Commit 39ef9691 authored by Misbah Mubarak's avatar Misbah Mubarak
Making the protocol transition threshold configurable
parent fd856baf
...@@ -23,7 +23,6 @@ ...@@ -23,7 +23,6 @@
#define TRACE -1 #define TRACE -1
#define MAX_WAIT_REQS 512 #define MAX_WAIT_REQS 512
#define CS_LP_DBG 1 #define CS_LP_DBG 1
#define EAGER_THRESHOLD 8192
#define RANK_HASH_TABLE_SZ 2000 #define RANK_HASH_TABLE_SZ 2000
#define NW_LP_NM "nw-lp" #define NW_LP_NM "nw-lp"
#define lprintf(_fmt, ...) \ #define lprintf(_fmt, ...) \
...@@ -46,6 +45,7 @@ char offset_file[8192]; ...@@ -46,6 +45,7 @@ char offset_file[8192];
static int wrkld_id; static int wrkld_id;
static int num_net_traces = 0; static int num_net_traces = 0;
static int num_dumpi_traces = 0; static int num_dumpi_traces = 0;
static uint64_t EAGER_THRESHOLD = 8192;
static int alloc_spec = 0; static int alloc_spec = 0;
static tw_stime self_overhead = 10.0; static tw_stime self_overhead = 10.0;
...@@ -279,7 +279,7 @@ struct nw_message ...@@ -279,7 +279,7 @@ struct nw_message
tw_lpid src_rank; tw_lpid src_rank;
int dest_rank; int dest_rank;
int64_t num_bytes; uint64_t num_bytes;
int num_matched; int num_matched;
int data_type; int data_type;
double sim_start_time; double sim_start_time;
...@@ -2285,6 +2285,7 @@ const tw_optdef app_opt [] = ...@@ -2285,6 +2285,7 @@ const tw_optdef app_opt [] =
TWOPT_CHAR("alloc_file", alloc_file, "allocation file name"), TWOPT_CHAR("alloc_file", alloc_file, "allocation file name"),
TWOPT_CHAR("workload_conf_file", workloads_conf_file, "workload config file name"), TWOPT_CHAR("workload_conf_file", workloads_conf_file, "workload config file name"),
TWOPT_UINT("num_net_traces", num_net_traces, "number of network traces"), TWOPT_UINT("num_net_traces", num_net_traces, "number of network traces"),
TWOPT_UINT("eager_threshold", EAGER_THRESHOLD, "the transition point for eager/rendezvous protocols (Default 8192)"),
TWOPT_UINT("disable_compute", disable_delay, "disable compute simulation"), TWOPT_UINT("disable_compute", disable_delay, "disable compute simulation"),
TWOPT_UINT("enable_mpi_debug", enable_debug, "enable debugging of MPI sim layer (works with sync=1 only)"), TWOPT_UINT("enable_mpi_debug", enable_debug, "enable debugging of MPI sim layer (works with sync=1 only)"),
TWOPT_UINT("sampling_interval", sampling_interval, "sampling interval for MPI operations"), TWOPT_UINT("sampling_interval", sampling_interval, "sampling interval for MPI operations"),
Markdown is supported
0% or
Please register or to comment
