Commit 4febce16 authored by Jonathan Jenkins's avatar Jonathan Jenkins
tweaks to install steps
parent 13e494da
...@@ -31,7 +31,11 @@ release (0.3.0), ROSS's latest commit hash was c04babe, so this revision is ...@@ -31,7 +31,11 @@ release (0.3.0), ROSS's latest commit hash was c04babe, so this revision is
cd build cd build
../configure --with-ross=/path/to/ross/install --prefix=/path/to/codes-base/install CC=mpicc ../configure --with-ross=/path/to/ross/install --prefix=/path/to/codes-base/install CC=mpicc
To enable network tracing with dumpi, use optional --with-dumpi = /path/to/dumpi/install with configure. To enable network tracing with dumpi, use the option
To enable using the darshan I/O generator, use the option
--with-darshan=/path/to/darshan with configure
3 - Build and install codes-base 3 - Build and install codes-base
Markdown is supported
0% or
Please register or to comment
