Commit 5612eb11 authored by Nikhil's avatar Nikhil Committed by Misbah Mubarak
Change NIC seq delay default to a low value
Change-Id: I07a70c6bc91e89634997998cf4ff07f74af67b53
parent 812b9a30
...@@ -246,7 +246,7 @@ static void base_read_config(const char * anno, model_net_base_params *p){ ...@@ -246,7 +246,7 @@ static void base_read_config(const char * anno, model_net_base_params *p){
"setting to %d\n", p->num_queues); "setting to %d\n", p->num_queues);
p->nic_seq_delay = 200; p->nic_seq_delay = 10;
ret = configuration_get_value_double(&config, "PARAMS", "nic_seq_delay", anno, ret = configuration_get_value_double(&config, "PARAMS", "nic_seq_delay", anno,
&p->nic_seq_delay); &p->nic_seq_delay);
if(ret && !g_tw_mynode) { if(ret && !g_tw_mynode) {
Markdown is supported
0% or
Please register or to comment
