GitLab maintenance scheduled for Today, 2019-04-24, from 12:00 to 13:00 CDT - Services will be unavailable during this time.
Commit 69292f03 authored by Caitlin Ross's avatar Caitlin Ross
fix RNG reverse bug in model-net.c
parent a3f129b4
......@@ -271,12 +271,12 @@ static model_net_event_return model_net_noop_event(
model_net_event_return num_rng_calls = 0;
tw_stime poffset = mn_in_sequence ? mn_msg_offset : 0.0;
tw_stime delay = codes_local_latency(sender);
num_rng_calls++; // rng call is in codes_local_latency
tw_stime sendTime = message_size * codes_cn_delay;
if (self_event_size && self_event != NULL) {
poffset += delay;
num_rng_calls++;
tw_event *e = tw_event_new(sender->gid, poffset+offset+sendTime, sender);
memcpy(tw_event_data(e), self_event, self_event_size);
tw_event_send(e);
......@@ -284,7 +284,6 @@ static model_net_event_return model_net_noop_event(
if (remote_event_size && remote_event != NULL) {
poffset += delay;
num_rng_calls++;
/* special case - in a "pull" event, the "remote" message is actually
* to self */
tw_event *e = tw_event_new(is_pull ? sender->gid : final_dest_lp,
Markdown is supported
0% or
Please register or to comment
