Commit 6f18f25b authored by Neil McGlohon's avatar Neil McGlohon
Adjusted build process for boost - needs refinement before merge to main
parent 0c071fe4
...@@ -13,6 +13,8 @@ EXTRA_PROGRAMS = ...@@ -13,6 +13,8 @@ EXTRA_PROGRAMS =
CLEANFILES = $(bin_SCRIPTS) CLEANFILES = $(bin_SCRIPTS)
EXTRA_DIST = EXTRA_DIST =
BUILT_SOURCES = BUILT_SOURCES =
AM_LDFLAGS =
# pkgconfig files # pkgconfig files
pkgconfigdir = $(libdir)/pkgconfig pkgconfigdir = $(libdir)/pkgconfig
...@@ -5,6 +5,10 @@ AC_PREREQ([2.67]) ...@@ -5,6 +5,10 @@ AC_PREREQ([2.67])
AC_INIT([codes], [0.6.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/]) AC_INIT([codes], [0.6.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/])
LT_INIT LT_INIT
#WRAP SOME OPTION AROUND THIS - IT'S NOT REQUIRED FOR 99% OF CODES
AX_BOOST_BASE([1.66])
AC_CANONICAL_TARGET AC_CANONICAL_TARGET
AC_CANONICAL_SYSTEM AC_CANONICAL_SYSTEM
AC_CANONICAL_HOST AC_CANONICAL_HOST
# https://www.gnu.org/software/autoconf-archive/ax_boost_base.html
# SYNOPSIS
# AX_BOOST_BASE([MINIMUM-VERSION], [ACTION-IF-FOUND], [ACTION-IF-NOT-FOUND])
# DESCRIPTION
# Test for the Boost C++ libraries of a particular version (or newer)
# If no path to the installed boost library is given the macro searchs
# under /usr, /usr/local, /opt and /opt/local and evaluates the
# $BOOST_ROOT environment variable. Further documentation is available at
# <http://randspringer.de/boost/index.html>.
# This macro calls:
# AC_SUBST(BOOST_CPPFLAGS) / AC_SUBST(BOOST_LDFLAGS)
# And sets:
# HAVE_BOOST
# LICENSE
# Copyright (c) 2008 Thomas Porschberg <thomas@randspringer.de>
# Copyright (c) 2009 Peter Adolphs
# Copying and distribution of this file, with or without modification, are
# permitted in any medium without royalty provided the copyright notice
# and this notice are preserved. This file is offered as-is, without any
# warranty.
#serial 44
# example boost program (need to pass version)
m4_define([_AX_BOOST_BASE_PROGRAM],
[AC_LANG_PROGRAM([[
#include <boost/version.hpp>
(void) ((void)sizeof(char[1 - 2*!!((BOOST_VERSION) < ($1))]));
AC_DEFUN([AX_BOOST_BASE],
AC_ARG_WITH([boost],
[AS_HELP_STRING([--with-boost@<:@=ARG@:>@],
[use Boost library from a standard location (ARG=yes),
from the specified location (ARG=<path>),
or disable it (ARG=no)
@<:@ARG=yes@:>@ ])],
AS_CASE([$withval],
[no],[want_boost="no";_AX_BOOST_BASE_boost_path=""],
[yes],[want_boost="yes";_AX_BOOST_BASE_boost_path=""],
[want_boost="yes";_AX_BOOST_BASE_boost_path="$withval"])
[want_boost="yes"])
AC_ARG_WITH([boost-libdir],
[AS_HELP_STRING([--with-boost-libdir=LIB_DIR],
[Force given directory for boost libraries.
Note that this will override library path detection,
so use this parameter only if default library detection fails
and you know exactly where your boost libraries are located.])],
AS_IF([test -d "$withval"],
[_AX_BOOST_BASE_boost_lib_path="$withval"],
[AC_MSG_ERROR([--with-boost-libdir expected directory name])])
[_AX_BOOST_BASE_boost_lib_path=""])
BOOST_LDFLAGS=""
BOOST_CPPFLAGS=""
AS_IF([test "x$want_boost" = "xyes"],
[_AX_BOOST_BASE_RUNDETECT([$1],[$2],[$3])])
# convert a version string in $2 to numeric and affect to polymorphic var $1
AC_DEFUN([_AX_BOOST_BASE_TONUMERICVERSION],[
AS_IF([test "x$2" = "x"],[_AX_BOOST_BASE_TONUMERICVERSION_req="1.20.0"],[_AX_BOOST_BASE_TONUMERICVERSION_req="$2"])
_AX_BOOST_BASE_TONUMERICVERSION_req_shorten=`expr $_AX_BOOST_BASE_TONUMERICVERSION_req : '\([[0-9]]*\.[[0-9]]*\)'`
_AX_BOOST_BASE_TONUMERICVERSION_req_major=`expr $_AX_BOOST_BASE_TONUMERICVERSION_req : '\([[0-9]]*\)'`
AS_IF([test "x$_AX_BOOST_BASE_TONUMERICVERSION_req_major" = "x"],
[AC_MSG_ERROR([You should at least specify libboost major version])])
_AX_BOOST_BASE_TONUMERICVERSION_req_minor=`expr $_AX_BOOST_BASE_TONUMERICVERSION_req : '[[0-9]]*\.\([[0-9]]*\)'`
AS_IF([test "x$_AX_BOOST_BASE_TONUMERICVERSION_req_minor" = "x"],
[_AX_BOOST_BASE_TONUMERICVERSION_req_minor="0"])
_AX_BOOST_BASE_TONUMERICVERSION_req_sub_minor=`expr $_AX_BOOST_BASE_TONUMERICVERSION_req : '[[0-9]]*\.[[0-9]]*\.\([[0-9]]*\)'`
AS_IF([test "X$_AX_BOOST_BASE_TONUMERICVERSION_req_sub_minor" = "X"],
[_AX_BOOST_BASE_TONUMERICVERSION_req_sub_minor="0"])
_AX_BOOST_BASE_TONUMERICVERSION_RET=`expr $_AX_BOOST_BASE_TONUMERICVERSION_req_major \* 100000 \+ $_AX_BOOST_BASE_TONUMERICVERSION_req_minor \* 100 \+ $_AX_BOOST_BASE_TONUMERICVERSION_req_sub_minor`
AS_VAR_SET($1,$_AX_BOOST_BASE_TONUMERICVERSION_RET)
dnl Run the detection of boost should be run only if $want_boost
AC_DEFUN([_AX_BOOST_BASE_RUNDETECT],[
_AX_BOOST_BASE_TONUMERICVERSION(WANT_BOOST_VERSION,[$1])
succeeded=no
AC_REQUIRE([AC_CANONICAL_HOST])
dnl On 64-bit systems check for system libraries in both lib64 and lib.
dnl The former is specified by FHS, but e.g. Debian does not adhere to
dnl this (as it rises problems for generic multi-arch support).
dnl The last entry in the list is chosen by default when no libraries
dnl are found, e.g. when only header-only libraries are installed!
AS_CASE([${host_cpu}],
[x86_64],[libsubdirs="lib64 libx32 lib lib64"],
[ppc64|s390x|sparc64|aarch64|ppc64le|riscv64],[libsubdirs="lib64 lib lib64"],
[libsubdirs="lib"]
dnl allow for real multi-arch paths e.g. /usr/lib/x86_64-linux-gnu. Give
dnl them priority over the other paths since, if libs are found there, they
dnl are almost assuredly the ones desired.
[i?86],[multiarch_libsubdir="lib/i386-${host_os}"],
[multiarch_libsubdir="lib/${host_cpu}-${host_os}"]
dnl first we check the system location for boost libraries
dnl this location ist chosen if boost libraries are installed with the --layout=system option
dnl or if you install boost with RPM
AS_IF([test "x$_AX_BOOST_BASE_boost_path" != "x"],[
AC_MSG_CHECKING([for boostlib >= $1 ($WANT_BOOST_VERSION) includes in "$_AX_BOOST_BASE_boost_path/include"])
AS_IF([test -d "$_AX_BOOST_BASE_boost_path/include" && test -r "$_AX_BOOST_BASE_boost_path/include"],[
AC_MSG_RESULT([yes])
BOOST_CPPFLAGS="-I$_AX_BOOST_BASE_boost_path/include"
for _AX_BOOST_BASE_boost_path_tmp in $multiarch_libsubdir $libsubdirs; do
AC_MSG_CHECKING([for boostlib >= $1 ($WANT_BOOST_VERSION) lib path in "$_AX_BOOST_BASE_boost_path/$_AX_BOOST_BASE_boost_path_tmp"])
AS_IF([test -d "$_AX_BOOST_BASE_boost_path/$_AX_BOOST_BASE_boost_path_tmp" && test -r "$_AX_BOOST_BASE_boost_path/$_AX_BOOST_BASE_boost_path_tmp" ],[
BOOST_LDFLAGS="-L$_AX_BOOST_BASE_boost_path/$_AX_BOOST_BASE_boost_path_tmp";
break;
[AC_MSG_RESULT([no])])
done],[
if test X"$cross_compiling" = Xyes; then
search_libsubdirs=$multiarch_libsubdir
else
search_libsubdirs="$multiarch_libsubdir $libsubdirs"
fi
for _AX_BOOST_BASE_boost_path_tmp in /usr /usr/local /opt /opt/local ; do
if test -d "$_AX_BOOST_BASE_boost_path_tmp/include/boost" && test -r "$_AX_BOOST_BASE_boost_path_tmp/include/boost" ; then
for libsubdir in $search_libsubdirs ; do
if ls "$_AX_BOOST_BASE_boost_path_tmp/$libsubdir/libboost_"* >/dev/null 2>&1 ; then break; fi
done
BOOST_LDFLAGS="-L$_AX_BOOST_BASE_boost_path_tmp/$libsubdir"
BOOST_CPPFLAGS="-I$_AX_BOOST_BASE_boost_path_tmp/include"
break;
fi
done
dnl overwrite ld flags if we have required special directory with
dnl --with-boost-libdir parameter
AS_IF([test "x$_AX_BOOST_BASE_boost_lib_path" != "x"],
[BOOST_LDFLAGS="-L$_AX_BOOST_BASE_boost_lib_path"])
AC_MSG_CHECKING([for boostlib >= $1 ($WANT_BOOST_VERSION)])
CPPFLAGS_SAVED="$CPPFLAGS"
CPPFLAGS="$CPPFLAGS $BOOST_CPPFLAGS"
export CPPFLAGS
LDFLAGS_SAVED="$LDFLAGS"
LDFLAGS="$LDFLAGS $BOOST_LDFLAGS"
export LDFLAGS
AC_REQUIRE([AC_PROG_CXX])
AC_LANG_PUSH(C++)
AC_COMPILE_IFELSE([_AX_BOOST_BASE_PROGRAM($WANT_BOOST_VERSION)],[
AC_MSG_RESULT(yes)
succeeded=yes
found_system=yes
AC_LANG_POP([C++])
dnl if we found no boost with system layout we search for boost libraries
dnl built and installed without the --layout=system option or for a staged(not installed) version
if test "x$succeeded" != "xyes" ; then
CPPFLAGS="$CPPFLAGS_SAVED"
LDFLAGS="$LDFLAGS_SAVED"
BOOST_CPPFLAGS=
if test -z "$_AX_BOOST_BASE_boost_lib_path" ; then
BOOST_LDFLAGS=
fi
_version=0
if test -n "$_AX_BOOST_BASE_boost_path" ; then
if test -d "$_AX_BOOST_BASE_boost_path" && test -r "$_AX_BOOST_BASE_boost_path"; then
for i in `ls -d $_AX_BOOST_BASE_boost_path/include/boost-* 2>/dev/null`; do
_version_tmp=`echo $i | sed "s#$_AX_BOOST_BASE_boost_path##" | sed 's/\/include\/boost-//' | sed 's/_/./'`
V_CHECK=`expr $_version_tmp \> $_version`
if test "x$V_CHECK" = "x1" ; then
_version=$_version_tmp
fi
VERSION_UNDERSCORE=`echo $_version | sed 's/\./_/'`
BOOST_CPPFLAGS="-I$_AX_BOOST_BASE_boost_path/include/boost-$VERSION_UNDERSCORE"
done
dnl if nothing found search for layout used in Windows distributions
if test -z "$BOOST_CPPFLAGS"; then
if test -d "$_AX_BOOST_BASE_boost_path/boost" && test -r "$_AX_BOOST_BASE_boost_path/boost"; then
BOOST_CPPFLAGS="-I$_AX_BOOST_BASE_boost_path"
fi
fi
dnl if we found something and BOOST_LDFLAGS was unset before
dnl (because "$_AX_BOOST_BASE_boost_lib_path" = ""), set it here.
if test -n "$BOOST_CPPFLAGS" && test -z "$BOOST_LDFLAGS"; then
for libsubdir in $libsubdirs ; do
if ls "$_AX_BOOST_BASE_boost_path/$libsubdir/libboost_"* >/dev/null 2>&1 ; then break; fi
done
BOOST_LDFLAGS="-L$_AX_BOOST_BASE_boost_path/$libsubdir"
fi
fi
else
if test "x$cross_compiling" != "xyes" ; then
for _AX_BOOST_BASE_boost_path in /usr /usr/local /opt /opt/local ; do
if test -d "$_AX_BOOST_BASE_boost_path" && test -r "$_AX_BOOST_BASE_boost_path" ; then
best_path=$_AX_BOOST_BASE_boost_path
fi
done
fi
done
BOOST_CPPFLAGS="-I$best_path/include/boost-$VERSION_UNDERSCORE"
if ls "$best_path/$libsubdir/libboost_"* >/dev/null 2>&1 ; then break; fi
done
BOOST_LDFLAGS="-L$best_path/$libsubdir"
fi
fi
if test -n "$BOOST_ROOT" ; then
if ls "$BOOST_ROOT/stage/$libsubdir/libboost_"* >/dev/null 2>&1 ; then break; fi
done
if test -d "$BOOST_ROOT" && test -r "$BOOST_ROOT" && test -d "$BOOST_ROOT/stage/$libsubdir" && test -r "$BOOST_ROOT/stage/$libsubdir"; then
version_dir=`expr //$BOOST_ROOT : '.*/\(.*\)'`
stage_version=`echo $version_dir | sed 's/boost_//' | sed 's/_/./g'`
stage_version_shorten=`expr $stage_version : '\([[0-9]]*\.[[0-9]]*\)'`
V_CHECK=`expr $stage_version_shorten \>\= $_version`
if test "x$V_CHECK" = "x1" && test -z "$_AX_BOOST_BASE_boost_lib_path" ; then
AC_MSG_NOTICE(We will use a staged boost library from $BOOST_ROOT)
BOOST_CPPFLAGS="-I$BOOST_ROOT"
BOOST_LDFLAGS="-L$BOOST_ROOT/stage/$libsubdir"
fi
fi
fi
fi
export CPPFLAGS
export LDFLAGS
AC_LANG_PUSH(C++)
AC_MSG_RESULT(yes)
succeeded=yes
found_system=yes
AC_LANG_POP([C++])
fi
if test "x$_version" = "x0" ; then
AC_MSG_NOTICE([[We could not detect the boost libraries (version $1 or higher). If you have a staged boost library (still not installed) please specify \$BOOST_ROOT in your environment and do not give a PATH to --with-boost option. If you are sure you have boost installed, then check your version number looking in <boost/version.hpp>. See http://randspringer.de/boost for more documentation.]])
else
AC_MSG_NOTICE([Your boost libraries seems to old (version $_version).])
fi
# execute ACTION-IF-NOT-FOUND (if present):
ifelse([$3], , :, [$3])
else
AC_DEFINE(HAVE_BOOST,,[define if the Boost library is available])
# execute ACTION-IF-FOUND (if present):
ifelse([$2], , :, [$2])
fi
# https://www.gnu.org/software/autoconf-archive/ax_boost_filesystem.html
# SYNOPSIS
# AX_BOOST_FILESYSTEM
# DESCRIPTION
# Test for Filesystem library from the Boost C++ libraries. The macro
# requires a preceding call to AX_BOOST_BASE. Further documentation is
# available at <http://randspringer.de/boost/index.html>.
# This macro calls:
# AC_SUBST(BOOST_FILESYSTEM_LIB)
# And sets:
# HAVE_BOOST_FILESYSTEM
# LICENSE
# Copyright (c) 2009 Thomas Porschberg <thomas@randspringer.de>
# Copyright (c) 2009 Michael Tindal
# Copyright (c) 2009 Roman Rybalko <libtorrent@romanr.info>
# warranty.
#serial 27
AC_DEFUN([AX_BOOST_FILESYSTEM],
AC_ARG_WITH([boost-filesystem],
AS_HELP_STRING([--with-boost-filesystem@<:@=special-lib@:>@],
[use the Filesystem library from boost - it is possible to specify a certain library for the linker
e.g. --with-boost-filesystem=boost_filesystem-gcc-mt ]),
if test "$withval" = "no"; then
want_boost="no"
elif test "$withval" = "yes"; then
want_boost="yes"
ax_boost_user_filesystem_lib=""
else
want_boost="yes"
ax_boost_user_filesystem_lib="$withval"
fi
[want_boost="yes"]
if test "x$want_boost" = "xyes"; then
AC_REQUIRE([AC_PROG_CC])
export CPPFLAGS
export LDFLAGS
LIBS_SAVED=$LIBS
LIBS="$LIBS $BOOST_SYSTEM_LIB"
export LIBS
AC_CACHE_CHECK(whether the Boost::Filesystem library is available,
ax_cv_boost_filesystem,
[AC_LANG_PUSH([C++])
AC_COMPILE_IFELSE([AC_LANG_PROGRAM([[@%:@include <boost/filesystem/path.hpp>]],
[[using namespace boost::filesystem;
path my_path( "foo/bar/data.txt" );
return 0;]])],
ax_cv_boost_filesystem=yes, ax_cv_boost_filesystem=no)
AC_LANG_POP([C++])
if test "x$ax_cv_boost_filesystem" = "xyes"; then
AC_DEFINE(HAVE_BOOST_FILESYSTEM,,[define if the Boost::Filesystem library is available])
BOOSTLIBDIR=`echo $BOOST_LDFLAGS | sed -e 's/@<:@^\/@:>@*//'`
if test "x$ax_boost_user_filesystem_lib" = "x"; then
for libextension in `ls -r $BOOSTLIBDIR/libboost_filesystem* 2>/dev/null | sed 's,.*/lib,,' | sed 's,\..*,,'` ; do
ax_lib=${libextension}
AC_CHECK_LIB($ax_lib, exit,
[BOOST_FILESYSTEM_LIB="-l$ax_lib"; AC_SUBST(BOOST_FILESYSTEM_LIB) link_filesystem="yes"; break],
[link_filesystem="no"])
done
if test "x$link_filesystem" != "xyes"; then
for libextension in `ls -r $BOOSTLIBDIR/boost_filesystem* 2>/dev/null | sed 's,.*/,,' | sed -e 's,\..*,,'` ; do
done
fi
else
for ax_lib in $ax_boost_user_filesystem_lib boost_filesystem-$ax_boost_user_filesystem_lib; do
done
fi
if test "x$ax_lib" = "x"; then
AC_MSG_ERROR(Could not find a version of the library!)
fi
AC_MSG_ERROR(Could not link against $ax_lib !)
fi
fi
LIBS="$LIBS_SAVED"
fi
# https://www.gnu.org/software/autoconf-archive/ax_boost_system.html
# SYNOPSIS
# AX_BOOST_SYSTEM
# DESCRIPTION
# Test for System library from the Boost C++ libraries. The macro requires
# a preceding call to AX_BOOST_BASE. Further documentation is available at
# This macro calls:
# AC_SUBST(BOOST_SYSTEM_LIB)
# And sets:
# HAVE_BOOST_SYSTEM
# LICENSE
# Copyright (c) 2008 Michael Tindal
# Copyright (c) 2008 Daniel Casimiro <dan.casimiro@gmail.com>
# warranty.
#serial 19
AC_DEFUN([AX_BOOST_SYSTEM],
AC_ARG_WITH([boost-system],
AS_HELP_STRING([--with-boost-system@<:@=special-lib@:>@],
[use the System library from boost - it is possible to specify a certain library for the linker
e.g. --with-boost-system=boost_system-gcc-mt ]),
want_boost="no"
want_boost="yes"
ax_boost_user_system_lib=""
else
want_boost="yes"
ax_boost_user_system_lib="$withval"
fi
[want_boost="yes"]
AC_REQUIRE([AC_CANONICAL_BUILD])
export CPPFLAGS
export LDFLAGS
AC_CACHE_CHECK(whether the Boost::System library is available,
ax_cv_boost_system,
CXXFLAGS_SAVE=$CXXFLAGS
CXXFLAGS=
AC_COMPILE_IFELSE([AC_LANG_PROGRAM([[@%:@include <boost/system/error_code.hpp>]],
[[boost::system::error_category *a = 0;]])],
ax_cv_boost_system=yes, ax_cv_boost_system=no)
CXXFLAGS=$CXXFLAGS_SAVE
AC_LANG_POP([C++])
if test "x$ax_cv_boost_system" = "xyes"; then
AC_DEFINE(HAVE_BOOST_SYSTEM,,[define if the Boost::System library is available])
LDFLAGS_SAVE=$LDFLAGS
if test "x$ax_boost_user_system_lib" = "x"; then
for libextension in `ls -r $BOOSTLIBDIR/libboost_system* 2>/dev/null | sed 's,.*/lib,,' | sed 's,\..*,,'` ; do
[BOOST_SYSTEM_LIB="-l$ax_lib"; AC_SUBST(BOOST_SYSTEM_LIB) link_system="yes"; break],
[link_system="no"])
done
if test "x$link_system" != "xyes"; then
for libextension in `ls -r $BOOSTLIBDIR/boost_system* 2>/dev/null | sed 's,.*/,,' | sed -e 's,\..*,,'` ; do
[link_system="no"])
done
fi
else
for ax_lib in $ax_boost_user_system_lib boost_system-$ax_boost_user_system_lib; do
[link_system="no"])
done
fi
fi
if test "x$link_system" = "xno"; then
fi
fi
fi
lib_LTLIBRARIES += src/libcodes.la src/libcodes_mpi_replay.la lib_LTLIBRARIES += src/libcodes.la src/libcodes_mpi_replay.la
AM_CPPFLAGS += $(BOOST_CPPFLAGS)
AM_LDFLAGS += $(BOOST_LDFLAGS)
BUILT_SOURCES += src/modelconfig/configparser.h \ BUILT_SOURCES += src/modelconfig/configparser.h \
src/modelconfig/configlex.h src/modelconfig/configlex.h
Markdown is supported
0% or
Please register or to comment
