Commit 51ea02b0 authored by Shane Snyder's avatar Shane Snyder
Add delay capability to recorder workloads
parent f5e5c65e
...@@ -20,13 +20,14 @@ ...@@ -20,13 +20,14 @@
#include "codes-workload-method.h" #include "codes-workload-method.h"
#include "codes/quickhash.h" #include "codes/quickhash.h"
#define RECORDER_MAX_TRACE_READ_COUNT 1024 #define RECORDER_NEGLIGIBLE_DELAY .00001
#define RANK_HASH_TABLE_SIZE 397 #define RANK_HASH_TABLE_SIZE 397
struct recorder_io_op struct recorder_io_op
double start_time; double start_time;
double end_time;
struct codes_workload_op codes_op; struct codes_workload_op codes_op;
...@@ -34,11 +35,13 @@ struct recorder_io_op ...@@ -34,11 +35,13 @@ struct recorder_io_op
struct rank_traces_context struct rank_traces_context
int rank; int rank;
struct qhash_head hash_link; double last_op_time;
struct recorder_io_op trace_ops[1024]; /* TODO: this should be extendable */ struct recorder_io_op trace_ops[2048]; /* TODO: this should be extendable */
int trace_list_ndx; int trace_list_ndx;
int trace_list_max; int trace_list_max;
...@@ -65,7 +68,7 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -65,7 +68,7 @@ static int recorder_io_workload_load(const char *params, int rank)
recorder_params *r_params = (recorder_params *) params; recorder_params *r_params = (recorder_params *) params;
int64_t nprocs = 0; int64_t nprocs = 16384;
struct rank_traces_context *new = NULL; struct rank_traces_context *new = NULL;
char *trace_dir = r_params->trace_dir_path; char *trace_dir = r_params->trace_dir_path;
...@@ -81,6 +84,7 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -81,6 +84,7 @@ static int recorder_io_workload_load(const char *params, int rank)
new->trace_list_ndx = 0; new->trace_list_ndx = 0;
new->trace_list_max = 0; new->trace_list_max = 0;
#if 0
DIR *dirp; DIR *dirp;
struct dirent *entry; struct dirent *entry;
dirp = opendir(trace_dir); dirp = opendir(trace_dir);
...@@ -89,6 +93,7 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -89,6 +93,7 @@ static int recorder_io_workload_load(const char *params, int rank)
nprocs++; nprocs++;
closedir(dirp); closedir(dirp);
#endif
char trace_file_name[1024] = {'\0'}; char trace_file_name[1024] = {'\0'};
sprintf(trace_file_name, "%s/log.%d", trace_dir, rank); sprintf(trace_file_name, "%s/log.%d", trace_dir, rank);
...@@ -97,21 +102,17 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -97,21 +102,17 @@ static int recorder_io_workload_load(const char *params, int rank)
if(trace_file == NULL) if(trace_file == NULL)
return -1; return -1;
double start_time;
char function_name[128] = {'\0'};
/* Read the first chunk of data (of size RECORDER_MAX_TRACE_READ_COUNT) */
char *line = NULL; char *line = NULL;
size_t len; size_t len;
ssize_t ret_value; ssize_t ret_value;
while((ret_value = getline(&line, &len, trace_file)) != -1) { while((ret_value = getline(&line, &len, trace_file)) != -1) {
struct recorder_io_op r_op; struct recorder_io_op r_op;
char *token = strtok(line, ", "); char *token = strtok(line, ", ");
start_time = atof(token); r_op.start_time = atof(token);
token = strtok(NULL, ", "); token = strtok(NULL, ", ");
strcpy(function_name, token); strcpy(function_name, token);
r_op.start_time = start_time;
if(!strcmp(function_name, "open") || !strcmp(function_name, "open64")) { if(!strcmp(function_name, "open") || !strcmp(function_name, "open64")) {
r_op.codes_op.op_type = CODES_WK_OPEN; r_op.codes_op.op_type = CODES_WK_OPEN;
...@@ -122,12 +123,17 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -122,12 +123,17 @@ static int recorder_io_workload_load(const char *params, int rank)
token = strtok(NULL, ", )"); token = strtok(NULL, ", )");
r_op.codes_op.u.open.file_id = atoi(token); r_op.codes_op.u.open.file_id = atoi(token);
token = strtok(NULL, ", \n");
else if(!strcmp(function_name, "close")) { else if(!strcmp(function_name, "close")) {
r_op.codes_op.op_type = CODES_WK_CLOSE; r_op.codes_op.op_type = CODES_WK_CLOSE;
token = strtok(NULL, ", ()"); token = strtok(NULL, ", ()");
r_op.codes_op.u.close.file_id = atoi(token); r_op.codes_op.u.close.file_id = atoi(token);
else if(!strcmp(function_name, "read") || !strcmp(function_name, "read64")) { else if(!strcmp(function_name, "read") || !strcmp(function_name, "read64")) {
r_op.codes_op.op_type = CODES_WK_READ; r_op.codes_op.op_type = CODES_WK_READ;
...@@ -143,6 +149,9 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -143,6 +149,9 @@ static int recorder_io_workload_load(const char *params, int rank)
r_op.codes_op.u.read.offset = atol(token); r_op.codes_op.u.read.offset = atol(token);
else if(!strcmp(function_name, "write") || !strcmp(function_name, "write64")) { else if(!strcmp(function_name, "write") || !strcmp(function_name, "write64")) {
r_op.codes_op.op_type = CODES_WK_WRITE; r_op.codes_op.op_type = CODES_WK_WRITE;
...@@ -158,19 +167,29 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -158,19 +167,29 @@ static int recorder_io_workload_load(const char *params, int rank)
r_op.codes_op.u.write.offset = atol(token); r_op.codes_op.u.write.offset = atol(token);
else if(!strcmp(function_name, "MPI_Barrier")) { else if(!strcmp(function_name, "MPI_Barrier")) {
char *tmp;
r_op.codes_op.op_type = CODES_WK_BARRIER; r_op.codes_op.op_type = CODES_WK_BARRIER;
r_op.codes_op.u.barrier.count = nprocs; r_op.codes_op.u.barrier.count = nprocs;
r_op.codes_op.u.barrier.root = 0; r_op.codes_op.u.barrier.root = 0;
tmp = strtok(NULL, ", \n");
if (tmp) token = tmp;
else{ else{
continue; continue;
r_op.end_time = r_op.start_time + atof(token);
new->trace_ops[new->trace_list_ndx++] = r_op; new->trace_ops[new->trace_list_ndx++] = r_op;
if (new->trace_list_ndx == 1024) break; if (new->trace_list_ndx == 2048) break;
fclose(trace_file); fclose(trace_file);
...@@ -179,6 +198,9 @@ static int recorder_io_workload_load(const char *params, int rank) ...@@ -179,6 +198,9 @@ static int recorder_io_workload_load(const char *params, int rank)
/* now we can read all events by counting through array from 0 - max */ /* now we can read all events by counting through array from 0 - max */
new->trace_list_max = new->trace_list_ndx; new->trace_list_max = new->trace_list_ndx;
if (new->trace_list_max > 0) {
new->last_op_time = new->trace_ops[0].start_time;
/* initialize the hash table of rank contexts, if it has not been initialized */ /* initialize the hash table of rank contexts, if it has not been initialized */
if (!rank_tbl) { if (!rank_tbl) {
...@@ -230,9 +252,20 @@ static void recorder_io_workload_get_next(int rank, struct codes_workload_op *op ...@@ -230,9 +252,20 @@ static void recorder_io_workload_get_next(int rank, struct codes_workload_op *op
else { else {
/* return the next event */ struct recorder_io_op *next_r_op = &(tmp->trace_ops[tmp->trace_list_ndx]);
/* TODO: Do I need to check for the delay like in Darshan? */
*op = tmp->trace_ops[tmp->trace_list_ndx++].codes_op; if ((next_r_op->start_time - tmp->last_op_time) <= RECORDER_NEGLIGIBLE_DELAY) {
*op = next_r_op->codes_op;
tmp->trace_list_ndx++;
tmp->last_op_time = next_r_op->end_time;
else {
op->op_type = CODES_WK_DELAY;
op->u.delay.seconds = next_r_op->start_time - tmp->last_op_time;
tmp->last_op_time = next_r_op->start_time;
return; return;
Markdown is supported
0% or
Please register or to comment
