Commit 434033d8 authored by Misbah Mubarak's avatar Misbah Mubarak
changes to the documentation
parent 642231b0
...@@ -14,11 +14,17 @@ SAMPLING: ...@@ -14,11 +14,17 @@ SAMPLING:
an end time. Over this end time, dragonfly model will collect compute an end time. Over this end time, dragonfly model will collect compute
node and router samples after every "t" simulated nanoseconds. The node and router samples after every "t" simulated nanoseconds. The
sampling output files can be specified in the config file using sampling output files can be specified in the config file using
cn_sample_file and rt_sample_file arguments. An example utility that cn_sample_file and rt_sample_file arguments. By default the compute node
reads the binary files and translates it into text can be found at and router outputs will be sent to dragonfly-cn-sampling-%d.bin and
dragonfly-router-sampling-%d.bin. Corresponding metadata files for also
generated that gives information on the file format, dragonfly
configuration being used, router radix etc.
An example utility that reads the binary files and translates it into
text format can be found at
src/networks/model-net/read-dragonfly-sample.c (Note that the router src/networks/model-net/read-dragonfly-sample.c (Note that the router
radix aka RADIX needs to be tuned with the dragonfly configuration radix aka RADIX needs to be tuned with the dragonfly configuration in the
in the utility to enable continguous array allocation). utility to enable continguous array allocation).
HOW TO RUN: HOW TO RUN:
...@@ -1986,8 +1986,8 @@ void dragonfly_rsample_fin(router_state * s, ...@@ -1986,8 +1986,8 @@ void dragonfly_rsample_fin(router_state * s,
sprintf(meta_fname, "dragonfly-router-sampling.meta"); sprintf(meta_fname, "dragonfly-router-sampling.meta");
FILE * fp = fopen(meta_fname, "w"); FILE * fp = fopen(meta_fname, "w");
fprintf(fp, "\n Router sample format: router_id \t busy time for each of the %d links \t" fprintf(fp, "Router sample struct format: router_id (tw_lpid) \t busy time for each of the %d links (double) \t"
"link traffic for each of the %d links \t sample end time ", "link traffic for each of the %d links (int64_t) \t sample end time (double)",
p->radix, p->radix); p->radix, p->radix);
fclose(fp); fclose(fp);
...@@ -2140,8 +2140,9 @@ void dragonfly_sample_fin(terminal_state * s, ...@@ -2140,8 +2140,9 @@ void dragonfly_sample_fin(terminal_state * s,
sprintf(meta_fname, "dragonfly-cn-sampling.meta"); sprintf(meta_fname, "dragonfly-cn-sampling.meta");
fprintf(fp, "\n Compute node sample format: terminal_id \t finished chunks \t" fprintf(fp, "Compute node sample format: terminal_id (tw_lpid) \t finished chunks (long) \t"
"data size per sample \t finished hops \t time to finish chunks \t busy time \t sample end time"); "data size per sample (long) \t finished hops (double) \t time to finish chunks (double) \t "
"busy time (double)\t sample end time(double)");
char rt_fn[MAX_NAME_LENGTH]; char rt_fn[MAX_NAME_LENGTH];
Markdown is supported
0% or
Please register or to comment
