Commit 2f3b89ad authored by Misbah Mubarak's avatar Misbah Mubarak
Removing printf warnings, unused functions, adding list of contributors
parent 703f0b01
...@@ -194,7 +194,7 @@ struct codes_workload_op ...@@ -194,7 +194,7 @@ struct codes_workload_op
/* TODO: not sure why source rank is here */ /* TODO: not sure why source rank is here */
int source_rank;/* source rank of MPI send message */ int source_rank;/* source rank of MPI send message */
int dest_rank; /* dest rank of MPI send message */ int dest_rank; /* dest rank of MPI send message */
uint64_t num_bytes; /* number of bytes to be transferred over the network */ int64_t num_bytes; /* number of bytes to be transferred over the network */
int16_t data_type; /* MPI data type to be matched with the recv */ int16_t data_type; /* MPI data type to be matched with the recv */
int count; /* number of elements to be received */ int count; /* number of elements to be received */
int tag; /* tag of the message */ int tag; /* tag of the message */
...@@ -204,7 +204,7 @@ struct codes_workload_op ...@@ -204,7 +204,7 @@ struct codes_workload_op
int source_rank;/* source rank of MPI recv message */ int source_rank;/* source rank of MPI recv message */
int dest_rank;/* dest rank of MPI recv message */ int dest_rank;/* dest rank of MPI recv message */
int16_t data_type; /* MPI data type to be matched with the send */ int16_t data_type; /* MPI data type to be matched with the send */
int count; /* number of elements to be sent */ int count; /* number of elements to be sent */
...@@ -2431,7 +2431,7 @@ dragonfly_terminal_final( terminal_state * s, ...@@ -2431,7 +2431,7 @@ dragonfly_terminal_final( terminal_state * s,
if(!s->terminal_id) if(!s->terminal_id)
written = sprintf(s->output_buf, "# Format <LP id> <Terminal ID> <Total Data Size> <Aggregate packet latency> <# Flits/Packets finished> <Avg hops> <Busy Time>"); written = sprintf(s->output_buf, "# Format <LP id> <Terminal ID> <Total Data Size> <Aggregate packet latency> <# Flits/Packets finished> <Avg hops> <Busy Time>");
written += sprintf(s->output_buf + written, "\n %llu %u %lld %lf %ld %lf %lf", written += sprintf(s->output_buf + written, "\n %llu %u %"PRId64" %lf %ld %lf %lf",
LLU(lp->gid), s->terminal_id, s->total_msg_size, (double)s->total_time/s->finished_packets, LLU(lp->gid), s->terminal_id, s->total_msg_size, (double)s->total_time/s->finished_packets,
s->finished_packets, (double)s->total_hops/s->finished_chunks, s->finished_packets, (double)s->total_hops/s->finished_chunks,
s->busy_time); s->busy_time);
...@@ -1027,7 +1027,7 @@ static void dimension_order_routing( nodes_state * s, ...@@ -1027,7 +1027,7 @@ static void dimension_order_routing( nodes_state * s,
int * dir ) int * dir )
int dest[s->params->n_dims]; int dest[s->params->n_dims];
int dest_id; int dest_id = -1;
/* dummys - check later */ /* dummys - check later */
*dim = -1; *dim = -1;
...@@ -327,7 +327,7 @@ void codes_workload_print_op( ...@@ -327,7 +327,7 @@ void codes_workload_print_op(
break; break;
case CODES_WK_SEND: case CODES_WK_SEND:
fprintf(f, "op: app:%d rank:%d type:send " fprintf(f, "op: app:%d rank:%d type:send "
"src:%d dst:%d bytes:%llu type:%d count:%d tag:%d " "src:%d dst:%d bytes:%"PRIu64" type:%d count:%d tag:%d "
"start:%.5e end:%.5e\n", "start:%.5e end:%.5e\n",
app_id, rank, app_id, rank,
op->u.send.source_rank, op->u.send.dest_rank, op->u.send.source_rank, op->u.send.dest_rank,
...@@ -337,7 +337,7 @@ void codes_workload_print_op( ...@@ -337,7 +337,7 @@ void codes_workload_print_op(
break; break;
case CODES_WK_RECV: case CODES_WK_RECV:
fprintf(f, "op: app:%d rank:%d type:recv " fprintf(f, "op: app:%d rank:%d type:recv "
op->u.recv.source_rank, op->u.recv.dest_rank, op->u.recv.source_rank, op->u.recv.dest_rank,
...@@ -347,7 +347,7 @@ void codes_workload_print_op( ...@@ -347,7 +347,7 @@ void codes_workload_print_op(
break; break;
case CODES_WK_ISEND: case CODES_WK_ISEND:
fprintf(f, "op: app:%d rank:%d type:isend " fprintf(f, "op: app:%d rank:%d type:isend "
...@@ -357,7 +357,7 @@ void codes_workload_print_op( ...@@ -357,7 +357,7 @@ void codes_workload_print_op(
break; break;
case CODES_WK_IRECV: case CODES_WK_IRECV:
fprintf(f, "op: app:%d rank:%d type:irecv " fprintf(f, "op: app:%d rank:%d type:irecv "
...@@ -109,12 +109,12 @@ static inline double time_to_us_lf(dumpi_clock t){ ...@@ -109,12 +109,12 @@ static inline double time_to_us_lf(dumpi_clock t){
static inline double time_to_ns_lf(dumpi_clock t){ static inline double time_to_ns_lf(dumpi_clock t){
return (double) t.sec * 1e9 + (double) t.nsec; return (double) t.sec * 1e9 + (double) t.nsec;
static int32_t get_unique_req_id(int32_t request_id) /*static int32_t get_unique_req_id(int32_t request_id)
uint32_t pc = 0, pb = 0; uint32_t pc = 0, pb = 0;
bj_hashlittle2(&request_id, sizeof(int32_t), &pc, &pb); bj_hashlittle2(&request_id, sizeof(int32_t), &pc, &pb);
return pc; return pc;
/*static inline double time_to_s_lf(dumpi_clock t){ /*static inline double time_to_s_lf(dumpi_clock t){
return (double) t.sec + (double) t.nsec / 1e9; return (double) t.sec + (double) t.nsec / 1e9;
Markdown is supported
0% or
Please register or to comment
