GitLab maintenance scheduled for Tomorrow, 2020-08-11, from 17:00 to 18:00 CT - Services will be unavailable during this time.
Commit 2caf6c9c authored by Noah Wolfe's avatar Noah Wolfe Committed by Nikhil
Created fat tree synthetic workload .c and .conf files from Dragonfly template
parent 56e896e4
LPGROUPS
MODELNET_GRP
repetitions="36";
server="2";
modelnet_fattree="2";
fattree_switch="1";
PARAMS
ft_type="0"; # Only appears to be one type (type=0) in fattree.c
num_levels="2"; # Must be 1 < num_levels < 4
switch_count="2,4"; # Some sort of csv string. I'm thinking it's the number of switches per level
switch_radix="4,4"; # Another csv string. I'm thinking it's the radix of the switches per level. All switches within same level have same radix
packet_size="512";
modelnet_order=( "fattree" );
# scheduler options
modelnet_scheduler="fcfs";
# chunk_size="32";
# modelnet_scheduler="round-robin";
# num_vcs="1";
vc_size="16384";
cn_vc_size="16384";
link_bandwidth="5";
cn_bandwidth="5";
message_size="512";
# routing="minimal";
router_delay="50";
soft_delay="1000";
* Copyright (C) 2015 University of Chicago.
* See COPYRIGHT notice in top-level directory.
* The test program generates some synthetic traffic patterns for the model-net network models.
* currently it only support the dragonfly network model uniform random and nearest neighbor traffic patterns.
#include "codes/model-net.h"
#include "codes/lp-io.h"
#include "codes/codes.h"
#include "codes/codes_mapping.h"
#include "codes/configuration.h"
#include "codes/lp-type-lookup.h"
#define PAYLOAD_SZ 512
static int net_id = 0;
static int num_routers = 0;
static int num_servers = 0;
static int offset = 2;
static int traffic = 1;
static double arrival_time = 1000.0;
/* whether to pull instead of push */
static int do_pull = 0;
static int num_servers_per_rep = 0;
static int num_routers_per_grp = 0;
static int num_nodes_per_grp = 0;
static int num_reps = 0;
static int num_groups = 0;
static int num_nodes = 0;
typedef struct svr_msg svr_msg;
typedef struct svr_state svr_state;
/* global variables for codes mapping */
static char group_name[MAX_NAME_LENGTH];
static char lp_type_name[MAX_NAME_LENGTH];
static int group_index, lp_type_index, rep_id, offset;
/* type of events */
enum svr_event
KICKOFF, /* kickoff event */
REMOTE, /* remote event */
LOCAL /* local event */
/* type of synthetic traffic */
enum TRAFFIC
UNIFORM = 1, /* sends message to a randomly selected node */
NEAREST_GROUP = 2, /* sends message to the node connected to the neighboring router */
NEAREST_NEIGHBOR = 3 /* sends message to the next node (potentially connected to the same router) */
struct svr_state
int msg_sent_count; /* requests sent */
int msg_recvd_count; /* requests recvd */
int local_recvd_count; /* number of local messages received */
tw_stime start_ts; /* time that we started sending requests */
tw_stime end_ts; /* time that we ended sending requests */
struct svr_msg
enum svr_event svr_event_type;
tw_lpid src; /* source of this request or ack */
int incremented_flag; /* helper for reverse computation */
static void svr_init(
svr_state * ns,
tw_lp * lp);
static void svr_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp);
static void svr_rev_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp);
static void svr_finalize(
svr_state * ns,
tw_lp * lp);
tw_lptype svr_lp = {
(init_f) svr_init,
(pre_run_f) NULL,
(event_f) svr_event,
(revent_f) svr_rev_event,
(final_f) svr_finalize,
(map_f) codes_mapping,
sizeof(svr_state),
const tw_optdef app_opt [] =
TWOPT_GROUP("Model net synthetic traffic " ),
TWOPT_UINT("traffic", traffic, "UNIFORM RANDOM=1, NEAREST NEIGHBOR=2 "),
TWOPT_STIME("arrival_time", arrival_time, "INTER-ARRIVAL TIME"),
TWOPT_END()
const tw_lptype* svr_get_lp_type()
return(&svr_lp);
static void svr_add_lp_type()
lp_type_register("server", svr_get_lp_type());
static void issue_event(
svr_state * ns,
tw_lp * lp)
tw_event *e;
svr_msg *m;
tw_stime kickoff_time;
/* each server sends a dummy event to itself that will kick off the real
* simulation
/* skew each kickoff event slightly to help avoid event ties later on */
kickoff_time = g_tw_lookahead + arrival_time + tw_rand_exponential(lp->rng, (double)arrival_time/100);
e = tw_event_new(lp->gid, kickoff_time, lp);
m = tw_event_data(e);
m->svr_event_type = KICKOFF;
tw_event_send(e);
svr_state * ns,
tw_lp * lp)
issue_event(ns, lp);
return;
static void handle_kickoff_rev_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
ns->msg_sent_count--;
model_net_event_rc(net_id, lp, PAYLOAD_SZ);
static void handle_kickoff_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
char* anno;
tw_lpid local_dest = -1, global_dest = -1;
svr_msg * m_local = malloc(sizeof(svr_msg));
svr_msg * m_remote = malloc(sizeof(svr_msg));
m_local->svr_event_type = LOCAL;
m_local->src = lp->gid;
memcpy(m_remote, m_local, sizeof(svr_msg));
m_remote->svr_event_type = REMOTE;
// assert(net_id == DRAGONFLY); /* only supported for dragonfly model right now. */
ns->start_ts = tw_now(lp);
codes_mapping_get_lp_info(lp->gid, group_name, &group_index, lp_type_name, &lp_type_index, anno, &rep_id, &offset);
/* in case of uniform random traffic, send to a random destination. */
if(traffic == UNIFORM)
local_dest = tw_rand_integer(lp->rng, 0, num_nodes - 1);
// printf("\n LP %ld sending to %d ", lp->gid, local_dest);
/* else if(traffic == NEAREST_GROUP)
local_dest = (rep_id * 2 + offset + num_nodes_per_grp) % num_nodes;
// printf("\n LP %ld sending to %ld num nodes %d ", rep_id * 2 + offset, local_dest, num_nodes);
else if(traffic == NEAREST_NEIGHBOR)
local_dest = (rep_id * 2 + offset + 2) % num_nodes;
*/ assert(local_dest < num_nodes);
codes_mapping_get_lp_id(group_name, lp_type_name, anno, 1, local_dest / num_servers_per_rep, local_dest % num_servers_per_rep, &global_dest);
ns->msg_sent_count++;
model_net_event(net_id, "test", global_dest, PAYLOAD_SZ, 0.0, sizeof(svr_msg), (const void*)m_remote, sizeof(svr_msg), (const void*)m_local, lp);
return;
static void handle_remote_rev_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
ns->msg_recvd_count--;
static void handle_remote_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
ns->msg_recvd_count++;
static void handle_local_rev_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
ns->local_recvd_count--;
static void handle_local_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
ns->local_recvd_count++;
/* convert ns to seconds */
static tw_stime ns_to_s(tw_stime ns)
return(ns / (1000.0 * 1000.0 * 1000.0));
/* convert seconds to ns */
static tw_stime s_to_ns(tw_stime ns)
return(ns * (1000.0 * 1000.0 * 1000.0));
svr_state * ns,
tw_lp * lp)
ns->end_ts = tw_now(lp);
printf("server %llu recvd %d bytes in %f seconds, %f MiB/s sent_count %d recvd_count %d local_count %d \n", (unsigned long long)lp->gid, PAYLOAD_SZ*ns->msg_recvd_count, ns_to_s(ns->end_ts-ns->start_ts),
((double)(PAYLOAD_SZ*ns->msg_sent_count)/(double)(1024*1024)/ns_to_s(ns->end_ts-ns->start_ts)), ns->msg_sent_count, ns->msg_recvd_count, ns->local_recvd_count);
return;
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
switch (m->svr_event_type)
case REMOTE:
handle_remote_rev_event(ns, b, m, lp);
break;
case LOCAL:
handle_local_rev_event(ns, b, m, lp);
break;
case KICKOFF:
handle_kickoff_rev_event(ns, b, m, lp);
break;
default:
assert(0);
break;
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
case REMOTE:
handle_remote_event(ns, b, m, lp);
break;
case LOCAL:
handle_local_event(ns, b, m, lp);
break;
case KICKOFF:
handle_kickoff_event(ns, b, m, lp);
break;
default:
printf("\n Invalid message type %d ", m->svr_event_type);
assert(0);
break;
int main(
int argc,
char **argv)
int nprocs;
int rank;
int num_nets;
int *net_ids;
char* anno;
lp_io_handle handle;
tw_opt_add(app_opt);
tw_init(&argc, &argv);
offset = 1;
if(argc < 2)
printf("\n Usage: mpirun <args> --sync=2/3 mapping_file_name.conf (optional --nkp) ");
MPI_Finalize();
return 0;
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
configuration_load(argv[2], MPI_COMM_WORLD, &config);
model_net_register();
svr_add_lp_type();
codes_mapping_setup();
net_ids = model_net_configure(&num_nets);
assert(num_nets==1);
net_id = *net_ids;
free(net_ids);
if(net_id != DRAGONFLY)
printf("\n The test works with dragonfly model configuration only! ");
MPI_Finalize();
return 0;
num_servers_per_rep = codes_mapping_get_lp_count("MODELNET_GRP", 1, "server",
NULL, 1);
configuration_get_value_int(&config, "PARAMS", "num_routers", anno, &num_routers_per_grp);
num_groups = (num_routers_per_grp * (num_routers_per_grp/2) + 1);
num_nodes = num_groups * num_routers_per_grp * (num_routers_per_grp / 2);
num_nodes_per_grp = num_routers_per_grp * (num_routers_per_grp / 2);
if(lp_io_prepare("modelnet-test", LP_IO_UNIQ_SUFFIX, &handle, MPI_COMM_WORLD) < 0)
return(-1);
tw_run();
model_net_report_stats(net_id);
if(lp_io_flush(handle, MPI_COMM_WORLD) < 0)
return(-1);
tw_end();
return 0;
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
* vim: ft=c ts=8 sts=4 sw=4 expandtab
Markdown is supported
0% or
Please register or to comment
