Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project
Project
Details
Activity
Releases
Cycle Analytics
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Charts
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Charts
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
4b5962ca
Commit
4b5962ca
authored
Feb 28, 2018
by
Misbah Mubarak
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
adding modifications to workload generator
parent
b8df46df
Changes
9
Hide whitespace changes
Inline
Side-by-side
Showing
9 changed files
with
758 additions
and
35 deletions
+758
-35
Makefile.am
Makefile.am
+6
-0
codes-workload.h
codes/codes-workload.h
+17
-0
configure.ac
configure.ac
+18
-0
codes.pc.in
maint/codes.pc.in
+6
-2
Makefile.subdir
src/Makefile.subdir
+1
-1
codes-workload-dump.c
src/workload/codes-workload-dump.c
+31
-1
codes-workload.c
src/workload/codes-workload.c
+30
-1
codes-dumpi-trace-nw-wrkld.c
src/workload/methods/codes-dumpi-trace-nw-wrkld.c
+33
-30
codes-online-comm-wrkld.C
src/workload/methods/codes-online-comm-wrkld.C
+616
-0
No files found.
Makefile.am
View file @
4b5962ca
@@ -57,6 +57,12 @@ AM_CPPFLAGS += ${RECORDER_CPPFLAGS}
src_libcodes_la_SOURCES
src/workload/methods/codes-recorder-io-wrkld.c
endif
if
USE_ONLINE
AM_CPPFLAGS
ARGOBOTS_CFLAGS
SWM_CFLAGS
-DUSE_ONLINE
1
LDADD
SWM_LIBS
ARGOBOTS_LIBS
endif
if
USE_DUMPI
AM_CPPFLAGS
DUMPI_CFLAGS
-DUSE_DUMPI
1
View file @
4b5962ca
@@ -19,6 +19,9 @@ extern "C" {
#include <ross.h>
#include "configuration.h"
#ifdef USE_ONLINE
#include <abt.h>
#endif
#define MAX_NAME_LENGTH_WKLD 512
/* implementations included with codes */
@@ -30,6 +33,7 @@ typedef struct recorder_params recorder_params;
/* struct to hold the actual data from a single MPI event*/
typedef
struct
dumpi_trace_params
dumpi_trace_params
typedef
struct
checkpoint_wrkld_params
typedef
struct
online_comm_params
online_comm_params
struct
iomock_params
@@ -77,6 +81,11 @@ struct dumpi_trace_params {
#endif
struct
online_comm_params
char
workload_name
char
file_path
int
nprocs
struct
int
nprocs
/* number of workload processes */
@@ -306,6 +315,13 @@ int codes_workload_get_rank_cnt(
const
char
params
int
app_id
/* Finalize the workload */
int
codes_workload_finalize
const
char
type
const
char
params
int
app_id
int
rank
/* for debugging/logging: print an individual operation to the specified file */
void
codes_workload_print_op
FILE
f
@@ -324,6 +340,7 @@ struct codes_workload_method
void
codes_workload_get_next
int
app_id
int
rank
struct
codes_workload_op
op
void
codes_workload_get_next_rc2
int
app_id
int
rank
int
const
char
params
int
app_id
int
const
char
params
int
app_id
int
rank
configure.ac
View file @
4b5962ca
@@ -104,6 +104,24 @@ fi
AM_CONDITIONAL(USE_DARSHAN, [test "x${use_darshan}" = xyes])
# check for Argobots
AC_ARG_WITH([online],[AS_HELP_STRING([--with-online@<:@=DIR@:>@],
[Build with the online workloads and argobots support])],
[use_online=yes],[use_online=no])
if test "x${use_online}" != "x" ; then
AM_CONDITIONAL(USE_ONLINE, true)
PKG_CHECK_MODULES_STATIC([ARGOBOTS], [argobots], [],
[AC_MSG_ERROR([Could not find working argobots installation via pkg-config])])
PKG_CHECK_MODULES_STATIC([SWM], [swm], [],
[AC_MSG_ERROR([Could not find working swm installation via pkg-config])])
PKG_CHECK_VAR([SWM_DATAROOTDIR], [swm], [datarootdir], [],
[AC_MSG_ERROR[Could not find shared directory in SWM]])
AC_DEFINE_UNQUOTED([SWM_DATAROOTDIR], ["$SWM_DATAROOTDIR"], [if using json
data files])
else
AM_CONDITIONAL(USE_ONLINE, false)
fi
# check for Recorder
AM_CONDITIONAL(USE_RECORDER, true)
RECORDER_CPPFLAGS="-DUSE_RECORDER=1"
maint/codes.pc.in
View file @
4b5962ca
@@ -14,11 +14,15 @@ python_cflags=@PYTHON_CFLAGS@
python_libs=@PYTHON_LIBS@
boost_cflags=@BOOST_CFLAGS@
boost_libs=@BOOST_LIBS@
argobots_libs=@ARGOBOTS_LIBS@
argobots_cflags=@ARGOBOTS_CFLAGS@
swm_libs=@SWM_LIBS@
swm_cflags=@SWM_CFLAGS@
Description: Base functionality for CODES storage simulation
Version: @PACKAGE_VERSION@
URL: http://trac.mcs.anl.gov/projects/CODES
Requires:
Libs: -L${libdir} -lcodes ${ross_libs} ${darshan_libs} ${dumpi_libs} ${cortex_libs}
Cflags: -I${includedir} ${
ross_cflags} ${darshan
_cflags} ${dumpi_cflags} ${cortex_cflags}
argobots_libs} ${swm_libs} ${
swm_datarootdir} ${ross_cflags} ${darshan_cflags} ${swm_cflags} ${argobots
src/Makefile.subdir
View file @
4b5962ca
@@ -142,7 +142,7 @@ src_libcodes_la_SOURCES = \
src/util/jobmap-impl/jobmap-list.c
src/util/jobmap-impl/jobmap-identity.c
src/util/codes-mapping-context.c
src/util/codes-comm.c
src/workload/methods/codes-iolang-wrkld.c
src/workload/methods/codes-checkpoint-wrkld.c
View file @
4b5962ca
@@ -16,6 +16,7 @@ static darshan_params d_params = {"", 0};
static
iolang_params
i_params
0
0
static
recorder_params
r_params
0
static
dumpi_trace_params
du_params
0
static
online_comm_params
oc_params
0
static
c_params
0
0
0
0
0
static
iomock_params
im_params
0
0
1
0
0
0
static
int
n
1
@@ -33,6 +34,7 @@ static struct option long_opts[] =
"r-trace-dir"
required_argument
NULL
'd'
"r-nprocs"
required_argument
NULL
'x'
"dumpi-log"
required_argument
NULL
'w'
"workload-name"
required_argument
NULL
'b'
"chkpoint-size"
required_argument
NULL
'S'
"chkpoint-bw"
required_argument
NULL
'B'
"chkpoint-iters"
required_argument
NULL
'i'
@@ -62,6 +64,8 @@ void usage(){
"--r-nprocs: number of ranks in original recorder workload
\n
"DUMPI TRACE OPTIONS (dumpi-trace-workload)
\n
"--dumpi-log: dumpi log file
\n
"ONLINE COMM OPTIONS (online_comm_workload)
\n
"--workload-name : name of the workload (lammps or nekbone)
\n
"CHECKPOINT OPTIONS (checkpoint_io_workload)
\n
"--chkpoint-size: size of aggregate checkpoint to write
\n
"--chkpoint-bw: checkpointing bandwidth
\n
@@ -79,6 +83,9 @@ void usage(){
int
main
int
argc
char
argv
#ifdef USE_ONLINE
ABT_init
argc
argv
#endif
int
print_stats
0
double
total_delay
0
0
int64_t
num_barriers
0
@@ -120,7 +127,7 @@ int main(int argc, char *argv[])
int64_t
num_testalls
0
char
ch
while
ch
getopt_long
argc
argv
"t:n:l:a:m:sp:wr:S:B:R:M:Q:N:z:f:u"
while
ch
getopt_long
argc
argv
"t:n:l:
b:
long_opts
NULL
1
switch
ch
case
't'
@@ -133,6 +140,9 @@ int main(int argc, char *argv[])
case
'l'
strcpy
d_params
log_file_path
optarg
break
case
'b'
strcpy
oc_params
workload_name
optarg
break
case
'a'
d_params
aggregator_cnt
atol
optarg
break
@@ -215,6 +225,18 @@ int main(int argc, char *argv[])
wparams
char
d_params
else
if
strcmp
type
"online_comm_workload"
0
if
n
1
fprintf
stderr
"Expected
--num-ranks
argument for online workload
\n
usage
return
1
else
oc_params
nprocs
n
wparams
char
oc_params
else
if
strcmp
type
"iolang_workload"
0
if
n
1
fprintf
stderr
@@ -422,6 +444,11 @@ int main(int argc, char *argv[])
op
op_type
while
op
op_type
CODES_WK_END
if
strcmp
type
0
type
wparams
0
i
if
print_stats
@@ -467,6 +494,9 @@ int main(int argc, char *argv[])
fprintf
stderr
"NUM_TESTALLS: %"
PRId64
\n
num_testalls
#ifdef USE_ONLINE
ABT_finalize
#endif
return
0
View file @
4b5962ca
@@ -24,6 +24,9 @@ extern struct codes_workload_method darshan_io_workload_method;
#ifdef USE_RECORDER
extern
struct
recorder_io_workload_method
#endif
#ifdef USE_ONLINE
extern
struct
online_comm_workload_method
#endif
extern
struct
checkpoint_workload_method
extern
struct
iomock_workload_method
@@ -37,6 +40,9 @@ static struct codes_workload_method const * method_array_default[] =
#ifdef USE_DARSHAN
#endif
#ifdef USE_ONLINE
#endif
#ifdef USE_RECORDER
#endif
@@ -89,6 +95,7 @@ static void init_workload_methods(void)
// note - includes null char
int
num_default_methods
sizeof
sizeof
0
printf
\n
Num default methods %d "
num_default_methods
method_array
realloc
method_array
num_default_methods
num_user_methods
1
sizeof
method_array
@@ -152,6 +159,7 @@ int codes_workload_load(
for
i
0
method_array
i
NULL
i
printf
\n
loading for workload %s %s "
type
method_array
i
method_name
if
strcmp
method_array
i
method_name
type
0
/* load appropriate workload generator */
@@ -264,6 +272,27 @@ void codes_workload_get_next_rc2(
method_array
wkld_id
app_id
rank
int
const
char
type
const
char
params
int
app_id
int
rank
int
i
for
i
0
method_array
i
NULL
i
if
strcmp
method_array
i
method_name
type
0
return
method_array
i
params
app_id
rank
fprintf
stderr
"Error: failed to find workload generator %s
\n
type
return
1
int
const
char
type
const
char
params
@@ -428,7 +457,7 @@ void codes_workload_print_op(
void
codes_workload_add_method
struct
const
method
static
int
method_array_cap
8
static
int
method_array_cap
10
if
is_workloads_init
tw_error
TW_LOC
"adding a workload method after initialization is forbidden"
View file @
4b5962ca
@@ -783,8 +783,11 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
if
rank
dumpi_params
num_net_traces
return
1
int
hash_size
dumpi_params
num_net_traces
dumpi_params
nprocs
1
if
rank_tbl
int
hash_size
1
if
dumpi_params
nprocs
0
hash_size
dumpi_params
num_net_traces
dumpi_params
nprocs
1
if
rank_tbl
rank_tbl
qhash_init
hash_rank_compare
quickhash_64bit_hash
hash_size
if
rank_tbl
@@ -850,12 +853,12 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
#endif
/* handle MPI function calls */
callbacks
on_init
handleDUMPIInit
callbacks
on_init
handleDUMPIInit
callbacks
on_send
dumpi_send_call
handleDUMPISend
callbacks
on_recv
dumpi_recv_call
handleDUMPIRecv
callbacks
on_isend
dumpi_isend_call
handleDUMPIISend
callbacks
on_irecv
dumpi_irecv_call
handleDUMPIIRecv
callbacks
on_allreduce
dumpi_allreduce_call
handleDUMPIAllreduce
callbacks
on_recv
dumpi_recv_call
handleDUMPIRecv
callbacks
on_isend
dumpi_isend_call
handleDUMPIISend
callbacks
on_irecv
dumpi_irecv_call
handleDUMPIIRecv
callbacks
on_allreduce
callbacks
on_bcast
dumpi_bcast_call
handleDUMPIBcast
callbacks
on_get_count
dumpi_get_count_call
handleDUMPIIgnore
callbacks
on_bsend
dumpi_bsend_call
handleDUMPIIgnore
@@ -890,28 +893,28 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
callbacks
on_sendrecv_replace
dumpi_sendrecv_replace_call
handleDUMPIIgnore
callbacks
on_type_contiguous
dumpi_type_contiguous_call
handleDUMPIIgnore
callbacks
on_barrier
dumpi_barrier_call
handleDUMPIIgnore
callbacks
on_gather
dumpi_gather_call
handleDUMPIIgnore
callbacks
on_gatherv
dumpi_gatherv_call
handleDUMPIIgnore
callbacks
on_scatter
dumpi_scatter_call
handleDUMPIIgnore
callbacks
on_scatterv
dumpi_scatterv_call
handleDUMPIIgnore
callbacks
on_allgather
dumpi_allgather_call
handleDUMPIIgnore
callbacks
on_allgatherv
dumpi_allgatherv_call
handleDUMPIIgnore
callbacks
on_alltoall
dumpi_alltoall_call
handleDUMPIIgnore
callbacks
on_alltoallv
dumpi_alltoallv_call
handleDUMPIIgnore
callbacks
on_alltoallw
dumpi_alltoallw_call
handleDUMPIIgnore
callbacks
on_reduce
dumpi_reduce_call
handleDUMPIIgnore
callbacks
on_reduce_scatter
dumpi_reduce_scatter_call
handleDUMPIIgnore
callbacks
on_group_size
dumpi_group_size_call
handleDUMPIIgnore
callbacks
on_group_rank
dumpi_group_rank_call
handleDUMPIIgnore
callbacks
on_comm_size
dumpi_comm_size_call
handleDUMPIIgnore
callbacks
on_comm_rank
dumpi_comm_rank_call
handleDUMPIIgnore
callbacks
on_comm_get_attr
dumpi_comm_get_attr_call
handleDUMPIIgnore
callbacks
on_comm_dup
dumpi_comm_dup_call
handleDUMPIError
callbacks
on_comm_create
dumpi_comm_create_call
handleDUMPIError
callbacks
on_wtime
dumpi_wtime_call
handleDUMPIIgnore
callbacks
on_finalize
dumpi_finalize_call
handleDUMPIFinalize
libundumpi_populate_callbacks
callbacks
callarr
callbacks
on_gather
dumpi_gather_call
handleDUMPIIgnore
callbacks
on_gatherv
dumpi_gatherv_call
handleDUMPIIgnore
callbacks
on_scatter
dumpi_scatter_call
handleDUMPIIgnore
callbacks
on_scatterv
dumpi_scatterv_call
handleDUMPIIgnore
callbacks
on_allgather
handleDUMPIIgnore
callbacks
on_allgatherv
handleDUMPIIgnore
callbacks
on_alltoall
dumpi_alltoall_call
handleDUMPIIgnore
callbacks
on_alltoallv
handleDUMPIIgnore
callbacks
on_alltoallw
handleDUMPIIgnore
callbacks
on_reduce
dumpi_reduce_call
handleDUMPIIgnore
callbacks
on_reduce_scatter
handleDUMPIIgnore
callbacks
on_group_size
handleDUMPIIgnore
callbacks
on_group_rank
handleDUMPIIgnore
callbacks
on_comm_size
handleDUMPIIgnore
callbacks
on_comm_rank
handleDUMPIIgnore
callbacks
on_comm_get_attr
handleDUMPIIgnore
callbacks
on_comm_dup
dumpi_comm_dup_call
handleDUMPIError
callbacks
on_comm_create
handleDUMPIError
callbacks
on_wtime
dumpi_wtime_call
handleDUMPIIgnore
callbacks
on_finalize
dumpi_finalize_call
handleDUMPIFinalize
callbacks
callarr
#ifdef ENABLE_CORTEX
#ifdef ENABLE_CORTEX_PYTHON
@@ -924,7 +927,7 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
CORTEX_MPICH_TRANSLATION
transarr
#endif
#endif
DUMPI_START_STREAM_READ
profile
profile
//dumpi_header* trace_header = undumpi_read_header(profile);
//dumpi_free_header(trace_header);
0 → 100644
View file @
4b5962ca
* Copyright (C) 2014 University of Chicago
* See COPYRIGHT notice in top-level directory.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <mpi.h>
#include <ross.h>
#include <assert.h>
#include <deque>
#include "codes/codes-workload.h"
#include "codes/quickhash.h"
#include "codes/codes-jobmap.h"
#include "codes_config.h"
#include "lammps.h"
#include "nekbone_swm_user_code.h"
#include <boost/property_tree/json_parser.hpp>
#include <boost/property_tree/ptree.hpp>
#define DBG_COMM 1
using
namespace
std
static
struct
qhash_table
rank_tbl
NULL
static
int
rank_tbl_pop
0
static
int
total_rank_cnt
0
ABT_thread
global_prod_thread
NULL
struct
shared_context
int
my_rank
char
workload_name
void
swm_obj
ABT_thread
producer
std
deque
struct
codes_workload_op
fifo
struct
rank_mpi_context
struct
qhash_head
hash_link
int
app_id
struct
shared_context
sctx
typedef
struct
rank_mpi_compare
int
app_id
int
rank
rank_mpi_compare
* peer: the receiving peer id
* comm_id: the communicator id being used
* tag: tag id
* reqvc: virtual channel being used by the message (to be ignored)
* rspvc: virtual channel being used by the message (to be ignored)
* buf: the address of sender's buffer in memory
* bytes: number of bytes to be sent
* reqrt and rsprt: routing types (to be ignored) */
void
SWM_Send
SWM_PEER
peer
SWM_COMM_ID
comm_id
SWM_TAG
tag
SWM_VC
reqvc
SWM_VC
rspvc
SWM_BUF
buf
SWM_BYTES
bytes
SWM_BYTES
pktrspbytes
SWM_ROUTING_TYPE
reqrt
SWM_ROUTING_TYPE
rsprt
/* add an event in the shared queue and then yield */
// printf("\n Sending to rank %d ", comm_id);
struct
codes_workload_op
wrkld_per_rank
wrkld_per_rank
op_type
CODES_WK_SEND
wrkld_per_rank
u
send
tag
tag
wrkld_per_rank
u
send
num_bytes
bytes
wrkld_per_rank
u
send
dest_rank
peer
#ifdef DBG_COMM
printf
\n
send op tag: %d bytes: %d dest: %d "
tag
bytes
peer
#endif
/* Retreive the shared context state */
ABT_thread
prod
void
arg
int
err
ABT_thread_self
prod
assert
err
ABT_SUCCESS
err
ABT_thread_get_arg
prod
arg
assert
err
ABT_SUCCESS
struct
shared_context
sctx
static_cast
shared_context
arg
wrkld_per_rank
u
send
source_rank
sctx
my_rank
sctx
fifo
push_back
wrkld_per_rank
ABT_thread_yield_to
global_prod_thread
void
SWM_Barrier
SWM_COMM_ID
comm_id
SWM_VC
reqvc
SWM_VC
rspvc
SWM_BUF
buf
SWM_UNKNOWN
auto1
SWM_UNKNOWN2
auto2
SWM_ROUTING_TYPE
reqrt
SWM_ROUTING_TYPE
rsprt
/* Add an event in the shared queue and then yield */
struct
codes_workload_op
wrkld_per_rank
wrkld_per_rank
op_type
CODES_WK_DELAY
/* TODO: Check how to convert cycle count into delay? */
wrkld_per_rank
u
delay
nsecs
0
1
#ifdef DBG_COMM
printf
\n
Barrier delay %lf "
wrkld_per_rank
u
delay
nsecs
#endif
ABT_thread
prod
void
arg
int
err
ABT_thread_self
prod
assert
err
ABT_SUCCESS
err
ABT_thread_get_arg
prod
arg
assert
err
ABT_SUCCESS
struct
shared_context
sctx
static_cast
shared_context
arg
sctx
fifo
push_back
wrkld_per_rank
ABT_thread_yield_to
global_prod_thread
void
SWM_Isend
SWM_PEER
peer
SWM_COMM_ID
comm_id
SWM_TAG
tag
SWM_VC
reqvc
SWM_VC
rspvc
SWM_BUF
buf
SWM_BYTES
bytes
SWM_BYTES
pktrspbytes
uint32_t
handle
SWM_ROUTING_TYPE
reqrt
SWM_ROUTING_TYPE
rsprt
struct
codes_workload_op
wrkld_per_rank
wrkld_per_rank
op_type
CODES_WK_ISEND
wrkld_per_rank
u
send
tag
tag
wrkld_per_rank
u
send
req_id
handle
wrkld_per_rank
u
send
num_bytes
bytes
wrkld_per_rank
u
send
dest_rank
peer
#ifdef DBG_COMM
printf
\n
isend op tag: %d req_id: %"
PRIu32
" bytes: %d dest: %d "
tag
handle
bytes
peer
#endif
ABT_thread
prod
void
arg
int
err
ABT_thread_self
prod
assert
err
ABT_SUCCESS
err
ABT_thread_get_arg
prod
arg
assert
err
ABT_SUCCESS
struct
shared_context
sctx
static_cast
shared_context
arg
wrkld_per_rank
u
send
source_rank
sctx
my_rank
sctx
fifo
push_back
wrkld_per_rank
ABT_thread_yield_to
global_prod_thread
void
SWM_Recv
SWM_PEER
peer
SWM_COMM_ID
comm_id
SWM_TAG
tag
SWM_BUF
buf
struct
codes_workload_op
wrkld_per_rank
wrkld_per_rank
op_type
CODES_WK_RECV
wrkld_per_rank
u
recv
tag
tag
wrkld_per_rank
u
recv
source_rank
peer
#ifdef DBG_COMM
printf
\n
recv op tag: %d source: %d "
tag
peer
#endif
ABT_thread
prod
void
arg
int
err
ABT_thread_self
prod
assert
err
ABT_SUCCESS
err
ABT_thread_get_arg
prod
arg
assert
err
ABT_SUCCESS
struct
shared_context
sctx
static_cast
shared_context
arg
wrkld_per_rank
u
recv
dest_rank
sctx
my_rank
sctx
fifo
push_back
wrkld_per_rank
ABT_thread_yield_to
global_prod_thread
/* handle is for the request ID */
void
SWM_Irecv
SWM_PEER
peer
SWM_COMM_ID
comm_id
SWM_TAG
tag
SWM_BUF
buf
uint32_t
handle
struct
codes_workload_op
wrkld_per_rank
wrkld_per_rank
op_type
CODES_WK_IRECV
wrkld_per_rank
u
recv
tag
tag
wrkld_per_rank
u
recv
source_rank
peer
wrkld_per_rank
u
recv
req_id
handle
wrkld_per_rank
u
recv
num_bytes
0
#ifdef DBG_COMM
printf
\n
irecv op tag: %d source: %d "
tag
peer
#endif
ABT_thread
prod
void
arg
int
err
ABT_thread_self
prod
assert
err
ABT_SUCCESS
err
ABT_thread_get_arg
prod
arg
assert
err
ABT_SUCCESS
struct
shared_context
sctx
static_cast
shared_context
arg
wrkld_per_rank
u
recv
dest_rank
sctx
my_rank
sctx
fifo
push_back
wrkld_per_rank
ABT_thread_yield_to
global_prod_thread
void
SWM_Compute
long
cycle_count
struct
codes_workload_op
wrkld_per_rank
wrkld_per_rank
op_type
CODES_WK_DELAY
wrkld_per_rank
u
delay
nsecs
cycle_count
#ifdef DBG_COMM
printf
\n
compute op delay: %ld "
cycle_count
#endif
ABT_thread
prod
void
arg
int
err
ABT_thread_self
prod
assert
err
ABT_SUCCESS
err
ABT_thread_get_arg
prod
arg
assert
err
ABT_SUCCESS
struct
shared_context
sctx
static_cast
shared_context
arg
sctx
fifo
push_back
wrkld_per_rank
ABT_thread_yield_to
global_prod_thread
void
SWM_Wait
uint32_t
req_id
struct
codes_workload_op
wrkld_per_rank
wrkld_per_rank
op_type
CODES_WK_WAIT
wrkld_per_rank
u
wait
req_id
req_id
#ifdef DBG_COMM
printf
\n
wait op req_id: %"
PRIu32
\n
req_id
#endif
ABT_thread
prod
void
arg
int
err
ABT_thread_self
prod
assert
err
ABT_SUCCESS
err
ABT_thread_get_arg
prod
arg
assert
err
ABT_SUCCESS
struct
shared_context
sctx
static_cast
shared_context
arg
sctx
fifo
push_back
wrkld_per_rank
ABT_thread_yield_to
global_prod_thread
void
SWM_Waitall
int
len
uint32_t
req_ids
struct
codes_workload_op
wrkld_per_rank
wrkld_per_rank
op_type
CODES_WK_WAITALL
wrkld_per_rank
u
waits
count
len
wrkld_per_rank
u
waits
req_ids
unsigned
int
calloc
len
sizeof
int
for
int
i
0
i
len
i
wrkld_per_rank
u
waits
req_ids
i
req_ids
i
#ifdef DBG_COMM
for
int
i
0
i
len
i
printf
\n
wait op req_id: %"
PRIu32
\n
req_ids
i
#endif
ABT_thread
prod
void
arg
int
err
ABT_thread_self
prod
assert
err
ABT_SUCCESS
err
ABT_thread_get_arg
prod
arg
assert
err
ABT_SUCCESS
struct
shared_context
sctx
static_cast
shared_context
arg
sctx
fifo
push_back
wrkld_per_rank
ABT_thread_yield_to
global_prod_thread
void
SWM_Sendrecv
SWM_COMM_ID
comm_id
SWM_PEER
sendpeer
SWM_TAG
sendtag
SWM_VC
sendreqvc
SWM_VC
sendrspvc
SWM_BUF
sendbuf
SWM_BYTES
sendbytes
SWM_BYTES
pktrspbytes
SWM_PEER
recvpeer
SWM_TAG
recvtag
SWM_BUF
recvbuf
SWM_ROUTING_TYPE
reqrt
SWM_ROUTING_TYPE
rsprt
// printf("\n Sending to %d receiving from %d ", sendpeer, recvpeer);
struct
codes_workload_op
send_op
send_op
op_type
CODES_WK_SEND
send_op
u
send
tag
sendtag
send_op
u
send
num_bytes
sendbytes
send_op
u
send
dest_rank
sendpeer
struct
codes_workload_op
recv_op
recv_op
op_type
CODES_WK_RECV
recv_op
u
recv
tag
recvtag
recv_op
u
recv
source_rank
recvpeer
#ifdef DBG_COMM
printf
\n
send/recv op send-tag %d send-bytes %d recv-tag: %d recv-source: %d "
sendtag
sendbytes
recvtag
recvpeer
#endif
ABT_thread
prod
void
arg
int
err
ABT_thread_self
prod
assert
err
ABT_SUCCESS
err
ABT_thread_get_arg
prod
arg
