Commit 2d6a1673 authored by Shane Snyder's avatar Shane Snyder
small changes to darshan workload api as well as tests Makefile
parent 4c8ccf14
...@@ -76,21 +76,21 @@ struct codes_workload_op ...@@ -76,21 +76,21 @@ struct codes_workload_op
int root; /* root rank */ int root; /* root rank */
} barrier; } barrier;
struct { struct {
int file_id; /* integer identifier for the file */ uint64_t file_id; /* integer identifier for the file */
int create_flag; /* file must be created, not just opened */ int create_flag; /* file must be created, not just opened */
} open; } open;
struct { struct {
int file_id; /* file to operate on */ uint64_t file_id; /* file to operate on */
off_t offset; /* offset and size */ off_t offset; /* offset and size */
size_t size; size_t size;
} write; } write;
struct { struct {
} read; } read;
struct { struct {
} close; } close;
}u; }u;
...@@ -73,6 +73,9 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -73,6 +73,9 @@ static int darshan_io_workload_load(const char *params, int rank)
int ret; int ret;
struct rank_events_context *new = NULL; struct rank_events_context *new = NULL;
if (!event_file)
return -1;
/* allocate a new event context for this rank */ /* allocate a new event context for this rank */
new = malloc(sizeof(*new)); new = malloc(sizeof(*new));
if (!new) if (!new)
...@@ -362,7 +365,7 @@ static struct codes_workload_op darshan_event_to_codes_workload_op(struct darsha ...@@ -362,7 +365,7 @@ static struct codes_workload_op darshan_event_to_codes_workload_op(struct darsha
struct codes_workload_op codes_op; struct codes_workload_op codes_op;
switch(event.type) switch (event.type)
case POSIX_OPEN: case POSIX_OPEN:
codes_op.op_type = CODES_WK_OPEN; codes_op.op_type = CODES_WK_OPEN;
...@@ -15,9 +15,10 @@ ...@@ -15,9 +15,10 @@
extern struct codes_workload_method test_workload_method; extern struct codes_workload_method test_workload_method;
extern struct codes_workload_method bgp_io_workload_method; extern struct codes_workload_method bgp_io_workload_method;
extern struct codes_workload_method darshan_io_workload_method;
static struct codes_workload_method *method_array[] = static struct codes_workload_method *method_array[] =
{&test_workload_method, &bgp_io_workload_method, NULL}; {&test_workload_method, &bgp_io_workload_method, &darshan_io_workload_method, NULL};
/* This shim layer is responsible for queueing up reversed operations and /* This shim layer is responsible for queueing up reversed operations and
* re-issuing them so that the underlying workload generator method doesn't * re-issuing them so that the underlying workload generator method doesn't
check_PROGRAMS += tests/lp-io-test \ check_PROGRAMS += tests/lp-io-test \
tests/workload/codes-workload-test tests/workload/codes-workload-test \
tests/workload/codes-workload-mpi-replay
TESTS += tests/lp-io-test.sh \ TESTS += tests/lp-io-test.sh \
tests/workload/codes-workload-test.sh tests/workload/codes-workload-test.sh
...@@ -14,6 +15,10 @@ tests_lp_io_test_LDADD = $(testlib) ${ROSS_LIBS} ...@@ -14,6 +15,10 @@ tests_lp_io_test_LDADD = $(testlib) ${ROSS_LIBS}
tests_lp_io_test_LDFLAGS = ${ROSS_LDFLAGS} tests_lp_io_test_LDFLAGS = ${ROSS_LDFLAGS}
tests_lp_io_test_SOURCES = tests/lp-io-test.c tests_lp_io_test_SOURCES = tests/lp-io-test.c
tests_workload_codes_workload_mpi_replay_LDADD = $(testlib) ${ROSS_LIBS}
tests_workload_codes_workload_mpi_replay_LDFLAGS = ${ROSS_LDFLAGS}
tests_workload_codes_workload_mpi_replay_SOURCES = tests/workload/codes-workload-mpi-replay.c
tests_workload_codes_workload_test_LDADD = $(testlib) ${ROSS_LIBS} tests_workload_codes_workload_test_LDADD = $(testlib) ${ROSS_LIBS}
tests_workload_codes_workload_test_LDFLAGS = ${ROSS_LDFLAGS} tests_workload_codes_workload_test_LDFLAGS = ${ROSS_LDFLAGS}
tests_workload_codes_workload_test_SOURCES = \ tests_workload_codes_workload_test_SOURCES = \
...@@ -21,4 +26,4 @@ tests_workload_codes_workload_test_SOURCES = \ ...@@ -21,4 +26,4 @@ tests_workload_codes_workload_test_SOURCES = \
tests/workload/codes-workload-test-svr-lp.c \ tests/workload/codes-workload-test-svr-lp.c \
tests/workload/codes-workload-test-svr-lp.h \ tests/workload/codes-workload-test-svr-lp.h \
tests/workload/codes-workload-test-cn-lp.c \ tests/workload/codes-workload-test-cn-lp.c \
tests/workload/codes-workload-test-cn-lp.h tests/workload/codes-workload-test-cn-lp.h
Markdown is supported
0%
or
Please register or to comment
