Commit 3219d200 authored by Xin Wang's avatar Xin Wang
Delete conc-latencyall.c
parent 807f83ee
* This file was generated by coNCePTuaL on Mon Jan 7 23:10:00 2019
* using the c_mpi backend (C + MPI).
* Do not modify this file; modify /Users/xin/macworkspace/codes-dev/codes/scripts/conceptual_benchmarks/latency-all.ncptl instead.
* Entire source program
* # An all-pairs ping-pong latency test written in coNCePTuaL
* # By Scott Pakin <pakin@lanl.gov>
* Require language version "1.5".
* # Parse the command line.
* reps is "Number of repetitions of each message size" and comes from "--reps" or "-r" with default 1000.
* maxbytes is "Maximum number of bytes to transmit" and comes from "--maxbytes" or "-m" with default 1M.
* # Ensure that we have a peer with whom to communicate.
* Assert that "the latency test requires at least two tasks" with num_tasks>=2.
* # Perform the benchmark.
* For each msgsize in {0}, {1, 2, 4, ..., maxbytes} {
* for reps repetitions {
* tasks ev such that ev is even reset their counters then
* tasks ev such that ev is even send a msgsize byte message to task ev+1 then
* tasks od such that od is odd send a msgsize byte message to task od-1 then
* tasks ev such that ev is even log the msgsize as "Bytes" and
* the median of elapsed_usecs/2 as "1/2 RTT (usecs)"
* } then
* tasks ev such that ev is even compute aggregates
#include "codes/codes-conc-addon.h"
* Include files *
/* Header files needed by all C-based backends */
#include <stdio.h>
#include <string.h>
#include <ncptl/ncptl.h>
/* Header files specific to the c_mpi backend */
#include <mpi.h>
#include <stdarg.h>
* Macros *
/* Define the maximum loop trip count that we're willing to unroll fully. */
#define CONC_MAX_UNROLL 5
/* Specify the minimum number of trial iterations in each FOR <time> loop. */
#define CONC_FOR_TIME_TRIALS 1
/* Define a macro that rounds a double to a ncptl_int. */
#define CONC_DBL2INT(D) ((ncptl_int)((D)+0.5))
/* Define a macro that increments a buffer pointer by a byte offset. */
#define CONC_GETBUFPTR(S) ((void *)((char *)thisev->s.S.buffer + thisev->s.S.bufferofs))
/* Implement ncptl_func_task_of in terms of ncptl_physical_to_virtual. */
#define ncptl_func_task_of(P) ((ncptl_int)(P) < 0LL || (ncptl_int)(P) >= var_num_tasks ? -1LL : ncptl_physical_to_virtual (procmap, (ncptl_int)(P)))
#define ncptl_dfunc_task_of(P) ((double) ncptl_func_task_of(P))
/* Implement ncptl_func_processor_of in terms of ncptl_virtual_to_physical. */
#define ncptl_func_processor_of(V) ((ncptl_int)(V) < 0LL || (ncptl_int)(V) >= var_num_tasks ? -1LL : ncptl_virtual_to_physical (procmap, (ncptl_int)(V)))
#define ncptl_dfunc_processor_of(V) ((double) ncptl_func_processor_of(V))
/* Define a macro that increments REDUCE's alternate buffer pointer by a byte offset. */
#define CONC_GETALTBUFPTR(S) ((void *)((char *)thisev->s.S.altbuffer + thisev->s.S.bufferofs))
/* Estimate the number of unique communicators that this program will need.
* (The tradeoff is one of initialization time versus memory consumption.) */
#define ESTIMATED_COMMUNICATORS 128
/* Specify an operation to use for all reduction operations. */
#define REDUCE_OPERATION MPI_SUM
#define REDUCE_OPERATION_NAME "MPI_SUM"
* Type declarations *
/* Enumerate the various mechanisms used to implement MULTICAST statements. */
typedef enum {
CONC_MCAST_MPI_BCAST, /* One to many */
CONC_MCAST_MPI_ALLTOALL, /* Many to many, same data to all */
CONC_MCAST_MPI_ALLTOALLV, /* General many to many */
CONC_MCAST_MPI_NUM_FUNCS /* Number of the above */
} CONC_MCAST_MPI_FUNC;
/* Define the type of event to perform. */
typedef enum {
EV_SEND, /* Synchronous send */
EV_ASEND, /* Asynchronous send */
EV_RECV, /* Synchronous receive */
EV_ARECV, /* Asynchronous receive */
EV_WAIT, /* Wait for all asynchronous sends/receives to complete */
EV_DELAY, /* Spin or sleep */
EV_TOUCH, /* Touch a region of memory */
EV_SYNC, /* Barrier synchronization */
EV_RESET, /* Reset counters */
EV_STORE, /* Store all counters' current values */
EV_RESTORE, /* Restore the previously pushed counter values */
EV_FLUSH, /* Compute aggregate functions for log-file columns */
EV_MCAST, /* Synchronous multicast */
EV_REDUCE, /* Reduction with or without a subsequent multicast */
EV_BTIME, /* Beginning of a timed loop */
EV_ETIME, /* Ending of a timed loop */
EV_REPEAT, /* Repeatedly process the next N events */
EV_SUPPRESS, /* Suppress writing to the log and standard output */
EV_NEWSTMT, /* Beginning of a new top-level statement */
EV_CODE, /* None of the above */
NUM_EVS /* Number of event types in CONC_EVENT_TYPE */
} CONC_EVENT_TYPE;
/* Describe a synchronous or asynchronous send event. */
typedef struct {
ncptl_int dest; /* Destination task */
ncptl_int size; /* Number of bytes to send */
ncptl_int alignment; /* Message alignment (in bytes) */
ncptl_int pendingsends; /* # of outstanding sends */
ncptl_int pendingrecvs; /* # of outstanding receives */
ncptl_int buffernum; /* Buffer # to send from */
ncptl_int bufferofs; /* Byte offset into the message buffer */
ncptl_int tag; /* Tag to use for selective receives */
int misaligned; /* 1=misaligned from a page; 0=align as specified */
int touching; /* 1=touch every word before sending */
int verification; /* 1=fill message buffer with known contents */
void *buffer; /* Pointer to message memory */
MPI_Request * handle; /* MPI handle representing an asynchronous send */
} CONC_SEND_EVENT;
/* Describe a synchronous or asynchronous receive event. */
typedef struct {
ncptl_int source; /* Source task */
ncptl_int size; /* Number of bytes to receive */
ncptl_int buffernum; /* Buffer # to receive into */
int touching; /* 1=touch every word after reception */
int verification; /* 1=verify that all bits are correct */
MPI_Request * handle; /* MPI handle representing an asynchronous receive */
} CONC_RECV_EVENT;
/* Describe a wait-for-asynchronous-completions event. */
typedef struct {
ncptl_int numsends; /* # of sends we expect to complete. */
ncptl_int numrecvs; /* # of receives we expect to complete. */
ncptl_int numrecvbytes; /* # of bytes we expect to receive-complete */
ncptl_int *touchedlist; /* List of receives that need to be touched */
ncptl_int numtouches; /* # of elements in the above */
} CONC_WAIT_EVENT;
/* Describe a spin or sleep delay. */
typedef struct {
uint64_t microseconds; /* Length of delay in microseconds */
int spin0sleep1; /* 0=spin; 1=sleep */
} CONC_DELAY_EVENT;
/* Describe a barrier synchronization event. */
typedef struct {
MPI_Comm communicator; /* Set of tasks to synchronize */
} CONC_SYNC_EVENT;
/* Describe a walk over a memory-region. */
typedef struct {
ncptl_int regionbytes; /* Size in bytes of the region to touch */
ncptl_int bytestride; /* Stride in bytes to touch */
ncptl_int numaccesses; /* Number of words to touch */
ncptl_int wordsize; /* Size in bytes of each touch */
ncptl_int firstbyte; /* Byte offset of the first byte to touch */
} CONC_TOUCH_EVENT;
/* Describe a synchronous multicast event. */
typedef struct {
ncptl_int source; /* Source task, -1 in the many-to-many case */
ncptl_int buffernum; /* Buffer # to send/receive from */
ncptl_int size2; /* Number of bytes to receive in the many-to-many case */
ncptl_int bufferofs2; /* Byte offset into the message buffer in the many-to-many case */
void * buffer2; /* Pointer to receive-message memory in the many-to-many case */
MPI_Comm communicator; /* Set of tasks to multicast to/from */
int root; /* source's rank within communicator */
int * sndvol; /* Volume of data to send to each rank in the communicator */
int * snddisp; /* Offset from buffer of each message to send */
int * rcvvol; /* Volume of data to receive from each rank in the communicator */
int * rcvdisp; /* Offset from buffer2 of each message to receive */
CONC_MCAST_MPI_FUNC mpi_func; /* MPI function to use to perform the multicast */
} CONC_MCAST_EVENT;
/* Describe a reduction event. */
typedef struct {
ncptl_int numitems; /* # of items to reduce */
ncptl_int itemsize; /* # of bytes per item */
int touching; /* 1=touch every word before sending/after receiving */
int sending; /* 1=we're a sender */
int receiving; /* 1=we're a receiver */
void * altbuffer; /* Pointer to additional message memory */
MPI_Comm sendcomm; /* Set of tasks to reduce from */
MPI_Comm recvcomm; /* Set of tasks to reduce to */
MPI_Datatype datatype; /* MPI datatype to reduce */
int reducetype; /* 0=reduce; 1=allreduce; 2=reduce+bcast */
ncptl_int reduceroot; /* Root task of the reduction if reducetype is 0 or 2 */
ncptl_int bcastroot; /* Root task of the multicast if reducetype is 2 */
} CONC_REDUCE_EVENT;
/* Describe an event representing the beginning of a timed loop. */
typedef struct {
uint64_t usecs; /* Requested loop duration */
uint64_t warmup_usecs; /* Requested duration of warmup loops */
uint64_t starttime; /* Time at which the loop state last changed */
uint64_t itersleft; /* # of iterations remaining */
uint64_t previters; /* # of iterations we performed last time */
int prev_quiet; /* Previous value of suppress_output */
int timing_trial; /* 1=performing a timing trial; 0=running for real */
volatile int finished; /* 1=time has expired; 0=still ticking */
} CONC_BTIME_EVENT;
/* Describe an event representing the end of a timed loop. */
typedef struct {
ncptl_int begin_event; /* Index into eventlist[] of the corresponding BTIME event */
} CONC_ETIME_EVENT;
/* Describe an event representing repetitions of subsequent events. */
typedef struct {
ncptl_int end_event; /* Index into eventlist[] of the last event to repeat */
ncptl_int numreps; /* # of repetitions to perform */
} CONC_REPEAT_EVENT;
/* Describe an event representing output suppression (either on or off). */
typedef struct conc_suppress_event {
int quiet; /* 0=allow output; 1=suppress it */
ncptl_int matching_event; /* Event ID of the "suppression on" event */
uint64_t stop_elapsed_usecs; /* Time at which we suppressed output */
} CONC_SUPPRESS_EVENT;
/* Describe an event representing arbitrary code to execute at run time. */
typedef struct {
ncptl_int number; /* Unique number corresponding to a specific piece of code */NCPTL_VIRT_PHYS_MAP *procmap; /* Current mapping between tasks and processors */
ncptl_int var_msgsize; /* Copy of var_msgsize to use within a piece of code */
} CONC_CODE_EVENT;
/* Describe an arbitrary coNCePTuaL event. */
typedef struct {
CONC_EVENT_TYPE type; /* Type of event */
union {
CONC_SEND_EVENT send; /* Send state */
CONC_RECV_EVENT recv; /* Receive state */
CONC_WAIT_EVENT wait; /* Wait-for-completions state */
CONC_DELAY_EVENT delay; /* State for spins and sleeps */
CONC_TOUCH_EVENT touch; /* State for memory touching */
CONC_SYNC_EVENT sync; /* Synchronization state */
CONC_MCAST_EVENT mcast; /* Multicast state */
CONC_REDUCE_EVENT reduce; /* Reduction state */
CONC_BTIME_EVENT btime; /* Timed-loop state */
CONC_ETIME_EVENT etime; /* Additional timed-loop state */
CONC_REPEAT_EVENT rep; /* Repeated-events state */
CONC_SUPPRESS_EVENT suppress; /* State for suppressing output */
CONC_CODE_EVENT code; /* State for arbitrary code */
} s;
} CONC_EVENT;
/* Fully specify an arbitrary for() loop (used by FOR EACH). */
typedef struct {
NCPTL_QUEUE *list_comp; /* NULL=ordinary list; other=list comprehension values */
int integral; /* 1=integral values; 0=floating-point values */
enum { /* Comparison of loop variable to end variable */
CONC_LEQ, /* Increasing progression */
CONC_GEQ /* Decreasing progression */
} comparator;
enum { /* How to increment the loop variable */
CONC_ADD, /* Arithmetically */
CONC_MULT, /* Geometrically increasing */
CONC_DIV /* Geometrically decreasing */
} increment;
union {
struct {
ncptl_int loopvar; /* Loop variable */
ncptl_int prev_loopvar; /* Previous value of loop variable */
ncptl_int startval; /* Initial value of loop variable */
ncptl_int endval; /* Value not to exceed */
ncptl_int incval; /* Loop-variable increment */
} i;
struct {
double loopvar; /* Loop variable */
double prev_loopvar; /* Previous value of loop variable */
double startval; /* Initial value of loop variable */
double endval; /* Value not to exceed */
double incval; /* Loop-variable increment */
} d;
} u;
} LOOPBOUNDS;
* Global variables *
/* Variables exported to coNCePTuaL programs */
static ncptl_int var_bytes_received = 0; /* Total number of bytes received */
static ncptl_int var_msgs_received = 0; /* Total number of messages received */
static ncptl_int var_bit_errors = 0; /* Total number of bit errors observed */
static ncptl_int var_total_msgs = 0; /* Sum of messages sent and messages received */
static ncptl_int var_msgs_sent = 0; /* Total number of messages sent */
static ncptl_int var_bytes_sent = 0; /* Total number of bytes sent */
static ncptl_int var_num_tasks = 1; /* Number of tasks running the program */
static ncptl_int var_elapsed_usecs = 0; /* Elapsed time in microseconds */
static ncptl_int var_total_bytes = 0; /* Sum of bytes sent and bytes received */
/* Dummy variable to help mark other variables as used */
static union {
ncptl_int ni;
int i;
void *vp;
} conc_dummy_var;
/* Variables used internally by boilerplate code */
static uint64_t starttime; /* Time the clock was last reset (microseconds) */
static ncptl_int pendingrecvs = 0; /* Current # of outstanding receives */
static ncptl_int pendingrecvbytes = 0; /* Current # of bytes in outstanding receives */
static NCPTL_QUEUE *touchedqueue; /* Queue of asynchronous receives to touch */
static ncptl_int pendingsends = 0; /* Current # of outstanding sends */
static NCPTL_QUEUE *eventqueue; /* List of coNCePTuaL events to perform */
static int within_time_loop = 0; /* 1=we're within a FOR <time> loop */
static int suppress_output = 0; /* 1=suppress output to stdout and the log file */
static void *touch_region = NULL; /* Memory region to touch */
static ncptl_int touch_region_size = 0; /* # of bytes in the above */
static int virtrank; /* This task's virtual rank in the computation */
static int physrank; /* This task's physical rank in the computation */
static NCPTL_VIRT_PHYS_MAP *procmap; /* Virtual to physical rank mapping */
static NCPTL_LOG_FILE_STATE *logstate; /* Opaque object representing all log-file state */
static char *logfile_uuid; /* Execution UUID to write to every log file */
static char *logfiletmpl; /* Template for the log file's name */
//static char *logfiletmpl_default; /* Default value of the above */
/* Global variables specific to the c_mpi backend */
static ncptl_int mpi_is_running = 0; /* 1=MPI has been initialized */
static NCPTL_QUEUE * recvreqQ; /* List of MPI receive requests */
static MPI_Request * recvrequests; /* List version of recvreqQ */
static NCPTL_QUEUE * recvstatQ; /* List of MPI receive statuses */
static MPI_Status * recvstatuses; /* List version of recvstatQ */
static NCPTL_QUEUE * sendreqQ; /* List of MPI send requests */
static MPI_Request * sendrequests; /* List version of sendreqQ */
static NCPTL_QUEUE * sendstatQ; /* List of MPI send statuses */
static MPI_Status * sendstatuses; /* List version of sendstatQ */
static NCPTL_SET * communicators; /* Map from an array of processor flags to an MPI communicator */
static MPI_Errhandler mpi_error_handler; /* Handle to handle_MPI_error() */
static ncptl_int mpi_tag_ub; /* Upper bound on an MPI tag value */
static ncptl_int conc_mcast_tallies[CONC_MCAST_MPI_NUM_FUNCS] = {0}; /* Tallies of (static) multicast implementation functions */
/* Program-specific variables */
static ncptl_int var_reps; /* Number of repetitions of each message size (command-line argument) */
static ncptl_int var_maxbytes; /* Maximum number of bytes to transmit (command-line argument) */
* Function declarations *
/* Make MPI errors invoke ncptl_fatal(). */
static void handle_MPI_error (MPI_Comm *comm, int *errcode, ...)
va_list args;
char errstring[MPI_MAX_ERROR_STRING];
int errstrlen;
va_start (args, errcode);
if (MPI_Error_string (*errcode, errstring, &errstrlen) == MPI_SUCCESS)
ncptl_fatal ("MPI run-time error: %s", errstring);
else
ncptl_fatal ("MPI aborted with unrecognized error code %d", *errcode);
conc_dummy_var.vp = (void *) comm; /* Prevent the compiler from complaining that comm is unused. */
va_end (args);
/* Perform the equivalent of CODES_MPI_Comm_rank() for an arbitrary process. */
static int rank_in_MPI_communicator (MPI_Comm subcomm, int global_rank)
MPI_Group world_group; /* Group associated with MPI_COMM_WORLD */
MPI_Group subgroup; /* Group associate with subcomm */
int subrank; /* global_rank's rank within subcomm */
MPI_Comm_group (MPI_COMM_WORLD, &world_group);
MPI_Comm_group (subcomm, &subgroup);
MPI_Group_translate_ranks (world_group, 1, &global_rank, subgroup, &subrank);
return subrank;
/* Map an arbitrary tag to within MPI's valid range of [0, mpi_tag_ub]. */
static ncptl_int map_tag_into_MPI_range (ncptl_int tag)
if (tag == NCPTL_INT_MIN)
/* Avoid taking the absolute value of NCPTL_INT_MIN. */
tag = 555666773LL; /* Arbitrary value */
tag = ncptl_func_abs (tag); /* Only nonnegatives values are allowed. */
if (mpi_tag_ub < NCPTL_INT_MAX)
tag %= mpi_tag_ub + 1;
return tag;
/* Given an array of task in/out booleans return an MPI
* communicator that represents the "in" tasks. */
static MPI_Comm define_MPI_communicator (char *procflags)
MPI_Comm *existing_comm; /* Previously defined MPI communicator */
MPI_Comm new_comm; /* Newly defined MPI communicator */
existing_comm = (MPI_Comm *) ncptl_set_find (communicators, (void *)procflags);
if (existing_comm)
return *existing_comm;
(void) MPI_Comm_split (MPI_COMM_WORLD, (int)procflags[physrank], physrank, &new_comm);
//(void) MPI_Errhandler_set (new_comm, mpi_error_handler);
ncptl_set_insert (communicators, (void *)procflags, (void *)&new_comm);
return define_MPI_communicator (procflags);
/* Return 1 if a sequence loop will take at least one trip. */
static int conc_seq_nonempty (LOOPBOUNDS *seq)
ncptl_int startval; /* Integer version of seq's startval element */
ncptl_int endval; /* Integer version of seq's endval element */
if (seq->integral) {
startval = seq->u.i.startval;
endval = seq->u.i.endval;
else {
startval = CONC_DBL2INT (seq->u.d.startval);
endval = CONC_DBL2INT (seq->u.d.endval);
switch (seq->comparator) {
case CONC_LEQ:
return startval <= endval;
case CONC_GEQ:
return startval >= endval;
default:
ncptl_fatal ("Internal error -- unknown comparator");
return -1; /* Appease idiotic compilers. */
/* Initialize a sequence loop. */
static void conc_seq_init (LOOPBOUNDS *seq)
seq->u.i.loopvar = seq->u.i.startval;
seq->u.i.prev_loopvar = seq->u.i.loopvar - 1;
else {
seq->u.d.loopvar = seq->u.d.startval;
seq->u.d.prev_loopvar = seq->u.d.loopvar - 1.0;
/* Return 1 if a sequence loop should continue, 0 when finished. */
static int conc_seq_continue (LOOPBOUNDS *seq)
LOOPBOUNDS seq_int; /* Integer equivalent of *seq */
if (seq->integral)
seq_int = *seq;
else {
seq_int.u.i.loopvar = CONC_DBL2INT (seq->u.d.loopvar);
seq_int.u.i.prev_loopvar = CONC_DBL2INT (seq->u.d.prev_loopvar);
seq_int.u.i.endval = CONC_DBL2INT (seq->u.d.endval);
if (seq_int.u.i.loopvar == seq_int.u.i.prev_loopvar)
return 0;
case CONC_LEQ:
return seq_int.u.i.loopvar <= seq_int.u.i.endval;
case CONC_GEQ:
return seq_int.u.i.loopvar >= seq_int.u.i.endval;
default:
/* Proceed to the next iteration of a sequence loop. */
static void conc_seq_next (LOOPBOUNDS *seq)
seq->u.i.prev_loopvar = seq->u.i.loopvar;
switch (seq->increment) {
case CONC_ADD:
seq->u.i.loopvar += seq->u.i.incval;
break;
case CONC_MULT:
seq->u.i.loopvar *= seq->u.i.incval;
break;
case CONC_DIV:
seq->u.i.loopvar /= seq->u.i.incval;
break;
default:
ncptl_fatal ("Internal error -- unknown incrementer");
else {
seq->u.d.prev_loopvar = seq->u.d.loopvar;
case CONC_ADD:
seq->u.d.loopvar += seq->u.d.incval;
break;
case CONC_MULT:
seq->u.d.loopvar *= seq->u.d.incval;
break;
case CONC_DIV:
seq->u.d.loopvar /= seq->u.d.incval;
break;
default:
/* Inhibit the compiler from complaining that
* certain variables are defined but not used.
* This function should never be called. */
static void conc_mark_variables_used (void)
conc_dummy_var.ni = var_bytes_received;
conc_dummy_var.ni = var_msgs_received;
conc_dummy_var.ni = var_bit_errors;
conc_dummy_var.ni = var_total_msgs;
conc_dummy_var.ni = var_msgs_sent;
conc_dummy_var.ni = var_bytes_sent;
conc_dummy_var.ni = var_num_tasks;
conc_dummy_var.ni = var_elapsed_usecs;
conc_dummy_var.ni = var_total_bytes;
conc_dummy_var.ni = pendingrecvbytes;
conc_dummy_var.ni = touch_region_size;
conc_dummy_var.vp = touch_region;
conc_dummy_var.i = within_time_loop;
conc_dummy_var.i = suppress_output;
rank_in_MPI_communicator (MPI_COMM_WORLD, 0);
/* Allocate a new event of a given type and return a pointer to it. */
static CONC_EVENT *conc_allocate_event (CONC_EVENT_TYPE type)
CONC_EVENT *newevent = (CONC_EVENT *) ncptl_queue_allocate (eventqueue);
newevent->type = type;
return newevent;
/* Declare an exit handler that gets called automatically when the
* program terminates, whether successfully or not. */
static void conc_exit_handler (void)
if (mpi_is_running)
MPI_Abort (MPI_COMM_WORLD, 1);
/* Initialize coNCePTuaL, the messaging layer, and this program itself. */
static void conc_initialize (int argc, char *argv[])
/* Variables needed by all C-based backends */
CONC_EVENT * eventlist; /* List of events to execute */
ncptl_int numevents; /* Number of entries in eventlist[] */
int help_only = 0; /* 1=User specified --help; save time by skipping ncptl_init() */
char * argv0 = strrchr(argv[0], '/') ? strrchr(argv[0], '/')+1 : argv[0]; /* Base name of the executable program */
int i; /* Generic loop variable */
/* Declare all of our command-line arguments. */
NCPTL_CMDLINE arguments[] = {
{ NCPTL_TYPE_STRING, NULL, "logfile", 'L', "Log-file template", {0}},
{ NCPTL_TYPE_INT, NULL, "reps", 'r', "Number of repetitions of each message size", {0}},
{ NCPTL_TYPE_INT, NULL, "maxbytes", 'm', "Maximum number of bytes to transmit", {0}}
/* Incorporate the complete coNCePTuaL source code as an array
// * for use by ncptl_log_write_prologue(). */
char *sourcecode[] = {
"# An all-pairs ping-pong latency test written in coNCePTuaL",
"# By Scott Pakin <pakin@lanl.gov>",
"Require language version \"1.5\".",
"# Parse the command line.",
"reps is \"Number of repetitions of each message size\" and comes from \"--reps\" or \"-r\" with default 1000.",
"maxbytes is \"Maximum number of bytes to transmit\" and comes from \"--maxbytes\" or \"-m\" with default 1M.",
"# Ensure that we have a peer with whom to communicate.",
"Assert that \"the latency test requires at least two tasks\" with num_tasks>=2.",
"# Perform the benchmark.",
"For each msgsize in {0}, {1, 2, 4, ..., maxbytes} {",
" for reps repetitions {",
" tasks ev such that ev is even reset their counters then",
" tasks ev such that ev is even send a msgsize byte message to task ev+1 then",
" tasks od such that od is odd send a msgsize byte message to task od-1 then",
" tasks ev such that ev is even log the msgsize as \"Bytes\" and",
" the median of elapsed_usecs/2 as \"1/2 RTT (usecs)\"",
" } then",
" tasks ev such that ev is even compute aggregates",
NULL
/* Variables specific to the c_mpi backend */
int num_tasks; /* int version of var_num_tasks needed by CODES_MPI_Comm_size() */
char * procflags; /* Array of 1s representing an all-task MPI communicator */
MPI_Comm comm_world = MPI_COMM_WORLD; /* Copy of MPI_COMM_WORLD that we can take the address of */
void * attr_val; /* Pointed to the value of MPI_TAG_UB */
int attr_flag = 0; /* true=MPI_TAG_UB was extracted; false=not extracted */
char log_key_str[128]; /* String representing the range of valid MPI tags */
/* As a special case, if the command line contains --help, then skip
* the coNCePTuaL initialization step. */
for (i=1; i<argc; i++)
if (!strcmp(argv[i], "--"))
break;
else
if (!strcmp(argv[i], "--help") || !strcmp(argv[i], "-?")) {
argv[1] = "-?"; /* Guaranteed to work, even with getopt() */
help_only = 1;
break;
/* Perform various initializations specific to the c_mpi backend. */
/* Initialize MPI. */
//(void) MPI_Init(&argc, &argv);
mpi_is_running = 1;
/* Initialize the coNCePTuaL run-time library. */
if (!help_only)
//ncptl_init (NCPTL_RUN_TIME_VERSION, argv[0]);
//(void) atexit (conc_exit_handler);
/* Initialize the communication routines needed by the c_mpi backend. */
//(void) MPI_Errhandler_create ((MPI_Handler_function *)handle_MPI_error, &mpi_error_handler);
//(void) MPI_Errhandler_set (MPI_COMM_WORLD, mpi_error_handler);
(void) CODES_MPI_Comm_rank(MPI_COMM_WORLD, &physrank);
(void) CODES_MPI_Comm_size(MPI_COMM_WORLD, &num_tasks);
var_num_tasks = (ncptl_int) num_tasks;
//(void) MPI_Comm_get_attr(MPI_COMM_WORLD, MPI_TAG_UB, &attr_val, &attr_flag);
mpi_tag_ub = (ncptl_int) (attr_flag ? *(int *)attr_val : 32767);
/* Generate and broadcast a UUID. */
//logfile_uuid = ncptl_log_generate_uuid();
//(void) CODES_MPI_Bcast ((void *)logfile_uuid, 37, MPI_CHAR, 0, MPI_COMM_WORLD);
/* Plug variables and default values into the NCPTL_CMDLINE structure. */
arguments[0].variable = (CMDLINE_VALUE *) &logfiletmpl;
arguments[1].variable = (CMDLINE_VALUE *) &var_reps;
arguments[1].defaultvalue.intval = 1000LL;
arguments[2].variable = (CMDLINE_VALUE *) &var_maxbytes;
arguments[2].defaultvalue.intval = 1048576LL;
//logfiletmpl_default = (char *) ncptl_malloc (strlen(argv0) + 15, 0);
//sprintf (logfiletmpl_default, "%s-%%p.log", argv0);
//arguments[0].defaultvalue.stringval = logfiletmpl_default;
/* Parse the command line. */
mpi_is_running = 0; /* Don't invoke MPI_Abort() after --help. */
ncptl_parse_command_line (argc, argv, arguments, sizeof(arguments)/sizeof(NCPTL_CMDLINE));
if (help_only)
ncptl_fatal ("Internal error in the c_generic backend: failed to exit after giving help");
mpi_is_running = 1;
/* Establish a mapping from (virtual) task IDs to (physical) ranks. */
procmap = ncptl_allocate_task_map (var_num_tasks);
virtrank = ncptl_physical_to_virtual (procmap, physrank);
/* Perform initializations specific to the c_mpi backend. */
//ncptl_log_add_comment ("MPI send routines", "MPI_Send() and CODES_MPI_Isend()");
//ncptl_log_add_comment ("MPI reduction operation", REDUCE_OPERATION_NAME);
//sprintf (log_key_str, "[0, %" NICS "]", mpi_tag_ub);
//ncptl_log_add_comment ("MPI tag range", log_key_str);
// /* Open the log file and write some standard prologue information to it. */
//logstate = ncptl_log_open (logfiletmpl, physrank);
////ncptl_log_write_prologue (logstate, argv[0], logfile_uuid, "c_mpi", "C + MPI",
//var_num_tasks,
//arguments, sizeof(arguments)/sizeof(NCPTL_CMDLINE),
//sourcecode);
//ncptl_free (logfile_uuid);
/* Allocate a variety of dynamically growing queues. */
eventqueue = ncptl_queue_init (sizeof (CONC_EVENT));
touchedqueue = ncptl_queue_init (sizeof (ncptl_int));
