Commit 5f8039a1 authored by Jonathan Jenkins's avatar Jonathan Jenkins
tweak to configurator log output
parent e3022cb7
...@@ -78,10 +78,7 @@ def main(): ...@@ -78,10 +78,7 @@ def main():
# print the configuration to the log # print the configuration to the log
flog.write(str(ct)) flog.write(str(ct))
for l in labels: for l in labels:
if isinstance(replace_map[l], str): flog.write(' ' + str(replace_map[l]))
flog.write(' "' + replace_map[l] + '"')
else:
flog.write(" " + str(replace_map[l]))
else: else:
flog.write('\n') flog.write('\n')
Markdown is supported
0%
or
Please register or to comment
