Commit 2f89192a authored by Noah Wolfe's avatar Noah Wolfe Committed by Nikhil
Finished Squashing Warnings
parent 81ae794e
...@@ -54,7 +54,7 @@ long fattree_packet_gen = 0, fattree_packet_fin = 0; ...@@ -54,7 +54,7 @@ long fattree_packet_gen = 0, fattree_packet_fin = 0;
static double maxd(double a, double b) { return a < b ? b : a; } static double maxd(double a, double b) { return a < b ? b : a; }
// arrival rate // arrival rate
static double MEAN_INTERVAL=200.0; //static double MEAN_INTERVAL=200.0;
typedef struct fattree_param fattree_param; typedef struct fattree_param fattree_param;
/* annotation-specific parameters (unannotated entry occurs at the /* annotation-specific parameters (unannotated entry occurs at the
...@@ -262,7 +262,7 @@ struct switch_state ...@@ -262,7 +262,7 @@ struct switch_state
static tw_stime fattree_total_time = 0; static tw_stime fattree_total_time = 0;
static tw_stime fattree_max_latency = 0; static tw_stime fattree_max_latency = 0;
static tw_stime max_collective = 0; //static tw_stime max_collective = 0;
static long long total_hops = 0; static long long total_hops = 0;
...@@ -375,7 +375,7 @@ int get_base_port(switch_state *s, int from_term, int index); ...@@ -375,7 +375,7 @@ int get_base_port(switch_state *s, int from_term, int index);
/* returns the fattree switch lp type for lp registration */ /* returns the fattree switch lp type for lp registration */
static const tw_lptype* fattree_get_switch_lp_type(void); //static const tw_lptype* fattree_get_switch_lp_type(void);
/* returns the fattree message size */ /* returns the fattree message size */
static int fattree_get_msg_sz(void) static int fattree_get_msg_sz(void)
...@@ -1114,7 +1114,7 @@ void ft_packet_generate(ft_terminal_state * s, tw_bf * bf, fattree_message * msg ...@@ -1114,7 +1114,7 @@ void ft_packet_generate(ft_terminal_state * s, tw_bf * bf, fattree_message * msg
// msg->dest_terminal_id = msg->final_dest_gid; // msg->dest_terminal_id = msg->final_dest_gid;
if(msg->packet_ID == LLU(TRACK_PKT)) if(msg->packet_ID == LLU(TRACK_PKT))
printf("\n Packet %llu generated at terminal %d terminal_gid %llu dest_terminal_id %llu final_dest_gid %llu size %llu num chunks %llu \n", printf("\n Packet %llu generated at terminal %d terminal_gid %llu dest_terminal_id %llu final_dest_gid %llu size %llu num chunks %llu \n",
msg->packet_ID, s->terminal_id, lp->gid, LLU(msg->dest_terminal_id), LLU(msg->final_dest_gid), msg->packet_ID, s->terminal_id, LLU(lp->gid), LLU(msg->dest_terminal_id), LLU(msg->final_dest_gid),
LLU(msg->packet_size), LLU(num_chunks)); LLU(msg->packet_size), LLU(num_chunks));
for(uint64_t i = 0; i < num_chunks; i++) for(uint64_t i = 0; i < num_chunks; i++)
...@@ -1261,12 +1261,12 @@ void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1261,12 +1261,12 @@ void ft_packet_send(ft_terminal_state * s, tw_bf * bf, fattree_message * msg,
if(cur_entry != NULL && if(cur_entry != NULL &&
s->vc_occupancy + s->params->packet_size <= s->params->cn_vc_size) { s->vc_occupancy + s->params->packet_size <= s->params->cn_vc_size) {
bf->c3 = 1; bf->c3 = 1;
fattree_message *m; fattree_message *m_new;
ts = ts + g_tw_lookahead * tw_rand_unif(lp->rng); ts = ts + g_tw_lookahead * tw_rand_unif(lp->rng);
tw_event* e = model_net_method_event_new(lp->gid, ts, lp, FATTREE, e = model_net_method_event_new(lp->gid, ts, lp, FATTREE,
(void**)&m, NULL); (void**)&m_new, NULL);
m->type = T_SEND; m_new->type = T_SEND;
m->magic = fattree_terminal_magic_num; m_new->magic = fattree_terminal_magic_num;
tw_event_send(e); tw_event_send(e);
} else { } else {
bf->c4 = 1; bf->c4 = 1;
...@@ -1291,8 +1291,8 @@ void switch_packet_receive( switch_state * s, tw_bf * bf, ...@@ -1291,8 +1291,8 @@ void switch_packet_receive( switch_state * s, tw_bf * bf,
bf->c2 = 0; bf->c2 = 0;
bf->c3 = 0; bf->c3 = 0;
tw_event *e; // tw_event *e;
fattree_message *m; // fattree_message *m;
tw_stime ts; tw_stime ts;
//printf("[%d] Switch %d recv packet %d\n", lp->gid, msg->vc_index); //printf("[%d] Switch %d recv packet %d\n", lp->gid, msg->vc_index);
...@@ -1314,7 +1314,7 @@ void switch_packet_receive( switch_state * s, tw_bf * bf, ...@@ -1314,7 +1314,7 @@ void switch_packet_receive( switch_state * s, tw_bf * bf,
printf("\n Packet %llu arrived at switch %d switch_gid %llu dest_terminal_id %llu dest_term_local_id %llu final_dest_gid %llu output_port %d to_terminal %d\n", printf("\n Packet %llu arrived at switch %d switch_gid %llu dest_terminal_id %llu dest_term_local_id %llu final_dest_gid %llu output_port %d to_terminal %d\n",
msg->packet_ID, s->switch_id, lp->gid, LLU(msg->dest_terminal_id), LLU(dest_term_local_id), LLU(msg->final_dest_gid), msg->packet_ID, s->switch_id, LLU(lp->gid), LLU(msg->dest_terminal_id), LLU(dest_term_local_id), LLU(msg->final_dest_gid),
output_port, to_terminal); output_port, to_terminal);
fattree_message_list * cur_chunk = (fattree_message_list *)malloc( fattree_message_list * cur_chunk = (fattree_message_list *)malloc(
...@@ -1453,12 +1453,12 @@ void switch_packet_send( switch_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1453,12 +1453,12 @@ void switch_packet_send( switch_state * s, tw_bf * bf, fattree_message * msg,
cur_entry = s->pending_msgs[output_port]; cur_entry = s->pending_msgs[output_port];
if(cur_entry != NULL) { if(cur_entry != NULL) {
tw_event *e = tw_event_new(lp->gid, ts, lp); e = tw_event_new(lp->gid, ts, lp);
m = tw_event_data(e); m_new = tw_event_data(e);
m->type = S_SEND; m_new->type = S_SEND;
m->vc_index = output_port; m_new->vc_index = output_port;
//printf("[%d] switch send loop Send to %d\n", lp->gid, lp->gid); //printf("[%d] switch send loop Send to %d\n", lp->gid, lp->gid);
} else { } else {
...@@ -1473,7 +1473,7 @@ void switch_packet_send( switch_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1473,7 +1473,7 @@ void switch_packet_send( switch_state * s, tw_bf * bf, fattree_message * msg,
* event */ * event */
void switch_credit_send(switch_state * s, tw_bf * bf, fattree_message * msg, void switch_credit_send(switch_state * s, tw_bf * bf, fattree_message * msg,
tw_lp * lp, int sq) { tw_lp * lp, int sq) {
(void)bf;
tw_event * buf_e; tw_event * buf_e;
fattree_message * buf_msg; fattree_message * buf_msg;
...@@ -1481,7 +1481,7 @@ void switch_credit_send(switch_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1481,7 +1481,7 @@ void switch_credit_send(switch_state * s, tw_bf * bf, fattree_message * msg,
int dest = 0, type = S_BUFFER; int dest = 0, type = S_BUFFER;
int is_terminal = 0; int is_terminal = 0;
fattree_param *p = s->params; // fattree_param *p = s->params;
// Notify sender terminal about available buffer space // Notify sender terminal about available buffer space
if(msg->last_hop == TERMINAL) { if(msg->last_hop == TERMINAL) {
dest = msg->src_terminal_id; dest = msg->src_terminal_id;
...@@ -1671,8 +1671,8 @@ if(msg->packet_ID == LLU(TRACK_PKT)) ...@@ -1671,8 +1671,8 @@ if(msg->packet_ID == LLU(TRACK_PKT))
// Packet arrives and accumulate # queued // Packet arrives and accumulate # queued
// Find a queue with an empty buffer slot // Find a queue with an empty buffer slot
tw_event * e, * buf_e; tw_event * buf_e;
fattree_message * m, * buf_msg; fattree_message * buf_msg;
// NIC aggregation - should this be a separate function? // NIC aggregation - should this be a separate function?
...@@ -1843,7 +1843,7 @@ if(msg->packet_ID == LLU(TRACK_PKT)) ...@@ -1843,7 +1843,7 @@ if(msg->packet_ID == LLU(TRACK_PKT))
return; return;
if(tmp->num_chunks >= total_chunks) if(tmp->num_chunks >= (int)total_chunks)
bf->c7 = 1; bf->c7 = 1;
...@@ -1871,7 +1871,8 @@ if(msg->packet_ID == LLU(TRACK_PKT)) ...@@ -1871,7 +1871,8 @@ if(msg->packet_ID == LLU(TRACK_PKT))
/* expects dest_terminal_id to be a local ID not global ID */ /* expects dest_terminal_id to be a local ID not global ID */
int ft_get_output_port( switch_state * s, tw_bf * bf, fattree_message * msg, int ft_get_output_port( switch_state * s, tw_bf * bf, fattree_message * msg,
tw_lp * lp, int *out_off) { tw_lp * lp, int *out_off) {
(void)bf;
(void)lp;
int outport = -1; int outport = -1;
int start_port, end_port; int start_port, end_port;
fattree_param *p = s->params; fattree_param *p = s->params;
...@@ -1936,7 +1937,7 @@ int ft_get_output_port( switch_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1936,7 +1937,7 @@ int ft_get_output_port( switch_state * s, tw_bf * bf, fattree_message * msg,
int get_base_port(switch_state *s, int from_term, int index) { int get_base_port(switch_state *s, int from_term, int index) {
int return_port; int return_port;
if(s->switch_level == 2) { if(s->switch_level == 2) {
} else if(from_term || index < s->switch_id) { } else if(from_term || index < (int)s->switch_id) {
return_port = ((index - s->start_lneigh) * s->con_per_lneigh); return_port = ((index - s->start_lneigh) * s->con_per_lneigh);
} else { } else {
return_port = s->num_lcons; return_port = s->num_lcons;
...@@ -2004,7 +2005,7 @@ void fattree_terminal_final( ft_terminal_state * s, tw_lp * lp ) ...@@ -2004,7 +2005,7 @@ void fattree_terminal_final( ft_terminal_state * s, tw_lp * lp )
void fattree_switch_final(switch_state * s, tw_lp * lp) { void fattree_switch_final(switch_state * s, tw_lp * lp) {
if(s->unused) return; if(s->unused) return;
(void)lp;
rc_stack_destroy(s->st); rc_stack_destroy(s->st);
char *stats_file = getenv("TRACER_LINK_FILE"); char *stats_file = getenv("TRACER_LINK_FILE");
...@@ -2014,11 +2015,11 @@ void fattree_switch_final(switch_state * s, tw_lp * lp) { ...@@ -2014,11 +2015,11 @@ void fattree_switch_final(switch_state * s, tw_lp * lp) {
char file_name[512]; char file_name[512];
sprintf(file_name, "%s.%d", stats_file, rank); sprintf(file_name, "%s.%d", stats_file, rank);
FILE *fout = fopen(file_name, "a"); FILE *fout = fopen(file_name, "a");
//int result = flock(fileno(fout), LOCK_EX); //int result = flock(fileno(fout), LOCK_EX);
fprintf(fout, "%d %d ", s->switch_id, s->switch_level); fprintf(fout, "%d %d ", s->switch_id, s->switch_level);
for(int d = 0; d < s->num_cons; d++) { for(int d = 0; d < s->num_cons; d++) {
fprintf(fout, "%lld ", s->link_traffic[d]); fprintf(fout, "%llu ", LLU(s->link_traffic[d]));
fprintf(fout, "\n"); fprintf(fout, "\n");
//result = flock(fileno(fout), LOCK_UN); //result = flock(fileno(fout), LOCK_UN);
...@@ -2232,6 +2233,8 @@ void ft_terminal_rc_event_handler(ft_terminal_state * s, tw_bf * bf, ...@@ -2232,6 +2233,8 @@ void ft_terminal_rc_event_handler(ft_terminal_state * s, tw_bf * bf,
// model_net_event_rc2(lp, &msg->event_rc); // model_net_event_rc2(lp, &msg->event_rc);
// tw_rand_reverse_unif(lp->rng); // tw_rand_reverse_unif(lp->rng);
assert(tmp);
tmp->num_chunks--;
break; break;
...@@ -2380,10 +2383,10 @@ static const tw_lptype* fattree_get_cn_lp_type(void) ...@@ -2380,10 +2383,10 @@ static const tw_lptype* fattree_get_cn_lp_type(void)
return(&fattree_lps[0]); return(&fattree_lps[0]);
static const tw_lptype* fattree_get_switch_lp_type(void) /*static const tw_lptype* fattree_get_switch_lp_type(void)
return(&fattree_lps[1]); return(&fattree_lps[1]);
static void fattree_register(tw_lptype *base_type) { static void fattree_register(tw_lptype *base_type) {
lp_type_register(LP_CONFIG_NM, base_type); lp_type_register(LP_CONFIG_NM, base_type);
Markdown is supported
0% or
Please register or to comment
