Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project
Project
Details
Activity
Releases
Cycle Analytics
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Charts
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Charts
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
3e9f0dbb
Commit
3e9f0dbb
authored
Sep 29, 2017
by
Caitlin Ross
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
adding support for ROSS model sampling to custom dragonfly
parent
4457f310
Changes
4
Expand all
Hide whitespace changes
Inline
Side-by-side
Showing
4 changed files
with
347 additions
and
1 deletion
+347
-1
dragonfly-custom.h
codes/net/dragonfly-custom.h
+2
-0
model-net-mpi-replay.c
src/network-workloads/model-net-mpi-replay.c
+4
-1
model-net-synthetic-custom-dfly.c
src/network-workloads/model-net-synthetic-custom-dfly.c
+50
-0
dragonfly-custom.C
src/networks/model-net/dragonfly-custom.C
+291
-0
No files found.
View file @
3e9f0dbb
@@ -85,6 +85,8 @@ struct terminal_custom_message
tw_stime
saved_total_time
tw_stime
saved_sample_time
tw_stime
msg_start_time
tw_stime
saved_busy_time_ross
tw_stime
saved_fin_chunks_ross
#ifdef __cplusplus
View file @
3e9f0dbb
@@ -2504,8 +2504,11 @@ st_model_types nw_lp_model_types[] = {
ev_trace_f
nw_lp_event_collect
sizeof
int
model_stat_f
nw_lp_model_stat_collect
0
NULL
NULL
0
NULL
0
NULL
0
NULL
0
NULL
0
NULL
0
NULL
0
NULL
NULL
0
static
const
st_model_types
nw_lp_get_model_stat_types
void
View file @
3e9f0dbb
@@ -107,6 +107,53 @@ tw_lptype svr_lp = {
sizeof
svr_state
/* setup for the ROSS event tracing
* can have a different function for rbev_trace_f and ev_trace_f
* but right now it is set to the same function for both
void
custom_svr_event_collect
svr_msg
m
tw_lp
lp
char
buffer
int
collect_flag
void
lp
void
collect_flag
int
type
int
m
svr_event_type
memcpy
buffer
type
sizeof
type
/* can add in any model level data to be collected along with simulation engine data
* in the ROSS instrumentation. Will need to update the last field in
* svr_model_types[0] for the size of the data to save in each function call
void
custom_svr_model_stat_collect
svr_state
s
tw_lp
lp
char
buffer
void
s
void
lp
void
buffer
return
st_model_types
custom_svr_model_types
rbev_trace_f
sizeof
int
ev_trace_f
sizeof
int
model_stat_f
0
NULL
NULL
0
NULL
0
NULL
0
NULL
0
NULL
NULL
0
static
const
st_model_types
custom_svr_get_model_stat_types
void
return
0
void
custom_svr_register_model_types
st_model_type_register
"nw-lp"
const
tw_optdef
app_opt
TWOPT_GROUP
"Model net synthetic traffic "
@@ -380,6 +427,9 @@ int main(
model_net_register
svr_add_lp_type
if
g_st_ev_trace
g_st_model_stats
g_st_use_analysis_lps
codes_mapping_setup
net_ids
model_net_configure
num_nets
View file @
3e9f0dbb
This diff is collapsed.
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
