Commit 78d73dda authored by Neil McGlohon's avatar Neil McGlohon
Dragonfly Plus: Model, Workload, and Config change
parent e602f6bc
...@@ -30,6 +30,10 @@ PARAMS ...@@ -30,6 +30,10 @@ PARAMS
num_level_chans="1"; num_level_chans="1";
# number of groups in the network # number of groups in the network
num_groups="4"; num_groups="4";
# predefined threshold (T) deciding when to reassign packet to a lower priority queue
queue_threshold="50";
# buffer size in bytes for local virtual channels # buffer size in bytes for local virtual channels
local_vc_size="8192"; local_vc_size="8192";
#buffer size in bytes for global virtual channels #buffer size in bytes for global virtual channels
...@@ -360,7 +360,8 @@ int main( ...@@ -360,7 +360,8 @@ int main(
int rank; int rank;
int num_nets; int num_nets;
int *net_ids; int *net_ids;
int num_router_rows, num_router_cols; int num_routers;
int num_router_leaf, num_router_spine;
tw_opt_add(app_opt); tw_opt_add(app_opt);
tw_init(&argc, &argv); tw_init(&argc, &argv);
...@@ -399,15 +400,16 @@ int main( ...@@ -399,15 +400,16 @@ int main(
num_servers_per_rep = codes_mapping_get_lp_count("MODELNET_GRP", 1, "nw-lp", num_servers_per_rep = codes_mapping_get_lp_count("MODELNET_GRP", 1, "nw-lp",
NULL, 1); NULL, 1);
configuration_get_value_int(&config, "PARAMS", "num_router_rows", NULL, &num_router_rows); configuration_get_value_int(&config, "PARAMS", "num_router_leaf", NULL, &num_router_leaf);
configuration_get_value_int(&config, "PARAMS", "num_router_cols", NULL, &num_router_cols); configuration_get_value_int(&config, "PARAMS", "num_router_spine", NULL, &num_router_spine);
configuration_get_value_int(&config, "PARAMS", "num_routers", NULL, &num_routers);
configuration_get_value_int(&config, "PARAMS", "num_groups", NULL, &num_groups); configuration_get_value_int(&config, "PARAMS", "num_groups", NULL, &num_groups);
configuration_get_value_int(&config, "PARAMS", "num_cns_per_router", NULL, &num_nodes_per_cn); configuration_get_value_int(&config, "PARAMS", "num_cns_per_router", NULL, &num_nodes_per_cn);
num_routers_per_grp = num_router_rows * num_router_cols; num_routers_per_grp = num_routers;
num_nodes = num_groups * num_routers_per_grp * num_nodes_per_cn; num_nodes = num_groups * num_router_leaf * num_nodes_per_cn;
num_nodes_per_grp = num_routers_per_grp * num_nodes_per_cn; num_nodes_per_grp = num_router_leaf * num_nodes_per_cn;
assert(num_nodes); assert(num_nodes);
...@@ -54,7 +54,7 @@ struct bLink ...@@ -54,7 +54,7 @@ struct bLink
/* Each entry in the vector is for a router id /* Each entry in the vector is for a router id
* against each router id, there is a map of links (key of the map is the dest * against each router id, there is a map of links (key of the map is the dest
* router id) * router id)
* link has information on type (green or black) and offset (number of links * link has information offset (number of links
* between that particular source and dest router ID)*/ * between that particular source and dest router ID)*/
static vector< map< int, vector< Link > > > intraGroupLinks; static vector< map< int, vector< Link > > > intraGroupLinks;
...@@ -172,13 +172,14 @@ struct dragonfly_plus_param ...@@ -172,13 +172,14 @@ struct dragonfly_plus_param
int num_level_chans; // number of channels between levels of the group(?) int num_level_chans; // number of channels between levels of the group(?)
int num_router_spine; // number of spine routers (top level) int num_router_spine; // number of spine routers (top level)
int num_router_leaf; // number of leaf routers (bottom level) int num_router_leaf; // number of leaf routers (bottom level)
int queue_threshold; // predefined queue length threshold T before a packet is routed through a lower priority queue
// dfp params end // dfp params end
int num_groups; int num_groups;
int radix; int radix;
int total_routers; int total_routers;
int total_terminals; int total_terminals;
int num_global_channels; int num_global_connections;
double cn_delay; double cn_delay;
double local_delay; double local_delay;
double global_delay; double global_delay;
...@@ -319,9 +320,7 @@ enum last_hop ...@@ -319,9 +320,7 @@ enum last_hop
enum ROUTING_ALGO enum ROUTING_ALGO
MINIMAL = 1, MINIMAL = 1,
NON_MINIMAL, FULLY_PROG_ADAPTIVE
ADAPTIVE,
PROG_ADAPTIVE
enum LINK_TYPE enum LINK_TYPE
...@@ -343,14 +342,6 @@ struct router_state ...@@ -343,14 +342,6 @@ struct router_state
int op_arr_size; int op_arr_size;
int max_arr_size; int max_arr_size;
/* radix properties - these are here because not all routers will necessarily have the same
* number of ports utilized for inter and intra connections.
* (e.g. Spines have global connections whereas leafs don't) */
int radix_util; //total ports actually utilized
int cn_radix_util; //total ports actually utilized for compute node/terminal connections -- unique to leafs
int intra_radix_util; //total ports actually utilized for intra-group connections -- leafs and spines both have some
int inter_radix_util; //total ports actually utilized for inter-group connections -- unique to spines
router_type dfp_router_type; // Enum to specify whether this router is a spine or a leaf router_type dfp_router_type; // Enum to specify whether this router is a spine or a leaf
int *global_channel; int *global_channel;
...@@ -589,15 +580,11 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -589,15 +580,11 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
configuration_get_value(&config, "PARAMS", "routing", anno, routing_str, MAX_NAME_LENGTH); configuration_get_value(&config, "PARAMS", "routing", anno, routing_str, MAX_NAME_LENGTH);
if (strcmp(routing_str, "minimal") == 0) if (strcmp(routing_str, "minimal") == 0)
routing = MINIMAL; routing = MINIMAL;
else if (strcmp(routing_str, "nonminimal") == 0 || strcmp(routing_str, "non-minimal") == 0) else if (strcmp(routing_str, "fully-prog-adaptive") == 0)
routing = NON_MINIMAL; routing = FULLY_PROG_ADAPTIVE;
else if (strcmp(routing_str, "adaptive") == 0)
routing = ADAPTIVE;
else if (strcmp(routing_str, "prog-adaptive") == 0)
routing = PROG_ADAPTIVE;
else { else {
fprintf(stderr, "No routing protocol specified, setting to minimal routing\n"); fprintf(stderr, "No routing protocol specified, setting to minimal routing\n");
routing = -1; routing = MINIMAL;
/* MM: This should be 2 for dragonfly plus*/ /* MM: This should be 2 for dragonfly plus*/
...@@ -633,12 +620,12 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -633,12 +620,12 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
p->num_cn = p->num_routers / 2; p->num_cn = p->num_routers / 2;
rc = configuration_get_value_int(&config, "PARAMS", "num_global_channels", anno, &p->num_global_channels); rc = configuration_get_value_int(&config, "PARAMS", "num_global_connections", anno, &p->num_global_connections);
if (rc) { if (rc) {
printf("\n Number of global channels per router not specified, setting to 10 "); printf("\n Number of global channels per router not specified, setting to 10 ");
p->num_global_channels = 10; p->num_global_connections = 10;
p->radix = p->intra_grp_radix + p->num_global_channels + p->radix = p->intra_grp_radix + p->num_global_connections +
p->num_cn; // TODO this may not be sufficient, radix isn't same for leaf and spine routers p->num_cn; // TODO this may not be sufficient, radix isn't same for leaf and spine routers
p->total_routers = p->num_groups * p->num_routers; p->total_routers = p->num_groups * p->num_routers;
p->total_terminals = (p->num_groups * p->num_router_leaf) * p->num_cn; p->total_terminals = (p->num_groups * p->num_router_leaf) * p->num_cn;
...@@ -672,6 +659,17 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -672,6 +659,17 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
// printf("DUMPING INTRA-CONN FOR ROUTER 3:\n");
// printf(" (dest - offset) \n");
// for (int i = 0; i < intraGroupLinks[3].size(); i++)
// for (int j = 0; j < intraGroupLinks[3][i].size(); j++)
// printf(" (%d - %d) ", i, intraGroupLinks[3][i][j].offset);
// printf("\n");
fclose(groupFile); fclose(groupFile);
// read inter group connections, store from a router's perspective // read inter group connections, store from a router's perspective
...@@ -818,10 +816,10 @@ void dragonfly_plus_report_stats() ...@@ -818,10 +816,10 @@ void dragonfly_plus_report_stats()
MPI_Reduce(&packet_gen, &total_gen, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce(&packet_gen, &total_gen, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES);
MPI_Reduce(&packet_fin, &total_fin, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce(&packet_fin, &total_fin, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES);
if (routing == ADAPTIVE || routing == PROG_ADAPTIVE) { // if (routing == ADAPTIVE || routing == PROG_ADAPTIVE) {
MPI_Reduce(&minimal_count, &total_minimal_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_CODES); // MPI_Reduce(&minimal_count, &total_minimal_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_CODES);
MPI_Reduce(&nonmin_count, &total_nonmin_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_CODES); // MPI_Reduce(&nonmin_count, &total_nonmin_packets, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_CODES);
/* print statistics */ /* print statistics */
if (!g_tw_mynode) { if (!g_tw_mynode) {
...@@ -831,11 +829,11 @@ void dragonfly_plus_report_stats() ...@@ -831,11 +829,11 @@ void dragonfly_plus_report_stats()
(float) avg_hops / total_finished_chunks, avg_time / (total_finished_chunks * 1000), (float) avg_hops / total_finished_chunks, avg_time / (total_finished_chunks * 1000),
max_time / 1000, (float) final_msg_sz / total_finished_msgs, total_finished_msgs, max_time / 1000, (float) final_msg_sz / total_finished_msgs, total_finished_msgs,
total_finished_chunks); total_finished_chunks);
if (routing == ADAPTIVE || routing == PROG_ADAPTIVE) // if (routing == ADAPTIVE || routing == PROG_ADAPTIVE)
printf( // printf(
"\n ADAPTIVE ROUTING STATS: %d chunks routed minimally %d chunks routed non-minimally " // "\n ADAPTIVE ROUTING STATS: %d chunks routed minimally %d chunks routed non-minimally "
"completed packets %lld \n", // "completed packets %lld \n",
total_minimal_packets, total_nonmin_packets, total_finished_chunks); // total_minimal_packets, total_nonmin_packets, total_finished_chunks);
printf("\n Total packets generated %ld finished %ld \n", total_gen, total_fin); printf("\n Total packets generated %ld finished %ld \n", total_gen, total_fin);
...@@ -986,42 +984,31 @@ void router_plus_setup(router_state *r, tw_lp *lp) ...@@ -986,42 +984,31 @@ void router_plus_setup(router_state *r, tw_lp *lp)
printf("%lu: %i is a LEAF\n",lp->gid, r->router_id); printf("%lu: %i is a LEAF\n",lp->gid, r->router_id);
// setup radix
if (r->dfp_router_type == SPINE) {
r->inter_radix_util = p->num_global_channels;
r->intra_radix_util = p->num_router_leaf * p->num_level_chans;
r->cn_radix_util = 0;
else { //leaf
r->intra_radix_util = p->num_router_spine * p->num_level_chans;
r->cn_radix_util = p->num_cn;
r->inter_radix_util = 0;
r->radix_util = r->inter_radix_util + r->intra_radix_util + r->cn_radix_util;
r->global_channel = (int *) malloc(p->num_global_channels * sizeof(int));
r->next_output_available_time = (tw_stime *) malloc(r->radix_util * sizeof(tw_stime));
r->link_traffic = (int64_t *) malloc(r->radix_util * sizeof(int64_t));
r->link_traffic_sample = (int64_t *) malloc(r->radix_util * sizeof(int64_t));
r->vc_occupancy = (int **) malloc(r->radix_util * sizeof(int *)); r->global_channel = (int *) malloc(p->num_global_connections * sizeof(int));
r->in_send_loop = (int *) malloc(r->radix_util * sizeof(int)); r->next_output_available_time = (tw_stime *) malloc(p->radix * sizeof(tw_stime));
r->link_traffic = (int64_t *) malloc(p->radix * sizeof(int64_t));
r->link_traffic_sample = (int64_t *) malloc(p->radix * sizeof(int64_t));
r->vc_occupancy = (int **) malloc(p->radix * sizeof(int *));
r->in_send_loop = (int *) malloc(p->radix * sizeof(int));
r->pending_msgs = r->pending_msgs =
(terminal_plus_message_list ***) malloc(r->radix_util * sizeof(terminal_plus_message_list **)); (terminal_plus_message_list ***) malloc(p->radix * sizeof(terminal_plus_message_list **));
r->pending_msgs_tail = r->pending_msgs_tail =
r->queued_msgs = r->queued_msgs =
r->queued_msgs_tail = r->queued_msgs_tail =
r->queued_count = (int *) malloc(r->radix_util * sizeof(int)); r->queued_count = (int *) malloc(p->radix * sizeof(int));
r->last_buf_full = (tw_stime **) malloc(r->radix_util * sizeof(tw_stime *)); r->last_buf_full = (tw_stime **) malloc(p->radix * sizeof(tw_stime *));
r->busy_time = (tw_stime *) malloc(r->radix_util * sizeof(tw_stime)); r->busy_time = (tw_stime *) malloc(p->radix * sizeof(tw_stime));
r->busy_time_sample = (tw_stime *) malloc(r->radix_util * sizeof(tw_stime)); r->busy_time_sample = (tw_stime *) malloc(p->radix * sizeof(tw_stime));
rc_stack_create(&r->st); rc_stack_create(&r->st);
for (int i = 0; i < r->radix_util; i++) { for (int i = 0; i < p->radix; i++) {
// Set credit & router occupancy // Set credit & router occupancy
r->busy_time[i] = 0.0; r->busy_time[i] = 0.0;
r->busy_time_sample[i] = 0.0; r->busy_time_sample[i] = 0.0;
...@@ -1471,8 +1458,8 @@ static void packet_arrive_rc(terminal_state *s, tw_bf *bf, terminal_plus_message ...@@ -1471,8 +1458,8 @@ static void packet_arrive_rc(terminal_state *s, tw_bf *bf, terminal_plus_message
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
if (msg->path_type == MINIMAL) if (msg->path_type == MINIMAL)
minimal_count--; minimal_count--;
if (msg->path_type == NON_MINIMAL) // if (msg->path_type == NON_MINIMAL)
nonmin_count--; // nonmin_count--;
N_finished_chunks--; N_finished_chunks--;
s->finished_chunks--; s->finished_chunks--;
...@@ -1649,15 +1636,15 @@ static void packet_arrive(terminal_state *s, tw_bf *bf, terminal_plus_message *m ...@@ -1649,15 +1636,15 @@ static void packet_arrive(terminal_state *s, tw_bf *bf, terminal_plus_message *m
minimal_count++; minimal_count++;
nonmin_count++; // nonmin_count++;
if (msg->chunk_id == num_chunks - 1) { if (msg->chunk_id == num_chunks - 1) {
bf->c31 = 1; bf->c31 = 1;
s->packet_fin++; s->packet_fin++;
packet_fin++; packet_fin++;
if (msg->path_type != MINIMAL && msg->path_type != NON_MINIMAL) if (msg->path_type != MINIMAL)
printf("\n Wrong message path type %d ", msg->path_type); printf("\n Wrong message path type %d ", msg->path_type);
/* save the sample time */ /* save the sample time */
...@@ -1775,13 +1762,13 @@ void dragonfly_plus_rsample_init(router_state *s, tw_lp *lp) ...@@ -1775,13 +1762,13 @@ void dragonfly_plus_rsample_init(router_state *s, tw_lp *lp)
int i = 0; int i = 0;
const dragonfly_plus_param *p = s->params; const dragonfly_plus_param *p = s->params;
assert(s->radix_util); assert(p->radix);
s->max_arr_size = MAX_STATS; s->max_arr_size = MAX_STATS;
s->rsamples = (struct dfly_router_sample *) malloc(MAX_STATS * sizeof(struct dfly_router_sample)); s->rsamples = (struct dfly_router_sample *) malloc(MAX_STATS * sizeof(struct dfly_router_sample));
for (; i < s->max_arr_size; i++) { for (; i < s->max_arr_size; i++) {
s->rsamples[i].busy_time = (tw_stime *) malloc(sizeof(tw_stime) * s->radix_util); s->rsamples[i].busy_time = (tw_stime *) malloc(sizeof(tw_stime) * p->radix);
s->rsamples[i].link_traffic_sample = (int64_t *) malloc(sizeof(int64_t) * s->radix_util); s->rsamples[i].link_traffic_sample = (int64_t *) malloc(sizeof(int64_t) * p->radix);
void dragonfly_plus_rsample_rc_fn(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp) void dragonfly_plus_rsample_rc_fn(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp)
...@@ -1797,12 +1784,12 @@ void dragonfly_plus_rsample_rc_fn(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -1797,12 +1784,12 @@ void dragonfly_plus_rsample_rc_fn(router_state *s, tw_bf *bf, terminal_plus_mess
for (; i < s->radix_util; i++) { for (; i < p->radix; i++) {
s->busy_time_sample[i] = stat.busy_time[i]; s->busy_time_sample[i] = stat.busy_time[i];
s->link_traffic_sample[i] = stat.link_traffic_sample[i]; s->link_traffic_sample[i] = stat.link_traffic_sample[i];
for (i = 0; i < s->radix_util; i++) { for (i = 0; i < p->radix; i++) {
stat.busy_time[i] = 0; stat.busy_time[i] = 0;
stat.link_traffic_sample[i] = 0; stat.link_traffic_sample[i] = 0;
...@@ -1835,7 +1822,7 @@ void dragonfly_plus_rsample_fn(router_state *s, tw_bf *bf, terminal_plus_message ...@@ -1835,7 +1822,7 @@ void dragonfly_plus_rsample_fn(router_state *s, tw_bf *bf, terminal_plus_message
s->rsamples[cur_indx].fwd_events = s->fwd_events; s->rsamples[cur_indx].fwd_events = s->fwd_events;
s->rsamples[cur_indx].rev_events = s->rev_events; s->rsamples[cur_indx].rev_events = s->rev_events;
s->rsamples[cur_indx].busy_time[i] = s->busy_time_sample[i]; s->rsamples[cur_indx].busy_time[i] = s->busy_time_sample[i];
s->rsamples[cur_indx].link_traffic_sample[i] = s->link_traffic_sample[i]; s->rsamples[cur_indx].link_traffic_sample[i] = s->link_traffic_sample[i];
...@@ -1846,7 +1833,7 @@ void dragonfly_plus_rsample_fn(router_state *s, tw_bf *bf, terminal_plus_message ...@@ -1846,7 +1833,7 @@ void dragonfly_plus_rsample_fn(router_state *s, tw_bf *bf, terminal_plus_message
s->fwd_events = 0; s->fwd_events = 0;
s->rev_events = 0; s->rev_events = 0;
s->busy_time_sample[i] = 0; s->busy_time_sample[i] = 0;
s->link_traffic_sample[i] = 0; s->link_traffic_sample[i] = 0;
...@@ -1868,7 +1855,7 @@ void dragonfly_plus_rsample_fin(router_state *s, tw_lp *lp) ...@@ -1868,7 +1855,7 @@ void dragonfly_plus_rsample_fin(router_state *s, tw_lp *lp)
"(double) \n" "(double) \n"
"link traffic for each of the %d links (int64_t) \nsample end time (double) forward events " "link traffic for each of the %d links (int64_t) \nsample end time (double) forward events "
"per sample \nreverse events per sample ", "per sample \nreverse events per sample ",
s->radix_util, s->radix_util); p->radix, p->radix);
fclose(fp); fclose(fp);
char rt_fn[MAX_NAME_LENGTH]; char rt_fn[MAX_NAME_LENGTH];
...@@ -1879,15 +1866,15 @@ void dragonfly_plus_rsample_fin(router_state *s, tw_lp *lp) ...@@ -1879,15 +1866,15 @@ void dragonfly_plus_rsample_fin(router_state *s, tw_lp *lp)
int size_sample = sizeof(tw_lpid) + s->radix_util * (sizeof(int64_t) + sizeof(tw_stime)) + int size_sample = sizeof(tw_lpid) + p->radix * (sizeof(int64_t) + sizeof(tw_stime)) +
sizeof(tw_stime) + 2 * sizeof(long); sizeof(tw_stime) + 2 * sizeof(long);
FILE *fp = fopen(rt_fn, "a"); FILE *fp = fopen(rt_fn, "a");
fseek(fp, sample_rtr_bytes_written, SEEK_SET); fseek(fp, sample_rtr_bytes_written, SEEK_SET);
for (; i < s->op_arr_size; i++) { for (; i < s->op_arr_size; i++) {
fwrite((void *) &(s->rsamples[i].router_id), sizeof(tw_lpid), 1, fp); fwrite((void *) &(s->rsamples[i].router_id), sizeof(tw_lpid), 1, fp);
fwrite(s->rsamples[i].busy_time, sizeof(tw_stime), s->radix_util, fp); fwrite(s->rsamples[i].busy_time, sizeof(tw_stime), p->radix, fp);
fwrite(s->rsamples[i].link_traffic_sample, sizeof(int64_t), s->radix_util, fp); fwrite(s->rsamples[i].link_traffic_sample, sizeof(int64_t), p->radix, fp);
fwrite((void *) &(s->rsamples[i].end_time), sizeof(tw_stime), 1, fp); fwrite((void *) &(s->rsamples[i].end_time), sizeof(tw_stime), 1, fp);
fwrite((void *) &(s->rsamples[i].fwd_events), sizeof(long), 1, fp); fwrite((void *) &(s->rsamples[i].fwd_events), sizeof(long), 1, fp);
fwrite((void *) &(s->rsamples[i].rev_events), sizeof(long), 1, fp); fwrite((void *) &(s->rsamples[i].rev_events), sizeof(long), 1, fp);
...@@ -2113,7 +2100,7 @@ void dragonfly_plus_router_final(router_state *s, tw_lp *lp) ...@@ -2113,7 +2100,7 @@ void dragonfly_plus_router_final(router_state *s, tw_lp *lp)
free(s->global_channel); free(s->global_channel);
int i, j; int i, j;
for (i = 0; i < s->radix_util; i++) { for (i = 0; i < s->params->radix; i++) {
for (j = 0; j < s->params->num_vcs; j++) { for (j = 0; j < s->params->num_vcs; j++) {
if (s->queued_msgs[i][j] != NULL) { if (s->queued_msgs[i][j] != NULL) {
printf("[%llu] leftover queued messages %d %d %d\n", LLU(lp->gid), i, j, printf("[%llu] leftover queued messages %d %d %d\n", LLU(lp->gid), i, j,
...@@ -2139,7 +2126,7 @@ void dragonfly_plus_router_final(router_state *s, tw_lp *lp) ...@@ -2139,7 +2126,7 @@ void dragonfly_plus_router_final(router_state *s, tw_lp *lp)
written += sprintf(s->output_buf + written, "\n %llu %d %d", LLU(lp->gid), s->router_id / p->num_routers, written += sprintf(s->output_buf + written, "\n %llu %d %d", LLU(lp->gid), s->router_id / p->num_routers,
s->router_id % p->num_routers); s->router_id % p->num_routers);
for (int d = 0; d < s->radix_util; d++) for (int d = 0; d < p->radix; d++)
written += sprintf(s->output_buf + written, " %lf", s->busy_time[d]); written += sprintf(s->output_buf + written, " %lf", s->busy_time[d]);
sprintf(s->output_buf + written, "\n"); sprintf(s->output_buf + written, "\n");
...@@ -2154,7 +2141,7 @@ void dragonfly_plus_router_final(router_state *s, tw_lp *lp) ...@@ -2154,7 +2141,7 @@ void dragonfly_plus_router_final(router_state *s, tw_lp *lp)
written += sprintf(s->output_buf2 + written, "\n %llu %d %d", LLU(lp->gid), s->router_id / p->num_routers, written += sprintf(s->output_buf2 + written, "\n %llu %d %d", LLU(lp->gid), s->router_id / p->num_routers,
written += sprintf(s->output_buf2 + written, " %lld", LLD(s->link_traffic[d])); written += sprintf(s->output_buf2 + written, " %lld", LLD(s->link_traffic[d]));
lp_io_write(lp->gid, (char *) "dragonfly-plus-router-traffic", written, s->output_buf2); lp_io_write(lp->gid, (char *) "dragonfly-plus-router-traffic", written, s->output_buf2);
...@@ -2165,11 +2152,11 @@ void dragonfly_plus_router_final(router_state *s, tw_lp *lp) ...@@ -2165,11 +2152,11 @@ void dragonfly_plus_router_final(router_state *s, tw_lp *lp)
* leaf router alone. */ * leaf router alone. */
/* Neil: For now I think this will work as is. With a 2 level fat tree at the group level, /* Neil: For now I think this will work as is. With a 2 level fat tree at the group level,
* this is overkill, perhaps. * this is overkill, perhaps.
static vector< int > get_intra_router(router_state *s, int src_router_id, int dest_router_id, static vector< int > get_intra_router(router_state *s, int src_router_id, int dest_router_id)
int num_rtrs_per_grp)
int num_rtrs_per_grp = s->params->num_routers;
/* Check for intra-group connections */ /* Check for intra-group connections */
int src_rel_id = src_router_id % num_rtrs_per_grp; int src_rel_id = src_router_id % num_rtrs_per_grp;
int dest_rel_id = dest_router_id % num_rtrs_per_grp; int dest_rel_id = dest_router_id % num_rtrs_per_grp;
...@@ -2227,7 +2214,7 @@ static tw_lpid get_next_stop(router_state *s, ...@@ -2227,7 +2214,7 @@ static tw_lpid get_next_stop(router_state *s,
int origin_grp_id = msg->origin_router_id / s->params->num_routers; int origin_grp_id = msg->origin_router_id / s->params->num_routers;
int select_chan = -1; int select_chan = -1;
/* If the packet has arrived at the destination router -------------------------------*/ /* If the packet has arrived at the destination router -------------------------------*/
if (dest_router_id == local_router_id) { if (dest_router_id == local_router_id) {
dest_lp = msg->dest_terminal_id; dest_lp = msg->dest_terminal_id;
...@@ -2237,8 +2224,14 @@ static tw_lpid get_next_stop(router_state *s, ...@@ -2237,8 +2224,14 @@ static tw_lpid get_next_stop(router_state *s,
/* If the packet has arrived at the destination group --------------------------------*/ /* If the packet has arrived at the destination group --------------------------------*/
if (s->group_id == dest_group_id) { if (s->group_id == dest_group_id) {
bf->c19 = 1; bf->c19 = 1;
vector< int > next_stop = get_intra_router(s, local_router_id, dest_router_id, s->params->num_routers); vector< int > next_stop = get_intra_router(s, local_router_id, dest_router_id);
printf("%d: Router next stop is: [",s->router_id);
for (vector<int>::iterator it = next_stop.begin(); it != next_stop.end(); it++)
printf(" %d ",*it);
printf("]\n");
assert(!next_stop.empty()); assert(!next_stop.empty());
select_chan = tw_rand_integer(lp->rng, 0, next_stop.size() - 1); select_chan = tw_rand_integer(lp->rng, 0, next_stop.size() - 1);
...@@ -2258,6 +2251,8 @@ static tw_lpid get_next_stop(router_state *s, ...@@ -2258,6 +2251,8 @@ static tw_lpid get_next_stop(router_state *s,
if (msg->last_hop == TERMINAL) { if (msg->last_hop == TERMINAL) {
assert(s->dfp_router_type == LEAF); //We're a leaf assert(s->dfp_router_type == LEAF); //We're a leaf
//Need to select a spine router from current group to forward to //Need to select a spine router from current group to forward to
select_chan = tw_rand_integer(lp->rng, 0, connectionList[my_grp_id][dest_group_id].size() - 1); select_chan = tw_rand_integer(lp->rng, 0, connectionList[my_grp_id][dest_group_id].size() - 1);
...@@ -2285,145 +2280,90 @@ static tw_lpid get_next_stop(router_state *s, ...@@ -2285,145 +2280,90 @@ static tw_lpid get_next_stop(router_state *s,
/* gets the output port corresponding to the next stop of the message */ /* gets the output port corresponding to the next stop of the message */
static int get_output_port(router_state *s, terminal_plus_message *msg, tw_lp *lp, tw_bf *bf, tw_lpid next_stop) static int get_output_port(router_state *s, terminal_plus_message *msg, tw_lp *lp, tw_bf *bf, tw_lpid next_stop)
// tw_error(TW_LOC, "\n DRAGONFLY PLUS GET OUTPUT PORT NOT IMPLEMENTED"); printf("%d: Get Output Port()\n", s->router_id);
printf("%lu, Router %d: Get Output Port()\n",lp->gid, s->router_id); int output_port = -1;
int output_port = 0;
int rand_offset = -1;
int terminal_id = codes_mapping_get_lp_relative_id(msg->dest_terminal_id, 0, 0); int terminal_id = codes_mapping_get_lp_relative_id(msg->dest_terminal_id, 0, 0);
int dest_router = codes_mapping_get_lp_relative_id(next_stop, 0, 0); //turns lpid into the corresponding router id int dest_router = codes_mapping_get_lp_relative_id(next_stop, 0, 0); //turns lpid into the corresponding router id
int dest_group_id = dest_router / p->num_routers;
int src_router = s->router_id; int src_router = s->router_id;
printf("\tdest_router = %d (%lu)\n",dest_router,next_stop); printf("\tdest_router = %d (%lu)\n",dest_router,next_stop);
if ((tw_lpid) next_stop == msg->dest_terminal_id) { // if the next stop is the destination if (s->dfp_router_type == LEAF) {
/* Make a random number selection (only for reverse computation) */ //packet from leaf must go to either destination terminal or to a spine router
int rand_sel = tw_rand_integer(lp->rng, 0, terminal_id);
output_port = s->intra_radix_util + s->inter_radix_util + (terminal_id % s->cn_radix_util); if ((tw_lpid) next_stop == msg->dest_terminal_id) { // if the next stop is the destination
int rand_sel = tw_rand_integer(lp->rng, 0, 2); // Make a random number selection (only for reverse computation)
printf("\t%d\n",output_port); output_port = p->intra_grp_radix + p->num_global_connections + (terminal_id % p->num_cn); //TODO this seems wrong?
// output_port = p->intra_grp_radix + p->num_global_channels + (terminal_id % p->num_cn); printf("\tPort: %d (terminal)\n", output_port);
else {
// next stop is not the destination terminal - must go to spine router in same group
int src_loc_id = src_router % p->num_routers;
int dest_loc_id = dest_router % p->num_routers;
int num_links = intraGroupLinks[src_loc_id][dest_loc_id].size(); //number of ports connecting src_router to dest_router
printf("\tnum_links to dest = %d\n", num_links);
if (routing == MINIMAL) {
//minimal doesn't care about adaptive routing, ARNs. Choose port to dest at random
int rand_sel = tw_rand_integer(lp->rng,0,num_links-1);
int offset = intraGroupLinks[src_loc_id][dest_loc_id][rand_sel].offset;
output_port = offset; //first ports are the intra-group ports so offset alone is sufficient
printf("\tPort: %d (intra)\n", output_port);
else {
tw_error(TW_LOC, "\nget_output_port() Unsupported Routing Algorithm");
// else { else if (s->dfp_router_type == SPINE) {
// int intm_grp_id = dest_router / p->num_routers; //packet from spine must go to either a leaf in the same group or to a spine router in another group
// int rand_offset = -1; if (dest_group_id == s->group_id) { // if the destination group id is this routers group
//needs to send to leaf via intra group connections
// if (intm_grp_id != s->group_id) { int src_loc_id = src_router % p->num_routers;
// /* traversing a global channel */ int dest_loc_id = dest_router % p->num_routers;
// vector< bLink > &curVec = interGroupLinks[src_router][intm_grp_id];
// if (interGroupLinks[src_router][intm_grp_id].size() == 0)
// printf("\n Source router %d intm_grp_id %d ", src_router, intm_grp_id);
// assert(interGroupLinks[src_router][intm_grp_id].size() > 0);
// rand_offset = tw_rand_integer(lp->rng, 0, interGroupLinks[src_router][intm_grp_id].size() - 1);
// assert(rand_offset >= 0);
// bLink bl = interGroupLinks[src_router][intm_grp_id][rand_offset];
// int channel_id = bl.offset;
// output_port = p->intra_grp_radix + channel_id;
// else {
// int intra_rtr_id = (dest_router % p->num_routers);
// int intragrp_rtr_id = s->router_id % p->num_routers;
// int src_col = intragrp_rtr_id % p->num_router_cols;
// int src_row = intragrp_rtr_id / p->num_router_cols;
// int dest_col = intra_rtr_id % p->num_router_cols;
