Commit 219f2999 authored by Philip Carns's avatar Philip Carns
make check test for p2p bw
parent 2ba8b69d
...@@ -70,4 +70,5 @@ AC_CONFIG_FILES([tests/modelnet-test.sh],[chmod +x tests/modelnet-test.sh]) ...@@ -70,4 +70,5 @@ AC_CONFIG_FILES([tests/modelnet-test.sh],[chmod +x tests/modelnet-test.sh])
AC_CONFIG_FILES([tests/modelnet-test-dragonfly.sh],[chmod +x tests/modelnet-test-dragonfly.sh]) AC_CONFIG_FILES([tests/modelnet-test-dragonfly.sh],[chmod +x tests/modelnet-test-dragonfly.sh])
AC_CONFIG_FILES([tests/modelnet-test-torus.sh],[chmod +x tests/modelnet-test-torus.sh]) AC_CONFIG_FILES([tests/modelnet-test-torus.sh],[chmod +x tests/modelnet-test-torus.sh])
AC_CONFIG_FILES([tests/modelnet-test-loggp.sh],[chmod +x tests/modelnet-test-loggp.sh]) AC_CONFIG_FILES([tests/modelnet-test-loggp.sh],[chmod +x tests/modelnet-test-loggp.sh])
AC_CONFIG_FILES([tests/modelnet-p2p-bw-loggp.sh],[chmod +x tests/modelnet-p2p-bw-loggp.sh])
AC_OUTPUT([maint/codes-net.pc]) AC_OUTPUT([maint/codes-net.pc])
...@@ -4,11 +4,13 @@ check_PROGRAMS += tests/modelnet-test tests/modelnet-p2p-bw ...@@ -4,11 +4,13 @@ check_PROGRAMS += tests/modelnet-test tests/modelnet-p2p-bw
TESTS += tests/modelnet-test.sh \ TESTS += tests/modelnet-test.sh \
tests/modelnet-test-torus.sh \ tests/modelnet-test-torus.sh \
tests/modelnet-test-loggp.sh \ tests/modelnet-test-loggp.sh \
tests/modelnet-test-dragonfly.sh tests/modelnet-test-dragonfly.sh \
EXTRA_DIST += tests/modelnet-test.sh \ EXTRA_DIST += tests/modelnet-test.sh \
testlib = src/libcodes-net.a testlib = src/libcodes-net.a
#!/bin/bash
abs_srcdir=@abs_srcdir@
tests/modelnet-p2p-bw --sync=1 -- $abs_srcdir/modelnet-p2p-bw-loggp.conf
Markdown is supported
0%
or
Please register or to comment
