Commit 5c665766 authored by Neil McGlohon's avatar Neil McGlohon
Dragonfly+ debugging and verification checks
parent 0a40bbf9
...@@ -33,14 +33,14 @@ ...@@ -33,14 +33,14 @@
#define DUMP_CONNECTIONS 0 #define DUMP_CONNECTIONS 0
#define PRINT_CONFIG 1 #define PRINT_CONFIG 1
#define T_ID -1 #define T_ID 1
#define CREDIT_SIZE 8 #define CREDIT_SIZE 8
#define DFLY_HASH_TABLE_SIZE 40000 #define DFLY_HASH_TABLE_SIZE 40000
#define SHOW_ADAPTIVE_STATS 1 #define SHOW_ADAPTIVE_STATS 1
// debugging parameters // debugging parameters
#define TRACK -1 #define TRACK -1
#define TRACK_PKT -1 #define TRACK_PKT 0
#define TRACK_MSG -1 #define TRACK_MSG -1
#define DEBUG 0 #define DEBUG 0
#define MAX_STATS 65536 #define MAX_STATS 65536
...@@ -1383,6 +1383,7 @@ static void packet_generate_rc(terminal_state *s, tw_bf *bf, terminal_plus_messa ...@@ -1383,6 +1383,7 @@ static void packet_generate_rc(terminal_state *s, tw_bf *bf, terminal_plus_messa
s->packet_gen--; s->packet_gen--;
packet_gen--; packet_gen--;
s->packet_counter--;
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
...@@ -1449,7 +1450,9 @@ static void packet_generate(terminal_state *s, tw_bf *bf, terminal_plus_message ...@@ -1449,7 +1450,9 @@ static void packet_generate(terminal_state *s, tw_bf *bf, terminal_plus_message
nic_ts = g_tw_lookahead + (num_chunks * cn_delay) + tw_rand_unif(lp->rng); nic_ts = g_tw_lookahead + (num_chunks * cn_delay) + tw_rand_unif(lp->rng);
msg->packet_ID = lp->gid + g_tw_nlp * s->packet_counter; // msg->packet_ID = lp->gid + g_tw_nlp * s->packet_counter;
msg->packet_ID = s->packet_counter;
s->packet_counter++;
msg->my_N_hop = 0; msg->my_N_hop = 0;
msg->my_l_hop = 0; msg->my_l_hop = 0;
msg->my_g_hop = 0; msg->my_g_hop = 0;
...@@ -1543,7 +1546,7 @@ static void packet_send_rc(terminal_state *s, tw_bf *bf, terminal_plus_message * ...@@ -1543,7 +1546,7 @@ static void packet_send_rc(terminal_state *s, tw_bf *bf, terminal_plus_message *
s->terminal_length += s->params->chunk_size; s->terminal_length += s->params->chunk_size;
s->packet_counter--; // s->packet_counter--;
s->vc_occupancy[0] -= s->params->chunk_size; s->vc_occupancy[0] -= s->params->chunk_size;
terminal_plus_message_list *cur_entry = (terminal_plus_message_list *) rc_stack_pop(s->st); terminal_plus_message_list *cur_entry = (terminal_plus_message_list *) rc_stack_pop(s->st);
...@@ -1640,7 +1643,7 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg ...@@ -1640,7 +1643,7 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg
memcpy(m_new, local_event, cur_entry->msg.local_event_size_bytes); memcpy(m_new, local_event, cur_entry->msg.local_event_size_bytes);
tw_event_send(e_new); tw_event_send(e_new);
s->packet_counter++; // s->packet_counter++;
s->vc_occupancy[0] += s->params->chunk_size; s->vc_occupancy[0] += s->params->chunk_size;
cur_entry = return_head(s->terminal_msgs, s->terminal_msgs_tail, 0); cur_entry = return_head(s->terminal_msgs, s->terminal_msgs_tail, 0);
rc_stack_push(lp, cur_entry, delete_terminal_plus_message_list, s->st); rc_stack_push(lp, cur_entry, delete_terminal_plus_message_list, s->st);
...@@ -3033,13 +3036,24 @@ static Connection do_dfp_routing(router_state *s, ...@@ -3033,13 +3036,24 @@ static Connection do_dfp_routing(router_state *s,
if (route_to_fdest) { if (route_to_fdest) {
vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id); vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id);
if (poss_next_stops.size() < 1)
tw_error(TW_LOC, "Dead end when finding stops to fdest router");
Connection best_min_conn = get_best_connection_from_conns(s, bf, msg, lp, poss_next_stops); Connection best_min_conn = get_best_connection_from_conns(s, bf, msg, lp, poss_next_stops);
if (best_min_conn.port == -1)
tw_error(TW_LOC, "Get best connection returned a bad connection");
return best_min_conn; return best_min_conn;
else { //then we need to be going toward the intermediate router else { //then we need to be going toward the intermediate router
msg->path_type = NON_MINIMAL; msg->path_type = NON_MINIMAL;
vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, msg->intm_rtr_id); vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, msg->intm_rtr_id);
tw_error(TW_LOC, "Dead end when finding stops to intermediate router");
Connection best_intm_conn = get_best_connection_from_conns(s, bf, msg, lp, poss_next_stops); Connection best_intm_conn = get_best_connection_from_conns(s, bf, msg, lp, poss_next_stops);
if (best_intm_conn.port == -1)
return best_intm_conn; return best_intm_conn;
...@@ -3197,6 +3211,10 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -3197,6 +3211,10 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
Connection next_stop_conn = do_dfp_routing(s, bf, &(cur_chunk->msg), lp, dest_router_id); Connection next_stop_conn = do_dfp_routing(s, bf, &(cur_chunk->msg), lp, dest_router_id);
if (s->connMan->is_any_connection_to(next_stop_conn.dest_gid) == false)
tw_error(TW_LOC, "Router does not have a connection to chosen destination\n");
output_port = next_stop_conn.port; output_port = next_stop_conn.port;
if (next_stop_conn.conn_type != CONN_TERMINAL) { if (next_stop_conn.conn_type != CONN_TERMINAL) {
...@@ -3216,12 +3234,14 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -3216,12 +3234,14 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
cur_chunk->msg.next_stop = next_stop; cur_chunk->msg.next_stop = next_stop;
output_chan = 0; output_chan = 0;
if(cur_chunk->msg.dfp_upward_channel_flag) { if(cur_chunk->msg.dfp_upward_channel_flag == 1) {
output_chan = 1; output_chan = 1;
else { else if (cur_chunk->msg.dfp_upward_channel_flag == 0) {
else
tw_error(TW_LOC, "upward channel flag has invalid value\n");
ConnectionType port_type = s->connMan->get_port_type(output_port); ConnectionType port_type = s->connMan->get_port_type(output_port);
int max_vc_size = 0; int max_vc_size = 0;
Markdown is supported
0% or
Please register or to comment
