Commit 69f49064 authored by Misbah Mubarak's avatar Misbah Mubarak
Adding statistics recording for mpi_allreduce, turning off the debug option
parent 346be3da
...@@ -36,8 +36,9 @@ static int msg_size_hash_compare( ...@@ -36,8 +36,9 @@ static int msg_size_hash_compare(
void *key, struct qhash_head *link); void *key, struct qhash_head *link);
/* NOTE: Message tracking works in sequential mode only! */ /* NOTE: Message tracking works in sequential mode only! */
int debug_cols = 0;
int enable_msg_tracking = 0; int enable_msg_tracking = 0;
tw_lpid TRACK_LP = 0; tw_lpid TRACK_LP = -1;
int unmatched = 0; int unmatched = 0;
char workload_type[128]; char workload_type[128];
...@@ -215,6 +216,15 @@ struct nw_state ...@@ -215,6 +216,15 @@ struct nw_state
/* time spent by the LP in executing the app trace*/ /* time spent by the LP in executing the app trace*/
double start_time; double start_time;
double col_time;
double reduce_time;
int num_reduce;
double all_reduce_time;
int num_all_reduce;
double elapsed_time; double elapsed_time;
/* time spent in compute operations */ /* time spent in compute operations */
double compute_time; double compute_time;
...@@ -232,7 +242,7 @@ struct nw_state ...@@ -232,7 +242,7 @@ struct nw_state
struct qlist_head completed_reqs; struct qlist_head completed_reqs;
tw_stime cur_interval_end; tw_stime cur_interval_end;
/* Pending wait operation */ /* Pending wait operation */
struct pending_waits * wait_op; struct pending_waits * wait_op;
...@@ -1397,9 +1407,14 @@ static void codes_exec_mpi_send(nw_state* s, ...@@ -1397,9 +1407,14 @@ static void codes_exec_mpi_send(nw_state* s,
/* convert seconds to ns */ /* convert seconds to ns */
static tw_stime s_to_ns(tw_stime ns) static tw_stime s_to_ns(tw_stime s)
return(s * (1000.0 * 1000.0 * 1000.0));
static tw_stime ns_to_s(tw_stime ns)
return(ns * (1000.0 * 1000.0 * 1000.0)); return(ns / (1000.0 * 1000.0 * 1000.0));
static void update_completed_queue_rc(nw_state * s, tw_bf * bf, nw_message * m, tw_lp * lp) static void update_completed_queue_rc(nw_state * s, tw_bf * bf, nw_message * m, tw_lp * lp)
...@@ -1658,6 +1673,10 @@ void nw_test_init(nw_state* s, tw_lp* lp) ...@@ -1658,6 +1673,10 @@ void nw_test_init(nw_state* s, tw_lp* lp)
s->sampling_indx = 0; s->sampling_indx = 0;
s->is_finished = 0; s->is_finished = 0;
s->cur_interval_end = 0; s->cur_interval_end = 0;
s->col_time = 0;
s->num_reduce = 0;
s->reduce_time = 0;
s->all_reduce_time = 0;
if(!num_net_traces) if(!num_net_traces)
num_net_traces = num_mpi_lps; num_net_traces = num_mpi_lps;
...@@ -1925,13 +1944,27 @@ static void get_next_mpi_operation_rc(nw_state* s, tw_bf * bf, nw_message * m, t ...@@ -1925,13 +1944,27 @@ static void get_next_mpi_operation_rc(nw_state* s, tw_bf * bf, nw_message * m, t
break; break;
case CODES_WK_ALLREDUCE:
if(bf->c1)
s->num_all_reduce--;
s->col_time = m->rc.saved_send_time;
s->all_reduce_time -= s->col_time;
else
s->col_time = 0;
codes_issue_next_event_rc(lp);
break;
case CODES_WK_BCAST: case CODES_WK_BCAST:
case CODES_WK_ALLGATHER: case CODES_WK_ALLGATHER:
case CODES_WK_ALLGATHERV: case CODES_WK_ALLGATHERV:
case CODES_WK_ALLTOALL: case CODES_WK_ALLTOALL:
case CODES_WK_ALLTOALLV: case CODES_WK_ALLTOALLV:
case CODES_WK_REDUCE: case CODES_WK_REDUCE:
case CODES_WK_COL: case CODES_WK_COL:
s->num_cols--; s->num_cols--;
...@@ -2053,16 +2086,34 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l ...@@ -2053,16 +2086,34 @@ static void get_next_mpi_operation(nw_state* s, tw_bf * bf, nw_message * m, tw_l
codes_exec_mpi_wait(s, bf, lp, &mpi_op); codes_exec_mpi_wait(s, bf, lp, &mpi_op);
break; break;
s->num_cols++;
if(s->col_time > 0)
bf->c1 = 1;
m->rc.saved_delay = s->all_reduce_time;
s->all_reduce_time += (tw_now(lp) - s->col_time);
m->rc.saved_send_time = s->col_time;
s->col_time = 0;
s->num_all_reduce++;
else
s->col_time = tw_now(lp);
codes_issue_next_event(lp);
break;
//printf("\n MPI COL ");
s->num_cols++; s->num_cols++;
codes_issue_next_event(lp); codes_issue_next_event(lp);
...@@ -2159,7 +2210,10 @@ void nw_test_finalize(nw_state* s, tw_lp* lp) ...@@ -2159,7 +2210,10 @@ void nw_test_finalize(nw_state* s, tw_lp* lp)
if(s->recv_time > max_recv_time) if(s->recv_time > max_recv_time)
max_recv_time = s->recv_time; max_recv_time = s->recv_time;
avg_time += s->elapsed_time; if(debug_cols)
printf("\n Rank %lld Avg all reduce time %lf ", s->nw_id, ns_to_s(s->all_reduce_time / s->num_all_reduce));
avg_comm_time += (s->elapsed_time - s->compute_time); avg_comm_time += (s->elapsed_time - s->compute_time);
avg_wait_time += s->wait_time; avg_wait_time += s->wait_time;
avg_send_time += s->send_time; avg_send_time += s->send_time;
Markdown is supported
0% or
Please register or to comment
