Commit 524b726e authored by Jonathan Jenkins's avatar Jonathan Jenkins
configurator - support for derived parameter
parent e0c15cb2
...@@ -13,13 +13,6 @@ def main(): ...@@ -13,13 +13,6 @@ def main():
# load the module # load the module
mod = conf.import_from(args.substitute_py) mod = conf.import_from(args.substitute_py)
# checks - make sure cfields is set and is the correct type
conf.check_cfields(mod)
# check that pairs are actually pairs
if len(args.token_pairs) % 2 != 0:
raise ValueError("token pairs must come in twos")
# intitialize the configuration object # intitialize the configuration object
cfg = conf.configurator(mod, args.token_pairs) cfg = conf.configurator(mod, args.token_pairs)
...@@ -44,6 +37,18 @@ def main(): ...@@ -44,6 +37,18 @@ def main():
flog.close() flog.close()
sub_help = \
'python file defining "cfields" variable consisting of a sequence of <name, ' \
'value sequence> pairs. The following variables may optionally appear. ' \
'"exceptions" - a sequence of dictionaries. Each configuration generated by ' \
'"cfields" is checked against each dictionary in "exceptions"; if each value ' \
'in the dict matches that of the configuration, then that configuration is ' \
'skipped. "cfields_derived_labels", "cfields_derived" - the former is a ' \
'sequence of strings identifying replace tokens that will be dynamically set ' \
'based on the input configuration generated by cfields. The latter is a ' \
'function that adds all <name,value> pairs for names in ' \
'"cfields_derived_labels".'
def parse_args(): def parse_args():
parser = argparse.ArgumentParser(\ parser = argparse.ArgumentParser(\
description="generate set of configuration files based on template " description="generate set of configuration files based on template "
...@@ -51,13 +56,7 @@ def parse_args(): ...@@ -51,13 +56,7 @@ def parse_args():
parser.add_argument("template", parser.add_argument("template",
help="template file with replace tokens") help="template file with replace tokens")
parser.add_argument("substitute_py", parser.add_argument("substitute_py",
help='python file defining "cfields" variable consisting of ' help=sub_help)
'elements of the form '
'( replacement_token, [replacements...]). An optional '
'variable "exceptions" may also be provided, of the form '
'( {replace_token : replacement, ...}, ...). This will '
'exclude any configuration that exhibits the key/value '
'pairs in any of the input dictionaries')
parser.add_argument("token_pairs", nargs='*', parser.add_argument("token_pairs", nargs='*',
help="a list of whitespace-separated token, replace pairs for " help="a list of whitespace-separated token, replace pairs for "
"command-line-driven replacement (useful in shell scripts " "command-line-driven replacement (useful in shell scripts "
...@@ -9,6 +9,12 @@ class configurator: ...@@ -9,6 +9,12 @@ class configurator:
# note: object assumes input has been validated by caller, though it will # note: object assumes input has been validated by caller, though it will
# still throw if it finds duplicate keys in the dict # still throw if it finds duplicate keys in the dict
def __init__(self, module, replace_pairs): def __init__(self, module, replace_pairs):
# checks - check cfields and friends
check_cfields(module)
if len(replace_pairs) % 2 != 0:
self.mod = module self.mod = module
self.num_fields = len(self.mod.cfields) self.num_fields = len(self.mod.cfields)
self.labels = [k[0] for k in self.mod.cfields] + replace_pairs[0::2] self.labels = [k[0] for k in self.mod.cfields] + replace_pairs[0::2]
...@@ -16,6 +22,8 @@ class configurator: ...@@ -16,6 +22,8 @@ class configurator:
self.start_iter = False self.start_iter = False
self.in_iter = False self.in_iter = False
self.has_except = "excepts" in self.mod.__dict__ self.has_except = "excepts" in self.mod.__dict__
self.has_derived = "cfields_derived_labels" in self.mod.__dict__ and \
"cfields_derived" in self.mod.__dict__
for i in range(0, len(replace_pairs), 2): for i in range(0, len(replace_pairs), 2):
k,vstr = replace_pairs[i], replace_pairs[i+1] k,vstr = replace_pairs[i], replace_pairs[i+1]
...@@ -28,9 +36,13 @@ class configurator: ...@@ -28,9 +36,13 @@ class configurator:
if v == None: if v == None:
v = vstr v = vstr
self.replace_map[k] = v self.replace_map[k] = v
# initialize derived labels if necessary
if self.has_derived:
self.labels += [l for l in self.mod.cfields_derived_labels]
def __iter__(self): def __iter__(self):
# pre-generate an initial config and return self
self.start_iter = True self.start_iter = True
self.in_iter = True self.in_iter = True
return self return self
...@@ -40,15 +52,11 @@ class configurator: ...@@ -40,15 +52,11 @@ class configurator:
raise StopIteration raise StopIteration
elif self.start_iter: elif self.start_iter:
# first iteration - initialize the iterators # first iteration - initialize the iterators
self.iterables = [k[1].__iter__() for k in self.mod.cfields] self.iterables = [k[1].__iter__() for k in self.mod.cfields]
for i in range(0, self.num_fields): for i in range(0, self.num_fields):
v = self.iterables[i].next() v = self.iterables[i].next()
self.replace_map[self.labels[i]] = v self.replace_map[self.labels[i]] = v
# check if this is a valid config, if not, then recurse
if self.has_except and is_replace_except(self.mod.excepts,
self.replace_map):
return self.next()
else: else:
# > first iteration, perform the updates # > first iteration, perform the updates
# generate the next config # generate the next config
...@@ -66,6 +74,10 @@ class configurator: ...@@ -66,6 +74,10 @@ class configurator:
else: else:
# last iterable has finished, have generated full set # last iterable has finished, have generated full set
# add derived fields before exceptions
self.mod.cfields_derived(self.replace_map)
if self.has_except and is_replace_except(self.mod.excepts, if self.has_except and is_replace_except(self.mod.excepts,
self.replace_map): self.replace_map):
return self.next() return self.next()
...@@ -110,6 +122,21 @@ def check_cfields(module): ...@@ -110,6 +122,21 @@ def check_cfields(module):
isinstance(module.excepts[0], dict)) : isinstance(module.excepts[0], dict)) :
raise TypeError("excepts not in correct format, see usage") raise TypeError("excepts not in correct format, see usage")
dl = "cfields_derived_labels" in module.__dict__
d = "cfields_derived" in module.__dict__
if (dl and not d) or (not dl and d):
raise TypeError("both cfields_derived_labels and cfields_derived must "
"be set")
elif dl and d and not \
(isinstance(module.cfields_derived_labels, Sequence) and \
isinstance(module.cfields_derived_labels[0], str) and \
hasattr(module.cfields_derived, "__call__")):
raise TypeError("cfields_derived_labels must be a sequence of "
"strings, cfields_derived must be callable (accepting a "
"dict of replace_token, replacement pairs and adding pairs "
"for each label in cfields_derived_labels")
# import a python file (assumes there is a .py suffix!!!) # import a python file (assumes there is a .py suffix!!!)
def import_from(filename): def import_from(filename):
...@@ -29,7 +29,7 @@ PARAMS ...@@ -29,7 +29,7 @@ PARAMS
# - individual packet sizes for network operations # - individual packet sizes for network operations
# (each "packet" is represented by an event) # (each "packet" is represented by an event)
# - independent of underlying network being used # - independent of underlying network being used
packet_size="512"; packet_size="C_PACKET_SZ";
# - type of model to use (must match with corresponding LPGROUPS entry) # - type of model to use (must match with corresponding LPGROUPS entry)
modelnet="simplenet"; modelnet="simplenet";
# - model-specific parameters # - model-specific parameters
...@@ -2,4 +2,10 @@ cfields = ( ("C_NUM_SERVERS", [1<<i for i in range(1,3)]), ...@@ -2,4 +2,10 @@ cfields = ( ("C_NUM_SERVERS", [1<<i for i in range(1,3)]),
("C_NUM_REQS", [1,2]), ("C_NUM_REQS", [1,2]),
("C_PAYLOAD_SZ", [1024*i for i in range(1,3)]) ) ("C_PAYLOAD_SZ", [1024*i for i in range(1,3)]) )
# example derived paramter - make the packet size 1/4 of the payload size
cfields_derived_labels = ( "C_PACKET_SZ", )
def cfields_derived(replace_map):
replace_map["C_PACKET_SZ"] = replace_map["C_PAYLOAD_SZ"] / 4
# example exception - don't generate configs with these sets of params
excepts = ( {"C_NUM_SERVERS" : 4, "C_PAYLOAD_SZ" : 1024}, ) excepts = ( {"C_NUM_SERVERS" : 4, "C_PAYLOAD_SZ" : 1024}, )
Markdown is supported
0% or
Please register or to comment
