Commit 2fb5c6de authored by Shane Snyder's avatar Shane Snyder
Replay tool performance patch from Phil
Hack to force replay tool to use one preallocated and initialized
I/O buffer for all I/O operations. Malloc'ing a new
(uninitialized) buffer for each I/O operation causes really poor
performance, likely due to page faults.
parent 3f1b2733
...@@ -24,7 +24,7 @@ ...@@ -24,7 +24,7 @@
#include "codes/quickhash.h" #include "codes/quickhash.h"
#include "codes/configuration.h" #include "codes/configuration.h"
#define DEBUG_PROFILING 1 #define DEBUG_PROFILING 0
/* hash table entry for looking up file descriptor of a workload file id */ /* hash table entry for looking up file descriptor of a workload file id */
struct file_info struct file_info
...@@ -195,6 +195,8 @@ int load_workload(char *conf_path, int rank) ...@@ -195,6 +195,8 @@ int load_workload(char *conf_path, int rank)
char* buf = NULL;
int main(int argc, char *argv[]) int main(int argc, char *argv[])
char *conf_path; char *conf_path;
...@@ -209,6 +211,7 @@ int main(int argc, char *argv[]) ...@@ -209,6 +211,7 @@ int main(int argc, char *argv[])
double load_start, load_end; double load_start, load_end;
int first_op = 1; int first_op = 1;
int ret = 0; int ret = 0;
int i;
/* parse command line args */ /* parse command line args */
parse_args(argc, argv, &conf_path, &replay_test_path); parse_args(argc, argv, &conf_path, &replay_test_path);
...@@ -257,6 +260,13 @@ int main(int argc, char *argv[]) ...@@ -257,6 +260,13 @@ int main(int argc, char *argv[])
goto error_exit; goto error_exit;
buf = malloc(16*1024*1024);
assert(buf);
for(i=0; i<16*1024*1024; i++)
buf[i] = '1';
/* synchronize before replay */ /* synchronize before replay */
MPI_Barrier(MPI_COMM_WORLD); MPI_Barrier(MPI_COMM_WORLD);
...@@ -330,7 +340,6 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -330,7 +340,6 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
int fildes; int fildes;
struct file_info *tmp_list = NULL; struct file_info *tmp_list = NULL;
struct qlist_head *hash_link = NULL; struct qlist_head *hash_link = NULL;
char *buf = NULL;
int ret; int ret;
#if DEBUG_PROFILING #if DEBUG_PROFILING
...@@ -485,6 +494,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -485,6 +494,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
tmp_list = qhash_entry(hash_link, struct file_info, hash_link); tmp_list = qhash_entry(hash_link, struct file_info, hash_link);
fildes = tmp_list->file_descriptor; fildes = tmp_list->file_descriptor;
#if 0
/* perform the write operation */ /* perform the write operation */
buf = malloc(replay_op.u.write.size); buf = malloc(replay_op.u.write.size);
if (!buf) if (!buf)
...@@ -492,8 +502,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -492,8 +502,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
fprintf(stderr, "No memory available for write buffer\n"); fprintf(stderr, "No memory available for write buffer\n");
return -1; return -1;
#endif
ret = pwrite(fildes, buf, replay_op.u.write.size, replay_op.u.write.offset); ret = pwrite(fildes, buf, replay_op.u.write.size, replay_op.u.write.offset);
#if 0
free(buf); free(buf);
#endif
if (ret < 0) if (ret < 0)
fprintf(stderr, "Rank %d failure on operation %lld [WRITE: %s]\n", fprintf(stderr, "Rank %d failure on operation %lld [WRITE: %s]\n",
...@@ -521,6 +534,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -521,6 +534,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
#if 0
buf = malloc(replay_op.u.read.size); buf = malloc(replay_op.u.read.size);
if (!buf) if (!buf)
...@@ -528,8 +542,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -528,8 +542,11 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
#endif
ret = pread(fildes, buf, replay_op.u.read.size, replay_op.u.read.offset); ret = pread(fildes, buf, replay_op.u.read.size, replay_op.u.read.offset);
#if 0
#endif
fprintf(stderr, "Rank %d failure on operation %lld [READ: %s]\n", fprintf(stderr, "Rank %d failure on operation %lld [READ: %s]\n",
Markdown is supported
0%
or
Please register or to comment
