Commit 406bab44 authored by Jonathan Jenkins's avatar Jonathan Jenkins
extended opts for config filter
parent da5b6b71
...@@ -33,6 +33,11 @@ def main(): ...@@ -33,6 +33,11 @@ def main():
if k not in cfg.replace_map: if k not in cfg.replace_map:
raise ValueError("key " + k + " not in original config") raise ValueError("key " + k + " not in original config")
# hack - if we are using an output prefix, append the "dot" here
if args.output_prefix == None:
args.output_prefix = ""
else:
args.output_prefix = args.output_prefix + '.'
# filter out the files # filter out the files
# (cfg iterator returns nothing, eval'd for side effects) # (cfg iterator returns nothing, eval'd for side effects)
for i,_ in enumerate(cfg): for i,_ in enumerate(cfg):
...@@ -40,13 +45,14 @@ def main(): ...@@ -40,13 +45,14 @@ def main():
if tdict[k] != cfg.replace_map[k]: if tdict[k] != cfg.replace_map[k]:
break break
else: else:
stdout.write(args.output_prefix + "." + str(i) + "\n") stdout.write(args.output_prefix + str(i) + "\n")
def parse_args(): def parse_args():
parser = argparse.ArgumentParser(\ parser = argparse.ArgumentParser(\
description="emit configuration files to stdout matching given " description="emit configuration files to stdout matching given "
"token values") "token values")
parser.add_argument("output_prefix", help="prefix of output config files") parser.add_argument("-o", "--output_prefix", help="prefix of output config "
"files (Default: print only the filtered indices)", type=str)
parser.add_argument("substitute_py", parser.add_argument("substitute_py",
help="input python file given to codes_configurator.py - see " help="input python file given to codes_configurator.py - see "
"codes_configurator.py for details") "codes_configurator.py for details")
Markdown is supported
0% or
Please register or to comment
