
port
if
port
1
if
scoring_preference
LOWER
return
INT_MAX
else
return
0
switch
scoring
case
ALPHA
//considers vc occupancy and queued count only LOWER SCORE IS BETTER
@@ -2328,7 +2391,7 @@ static int dfp_score_connection(router_state *s, tw_bf *bf, terminal_plus_messag
break
case
GAMMA
//consideres vc occupancy and queue count but ports that follow a minimal path to fdest are biased 2:1 bonus by multiplying minimal by 2 HIGHER SCORE IS BETTER
score
s
params
max_port_score
//initialize this to max score.
int
to_subtract
0
for
int
k
0
k
s
params
num_vcs
k
@@ -2668,7 +2731,7 @@ static Connection do_dfp_routing(router_state *s,
bool
in_intermediate_group
my_group_id
origin_group_id
my_group_id
fdest_group_id
int
adaptive_threshold
s
params
adaptive_threshold
Connection
nextStopConn
//the connection that we will forward the packet to
//----------- LOCAL GROUP ROUTING --------------
if
my_router_id
fdest_router_id
@@ -2687,7 +2750,6 @@ static Connection do_dfp_routing(router_state *s,
//------------ END LOCAL GROUP ROUTING ---------
// from here we can assume that we are not in the destination group
Connection
theConn
if
isRoutingAdaptive
routing
if
routing
PROG_ADAPTIVE
@@ -2847,6 +2909,7 @@ static void router_packet_receive_rc(router_state *s, tw_bf *bf, terminal_plus_m
/* Packet arrives at the router and a credit is sent back to the sending terminal/router */
static
void
router_state
s
tw_bf
bf
msg
tw_lp
lp
router_verify_valid_receipt
s
bf
msg
lp
router_ecount
tw_stime
ts
@@ -2947,7 +3010,6 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
m
type
R_SEND
m
magic
router_magic_num
m
vc_index
output_port
m
dfp_upward_channel_flag
msg
tw_event_send
e
s
in_send_loop
output_port
1
@@ -3720,4 +3782,4 @@ struct model_net_method dragonfly_plus_router_method = {
// #endif
\ No newline at end of file
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
