Commit 22575287 authored by Neil McGlohon's avatar Neil McGlohon
Dragonfly Plus: Add synth workload
parent eb8912ec
...@@ -71,11 +71,11 @@ typedef struct mn_stats mn_stats; ...@@ -71,11 +71,11 @@ typedef struct mn_stats mn_stats;
X(DRAGONFLY_ROUTER, "modelnet_dragonfly_router", "dragonfly_router", &dragonfly_router_method)\ X(DRAGONFLY_ROUTER, "modelnet_dragonfly_router", "dragonfly_router", &dragonfly_router_method)\
X(DRAGONFLY_CUSTOM, "modelnet_dragonfly_custom", "dragonfly_custom", &dragonfly_custom_method)\ X(DRAGONFLY_CUSTOM, "modelnet_dragonfly_custom", "dragonfly_custom", &dragonfly_custom_method)\
X(DRAGONFLY_CUSTOM_ROUTER, "modelnet_dragonfly_custom_router", "dragonfly_custom_router", &dragonfly_custom_router_method)\ X(DRAGONFLY_CUSTOM_ROUTER, "modelnet_dragonfly_custom_router", "dragonfly_custom_router", &dragonfly_custom_router_method)\
X(DRAGONFLY_PLUS, "modelnet_dragonfly_plus", "dragonfly_plus", &dragonfly_plus_method)\
X(DRAGONFLY_PLUS_ROUTER, "modelnet_dragonfly_plus_router", "dragonfly_plus_router", &dragonfly_plus_router_method)\
X(LOGGP, "modelnet_loggp", "loggp", &loggp_method)\ X(LOGGP, "modelnet_loggp", "loggp", &loggp_method)\
X(EXPRESS_MESH, "modelnet_express_mesh", "express_mesh", &express_mesh_method)\ X(EXPRESS_MESH, "modelnet_express_mesh", "express_mesh", &express_mesh_method)\
X(EXPRESS_MESH_ROUTER, "modelnet_express_mesh_router", "express_mesh_router", &express_mesh_router_method)\ X(EXPRESS_MESH_ROUTER, "modelnet_express_mesh_router", "express_mesh_router", &express_mesh_router_method)\
X(MAX_NETS, NULL, NULL, NULL) X(MAX_NETS, NULL, NULL, NULL)
#define X(a,b,c,d) a, #define X(a,b,c,d) a,
* Copyright (C) 2015 University of Chicago.
* See COPYRIGHT notice in top-level directory.
* The test program generates some synthetic traffic patterns for the model-net network models.
* currently it only support the dragonfly network model uniform random and nearest neighbor traffic patterns.
#include "codes/model-net.h"
#include "codes/lp-io.h"
#include "codes/codes.h"
#include "codes/codes_mapping.h"
#include "codes/configuration.h"
#include "codes/lp-type-lookup.h"
#define PAYLOAD_SZ 2048
static int net_id = 0;
static int traffic = 1;
static double arrival_time = 1000.0;
/* whether to pull instead of push */
static int num_servers_per_rep = 0;
static int num_routers_per_grp = 0;
static int num_nodes_per_grp = 0;
static int num_nodes_per_cn = 0;
static int num_groups = 0;
static unsigned long long num_nodes = 0;
static char lp_io_dir[256] = {'\0'};
static lp_io_handle io_handle;
static unsigned int lp_io_use_suffix = 0;
static int do_lp_io = 0;
static int num_msgs = 20;
static tw_stime sampling_interval = 800000;
static tw_stime sampling_end_time = 1600000;
typedef struct svr_msg svr_msg;
typedef struct svr_state svr_state;
/* global variables for codes mapping */
static char group_name[MAX_NAME_LENGTH];
static char lp_type_name[MAX_NAME_LENGTH];
static int group_index, lp_type_index, rep_id, offset;
/* type of events */
enum svr_event
KICKOFF, /* kickoff event */
REMOTE, /* remote event */
LOCAL /* local event */
/* type of synthetic traffic */
enum TRAFFIC
UNIFORM = 1, /* sends message to a randomly selected node */
NEAREST_GROUP = 2, /* sends message to the node connected to the neighboring router */
NEAREST_NEIGHBOR = 3 /* sends message to the next node (potentially connected to the same router) */
struct svr_state
int msg_sent_count; /* requests sent */
int msg_recvd_count; /* requests recvd */
int local_recvd_count; /* number of local messages received */
tw_stime start_ts; /* time that we started sending requests */
tw_stime end_ts; /* time that we ended sending requests */
struct svr_msg
enum svr_event svr_event_type;
tw_lpid src; /* source of this request or ack */
int incremented_flag; /* helper for reverse computation */
model_net_event_return event_rc;
static void svr_init(
svr_state * ns,
tw_lp * lp);
static void svr_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp);
static void svr_rev_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp);
static void svr_finalize(
svr_state * ns,
tw_lp * lp);
tw_lptype svr_lp = {
(init_f) svr_init,
(pre_run_f) NULL,
(event_f) svr_event,
(revent_f) svr_rev_event,
(commit_f) NULL,
(final_f) svr_finalize,
(map_f) codes_mapping,
sizeof(svr_state),
const tw_optdef app_opt [] =
TWOPT_GROUP("Model net synthetic traffic " ),
TWOPT_UINT("traffic", traffic, "UNIFORM RANDOM=1, NEAREST NEIGHBOR=2 "),
TWOPT_UINT("num_messages", num_msgs, "Number of messages to be generated per terminal "),
TWOPT_STIME("sampling-interval", sampling_interval, "the sampling interval "),
TWOPT_STIME("sampling-end-time", sampling_end_time, "sampling end time "),
TWOPT_STIME("arrival_time", arrival_time, "INTER-ARRIVAL TIME"),
TWOPT_CHAR("lp-io-dir", lp_io_dir, "Where to place io output (unspecified -> no output"),
TWOPT_UINT("lp-io-use-suffix", lp_io_use_suffix, "Whether to append uniq suffix to lp-io directory (default 0)"),
TWOPT_END()
const tw_lptype* svr_get_lp_type()
return(&svr_lp);
static void svr_add_lp_type()
lp_type_register("nw-lp", svr_get_lp_type());
static void issue_event(
svr_state * ns,
tw_lp * lp)
(void)ns;
tw_event *e;
svr_msg *m;
tw_stime kickoff_time;
/* each server sends a dummy event to itself that will kick off the real
* simulation
/* skew each kickoff event slightly to help avoid event ties later on */
kickoff_time = 1.1 * g_tw_lookahead + tw_rand_exponential(lp->rng, arrival_time);
e = tw_event_new(lp->gid, kickoff_time, lp);
m = tw_event_data(e);
m->svr_event_type = KICKOFF;
tw_event_send(e);
svr_state * ns,
tw_lp * lp)
ns->start_ts = 0.0;
issue_event(ns, lp);
return;
static void handle_kickoff_rev_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
if(m->incremented_flag)
return;
if(b->c1)
tw_rand_reverse_unif(lp->rng);
model_net_event_rc2(lp, &m->event_rc);
ns->msg_sent_count--;
static void handle_kickoff_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
if(ns->msg_sent_count >= num_msgs)
m->incremented_flag = 1;
return;
m->incremented_flag = 0;
char anno[MAX_NAME_LENGTH];
tw_lpid local_dest = -1, global_dest = -1;
svr_msg * m_local = malloc(sizeof(svr_msg));
svr_msg * m_remote = malloc(sizeof(svr_msg));
m_local->svr_event_type = LOCAL;
m_local->src = lp->gid;
memcpy(m_remote, m_local, sizeof(svr_msg));
m_remote->svr_event_type = REMOTE;
assert(net_id == DRAGONFLY || net_id == DRAGONFLY_PLUS || net_id == DRAGONFLY_CUSTOM); /* only supported for dragonfly model right now. */
ns->start_ts = tw_now(lp);
codes_mapping_get_lp_info(lp->gid, group_name, &group_index, lp_type_name, &lp_type_index, anno, &rep_id, &offset);
int local_id = codes_mapping_get_lp_relative_id(lp->gid, 0, 0);
/* in case of uniform random traffic, send to a random destination. */
if(traffic == UNIFORM)
b->c1 = 1;
local_dest = tw_rand_integer(lp->rng, 0, num_nodes - 1);
else if(traffic == NEAREST_GROUP)
local_dest = (local_id + num_nodes_per_grp) % num_nodes;
//printf("\n LP %ld sending to %ld num nodes %d ", local_id, local_dest, num_nodes);
else if(traffic == NEAREST_NEIGHBOR)
local_dest = (local_id + 1) % num_nodes;
// printf("\n LP %ld sending to %ld num nodes %d ", rep_id * 2 + offset, local_dest, num_nodes);
assert(local_dest < num_nodes);
// codes_mapping_get_lp_id(group_name, lp_type_name, anno, 1, local_dest / num_servers_per_rep, local_dest % num_servers_per_rep, &global_dest);
global_dest = codes_mapping_get_lpid_from_relative(local_dest, group_name, lp_type_name, NULL, 0);
ns->msg_sent_count++;
model_net_event(net_id, "test", global_dest, PAYLOAD_SZ, 0.0, sizeof(svr_msg), (const void*)m_remote, sizeof(svr_msg), (const void*)m_local, lp);
return;
static void handle_remote_rev_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
(void)b;
(void)m;
(void)lp;
ns->msg_recvd_count--;
static void handle_remote_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
(void)b;
(void)m;
(void)lp;
ns->msg_recvd_count++;
static void handle_local_rev_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
(void)b;
(void)m;
(void)lp;
ns->local_recvd_count--;
static void handle_local_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
(void)b;
(void)m;
(void)lp;
ns->local_recvd_count++;
/* convert ns to seconds */
static tw_stime ns_to_s(tw_stime ns)
return(ns / (1000.0 * 1000.0 * 1000.0));
/* convert seconds to ns */
static tw_stime s_to_ns(tw_stime ns)
return(ns * (1000.0 * 1000.0 * 1000.0));
svr_state * ns,
tw_lp * lp)
ns->end_ts = tw_now(lp);
printf("server %llu recvd %d bytes in %f seconds, %f MiB/s sent_count %d recvd_count %d local_count %d \n", (unsigned long long)lp->gid, PAYLOAD_SZ*ns->msg_recvd_count, ns_to_s(ns->end_ts-ns->start_ts),
((double)(PAYLOAD_SZ*ns->msg_sent_count)/(double)(1024*1024)/ns_to_s(ns->end_ts-ns->start_ts)), ns->msg_sent_count, ns->msg_recvd_count, ns->local_recvd_count);
return;
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
switch (m->svr_event_type)
case REMOTE:
handle_remote_rev_event(ns, b, m, lp);
break;
case LOCAL:
handle_local_rev_event(ns, b, m, lp);
break;
case KICKOFF:
handle_kickoff_rev_event(ns, b, m, lp);
break;
default:
assert(0);
break;
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
case REMOTE:
handle_remote_event(ns, b, m, lp);
break;
case LOCAL:
handle_local_event(ns, b, m, lp);
break;
case KICKOFF:
handle_kickoff_event(ns, b, m, lp);
break;
default:
printf("\n Invalid message type %d ", m->svr_event_type);
assert(0);
break;
int main(
int argc,
char **argv)
int nprocs;
int rank;
int num_nets;
int *net_ids;
int num_router_rows, num_router_cols;
tw_opt_add(app_opt);
tw_init(&argc, &argv);
if(argc < 2)
printf("\n Usage: mpirun <args> --sync=2/3 mapping_file_name.conf (optional --nkp) ");
MPI_Finalize();
return 0;
MPI_Comm_rank(MPI_COMM_CODES, &rank);
MPI_Comm_size(MPI_COMM_CODES, &nprocs);
configuration_load(argv[2], MPI_COMM_CODES, &config);
model_net_register();
svr_add_lp_type();
codes_mapping_setup();
net_ids = model_net_configure(&num_nets);
//assert(num_nets==1);
net_id = *net_ids;
free(net_ids);
/* 5 days of simulation time */
g_tw_ts_end = s_to_ns(5 * 24 * 60 * 60);
model_net_enable_sampling(sampling_interval, sampling_end_time);
if(!(net_id == DRAGONFLY || net_id == DRAGONFLY_PLUS || net_id == DRAGONFLY_CUSTOM))
printf("\n The test works with dragonfly model configuration only! %d %d ", DRAGONFLY_PLUS, net_id);
MPI_Finalize();
return 0;
num_servers_per_rep = codes_mapping_get_lp_count("MODELNET_GRP", 1, "nw-lp",
NULL, 1);
configuration_get_value_int(&config, "PARAMS", "num_router_rows", NULL, &num_router_rows);
configuration_get_value_int(&config, "PARAMS", "num_router_cols", NULL, &num_router_cols);
configuration_get_value_int(&config, "PARAMS", "num_groups", NULL, &num_groups);
configuration_get_value_int(&config, "PARAMS", "num_cns_per_router", NULL, &num_nodes_per_cn);
num_routers_per_grp = num_router_rows * num_router_cols;
num_nodes = num_groups * num_routers_per_grp * num_nodes_per_cn;
num_nodes_per_grp = num_routers_per_grp * num_nodes_per_cn;
assert(num_nodes);
if(lp_io_dir[0])
do_lp_io = 1;
int flags = lp_io_use_suffix ? LP_IO_UNIQ_SUFFIX : 0;
int ret = lp_io_prepare(lp_io_dir, flags, &io_handle, MPI_COMM_CODES);
assert(ret == 0 || !"lp_io_prepare failure");
tw_run();
if (do_lp_io){
int ret = lp_io_flush(io_handle, MPI_COMM_CODES);
assert(ret == 0 || !"lp_io_flush failure");
model_net_report_stats(net_id);
tw_end();
return 0;
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
* vim: ft=c ts=8 sts=4 sw=4 expandtab
Markdown is supported
0% or
Please register or to comment
