Commit 5f62907b authored by Neil McGlohon's avatar Neil McGlohon
Add Dragonfly Custom Print Config
parent c1e1e761
...@@ -26,6 +26,7 @@ ...@@ -26,6 +26,7 @@
#endif #endif
#define DUMP_CONNECTIONS 0 #define DUMP_CONNECTIONS 0
#define PRINT_CONFIG 1
#define CREDIT_SIZE 8 #define CREDIT_SIZE 8
#define DFLY_HASH_TABLE_SIZE 4999 #define DFLY_HASH_TABLE_SIZE 4999
// debugging parameters // debugging parameters
...@@ -179,6 +180,9 @@ struct dragonfly_param ...@@ -179,6 +180,9 @@ struct dragonfly_param
double router_delay; double router_delay;
static const dragonfly_param* stored_params;
struct dfly_hash_key struct dfly_hash_key
uint64_t message_id; uint64_t message_id;
...@@ -499,6 +503,42 @@ static terminal_custom_message_list* return_tail( ...@@ -499,6 +503,42 @@ static terminal_custom_message_list* return_tail(
return tail; return tail;
void dragonfly_print_params(const dragonfly_param *p)
int myRank;
MPI_Comm_rank(MPI_COMM_CODES, &myRank);
if (!myRank) {
printf("\n------------------ Dragonfly Custom Parameters ---------\n");
printf("\tnum_routers = %d\n",p->num_routers);
printf("\tlocal_bandwidth = %.2f\n",p->local_bandwidth);
printf("\tglobal_bandwidth = %.2f\n",p->global_bandwidth);
printf("\tcn_bandwidth = %.2f\n",p->cn_bandwidth);
printf("\tnum_vcs = %d\n",p->num_vcs);
printf("\tlocal_vc_size = %d\n",p->local_vc_size);
printf("\tglobal_vc_size = %d\n",p->global_vc_size);
printf("\tcn_vc_size = %d\n",p->cn_vc_size);
printf("\tchunk_size = %d\n",p->chunk_size);
printf("\tnum_cn = %d\n",p->num_cn);
printf("\tintra_grp_radix = %d\n",p->intra_grp_radix);
printf("\tnum_col_chans = %d\n",p->num_col_chans);
printf("\tnum_row_chans = %d\n",p->num_row_chans);
printf("\tnum_router_rows = %d\n",p->num_router_rows);
printf("\tnum_router_cols = %d\n",p->num_router_cols);
printf("\tnum_groups = %d\n",p->num_groups);
printf("\tradix = %d\n",p->radix);
printf("\ttotal_routers = %d\n",p->total_routers);
printf("\ttotal_terminals = %d\n",p->total_terminals);
printf("\tnum_global_channels = %d\n",p->num_global_channels);
printf("\tcn_delay = %.2f\n",p->cn_delay);
printf("\tlocal_delay = %.2f\n",p->local_delay);
printf("\tglobal_delay = %.2f\n",p->global_delay);
printf("\tcredit_delay = %.2f\n",p->credit_delay);
printf("\trouter_delay = %.2f\n",p->router_delay);
printf("\trouting = %d\n",routing);
printf("------------------------------------------------------\n\n");
static void dragonfly_read_config(const char * anno, dragonfly_param *params){ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
/*Adding init for router magic number*/ /*Adding init for router magic number*/
uint32_t h1 = 0, h2 = 0; uint32_t h1 = 0, h2 = 0;
...@@ -815,6 +855,11 @@ else ...@@ -815,6 +855,11 @@ else
p->local_delay = bytes_to_ns(p->chunk_size, p->local_bandwidth); p->local_delay = bytes_to_ns(p->chunk_size, p->local_bandwidth);
p->global_delay = bytes_to_ns(p->chunk_size, p->global_bandwidth); p->global_delay = bytes_to_ns(p->chunk_size, p->global_bandwidth);
p->credit_delay = bytes_to_ns(CREDIT_SIZE, p->local_bandwidth); //assume 8 bytes packet p->credit_delay = bytes_to_ns(CREDIT_SIZE, p->local_bandwidth); //assume 8 bytes packet
if (PRINT_CONFIG)
dragonfly_print_params(p);
stored_params = p;
void dragonfly_custom_configure(){ void dragonfly_custom_configure(){
...@@ -867,6 +912,9 @@ void dragonfly_custom_report_stats() ...@@ -867,6 +912,9 @@ void dragonfly_custom_report_stats()
/* print statistics */ /* print statistics */
if(!g_tw_mynode) if(!g_tw_mynode)
if (PRINT_CONFIG)
dragonfly_print_params(stored_params);
printf(" Average number of hops traversed %f average chunk latency %lf us maximum chunk latency %lf us avg message size %lf bytes finished messages %lld finished chunks %lld \n", printf(" Average number of hops traversed %f average chunk latency %lf us maximum chunk latency %lf us avg message size %lf bytes finished messages %lld finished chunks %lld \n",
(float)avg_hops/total_finished_chunks, avg_time/(total_finished_chunks*1000), max_time/1000, (float)final_msg_sz/total_finished_msgs, total_finished_msgs, total_finished_chunks); (float)avg_hops/total_finished_chunks, avg_time/(total_finished_chunks*1000), max_time/1000, (float)final_msg_sz/total_finished_msgs, total_finished_msgs, total_finished_chunks);
if(routing == ADAPTIVE || routing == PROG_ADAPTIVE || SHOW_ADAP_STATS) if(routing == ADAPTIVE || routing == PROG_ADAPTIVE || SHOW_ADAP_STATS)
...@@ -2251,6 +2299,13 @@ void dragonfly_custom_router_final(router_state * s, ...@@ -2251,6 +2299,13 @@ void dragonfly_custom_router_final(router_state * s,
written += sprintf(s->output_buf2 + written, " %lld", LLD(s->link_traffic[d])); written += sprintf(s->output_buf2 + written, " %lld", LLD(s->link_traffic[d]));
lp_io_write(lp->gid, (char*)"dragonfly-router-traffic", written, s->output_buf2); lp_io_write(lp->gid, (char*)"dragonfly-router-traffic", written, s->output_buf2);
if (!g_tw_mynode) {
if (s->router_id == 0) {
if (PRINT_CONFIG)
dragonfly_print_params(s->params);
static vector<int> get_intra_router(router_state * s, int src_router_id, int dest_router_id, int num_rtrs_per_grp) static vector<int> get_intra_router(router_state * s, int src_router_id, int dest_router_id, int num_rtrs_per_grp)
Markdown is supported
0% or
Please register or to comment
