Commit 6c9d8667 authored by Philip Carns's avatar Philip Carns
added section on workload generator
parent 24c1e02f
...@@ -317,6 +317,16 @@ file per LP. ...@@ -317,6 +317,16 @@ file per LP.
TODO: look at ross/IO code and determine how it relates to this. TODO: look at ross/IO code and determine how it relates to this.
\subsection{codes-workload generator}
TODO: fill this in. codes-workload is an abstraction layer for feeding I/O
workloads into a simulation. It supports multiple back-ends for generating
those I/O events; data could come from a trace file, from Darshan, or from a
synthetic description.
This component is under active development right now, not complete yet. The
synthetic generator is probably pretty solid for use already though.
\subsection{codes\_event\_new} \subsection{codes\_event\_new}
TODO: fill this in. codes\_event\_new is a small wrapper to tw\_event\_new TODO: fill this in. codes\_event\_new is a small wrapper to tw\_event\_new
Markdown is supported
0% or
Please register or to comment
