Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
2a169880
Commit
2a169880
authored
Jan 08, 2014
by
Jonathan Jenkins
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
added experimental lp-io reverse computation support
parent
21b03940
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
with
51 additions
and
0 deletions
+51
-0
codes/lp-io.h
codes/lp-io.h
+5
-0
src/util/lp-io.c
src/util/lp-io.c
+46
-0
No files found.
codes/lp-io.h
View file @
2a169880
@@ -21,6 +21,11 @@ int lp_io_prepare(char *directory, int flags, lp_io_handle* handle, MPI_Comm com
/* to be called within LPs to store a block of data */
int
lp_io_write
tw_lpid
gid
char
identifier
int
size
void
buffer
int
lp_io_write
tw_lpid
gid
char
identifier
int
size
void
buffer
/* undo the immediately preceding write for the given LP
* (hack for logging/testing optimistic mode, not recommended for general use)
int
lp_io_write_rev
tw_lpid
gid
char
identifier
/* to be called (collectively) after tw_run() to flush data to disk */
int
lp_io_flush
lp_io_handle
handle
MPI_Comm
comm
int
lp_io_flush
lp_io_handle
handle
MPI_Comm
comm
src/util/lp-io.c
View file @
2a169880
@@ -100,6 +100,52 @@ int lp_io_write(tw_lpid gid, char* identifier, int size, void* buffer)
return
0
return
0
int
lp_io_write_rev
tw_lpid
gid
char
identifier
struct
identifier
id
struct
io_buffer
buf
buf_prev
/* find given identifier */
if
strlen
identifier
32
fprintf
stderr
"Error: identifier %s too big.
\n
identifier
return
1
id
identifiers
while
id
strcmp
identifier
id
identifier
0
id
id
next
if
id
fprintf
stderr
"Error: identifier %s not found on reverse.
\n
identifier
return
1
/* attempt to find previous LP's write. This is made easier by the fact
* that the list is stored newest-to-oldest */
buf
id
buffers
buf_prev
NULL
while
buf
if
buf
gid
gid
break
buf_prev
buf
buf
buf
next
if
buf
fprintf
stderr
"Error: no lp-io write buffer found for LP %lu (reverse write)
\n
gid
return
1
id
buffers_count
/* remove the buffer from the list
* (NULLs for end-of-list are preserved) */
if
buf
id
buffers
/* buf is head of list */
id
buffers
buf
next
else
/* buf is in list, has a previous element */
buf_prev
next
buf
next
free
buf
buffer
free
buf
return
0
int
lp_io_prepare
char
directory
int
flags
lp_io_handle
handle
MPI_Comm
comm
int
lp_io_prepare
char
directory
int
flags
lp_io_handle
handle
MPI_Comm
comm
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
