Commit 20bfbd44 authored by Nikhil's avatar Nikhil
Fix cimpler issues
Change-Id: I5bd8ffda63820260eaecb58061e903ccabafe567
parent d9571f96
...@@ -41,6 +41,8 @@ include $(top_srcdir)/src/Makefile.subdir ...@@ -41,6 +41,8 @@ include $(top_srcdir)/src/Makefile.subdir
include $(top_srcdir)/tests/Makefile.subdir include $(top_srcdir)/tests/Makefile.subdir
include $(top_srcdir)/doc/Makefile.subdir include $(top_srcdir)/doc/Makefile.subdir
LDADD += -lcgraph
if USE_DEBUG if USE_DEBUG
AM_CPPFLAGS += -g AM_CPPFLAGS += -g
AM_CFLAGS += -g AM_CFLAGS += -g
...@@ -31,6 +31,7 @@ extern "C" { ...@@ -31,6 +31,7 @@ extern "C" {
#include "net/simplep2p.h" #include "net/simplep2p.h"
#include "net/torus.h" #include "net/torus.h"
#include "net/express-mesh.h" #include "net/express-mesh.h"
#include "net/network-graph.h"
extern int model_net_base_magic; extern int model_net_base_magic;
...@@ -140,6 +141,7 @@ typedef struct model_net_wrap_msg { ...@@ -140,6 +141,7 @@ typedef struct model_net_wrap_msg {
sp_message m_sp2p; // simplep2p sp_message m_sp2p; // simplep2p
nodes_message m_torus; // torus nodes_message m_torus; // torus
em_message m_em; // express-mesh em_message m_em; // express-mesh
network_graph_message m_ng; // express-mesh
// add new ones here // add new ones here
} msg; } msg;
} model_net_wrap_msg; } model_net_wrap_msg;
...@@ -74,6 +74,8 @@ typedef struct mn_stats mn_stats; ...@@ -74,6 +74,8 @@ typedef struct mn_stats mn_stats;
X(LOGGP, "modelnet_loggp", "loggp", &loggp_method)\ X(LOGGP, "modelnet_loggp", "loggp", &loggp_method)\
X(EXPRESS_MESH, "modelnet_express_mesh", "express_mesh", &express_mesh_method)\ X(EXPRESS_MESH, "modelnet_express_mesh", "express_mesh", &express_mesh_method)\
X(EXPRESS_MESH_ROUTER, "modelnet_express_mesh_router", "express_mesh_router", &express_mesh_router_method)\ X(EXPRESS_MESH_ROUTER, "modelnet_express_mesh_router", "express_mesh_router", &express_mesh_router_method)\
X(NETWORK_GRAPH, "modelnet_network_graph", "network_graph", &network_graph_method)\
X(NETWORK_GRAPH_ROUTER, "modelnet_network_graph_router", "network_graph_router", &network_graph_router_method)\
X(DRAGONFLY_PLUS, "modelnet_dragonfly_plus", "dragonfly_plus", &dragonfly_plus_method)\ X(DRAGONFLY_PLUS, "modelnet_dragonfly_plus", "dragonfly_plus", &dragonfly_plus_method)\
X(DRAGONFLY_PLUS_ROUTER, "modelnet_dragonfly_plus_router", "dragonfly_plus_router", &dragonfly_plus_router_method)\ X(DRAGONFLY_PLUS_ROUTER, "modelnet_dragonfly_plus_router", "dragonfly_plus_router", &dragonfly_plus_router_method)\
X(MAX_NETS, NULL, NULL, NULL) X(MAX_NETS, NULL, NULL, NULL)
...@@ -99,6 +99,7 @@ nobase_include_HEADERS = \ ...@@ -99,6 +99,7 @@ nobase_include_HEADERS = \
codes/net/slimfly.h \ codes/net/slimfly.h \
codes/net/fattree.h \ codes/net/fattree.h \
codes/net/loggp.h \ codes/net/loggp.h \
codes/net/network-graph.h \
codes/net/simplenet-upd.h \ codes/net/simplenet-upd.h \
codes/net/simplep2p.h \ codes/net/simplep2p.h \
codes/net/express-mesh.h \ codes/net/express-mesh.h \
...@@ -166,6 +167,7 @@ src_libcodes_la_SOURCES = \ ...@@ -166,6 +167,7 @@ src_libcodes_la_SOURCES = \
src/networks/model-net/dragonfly-plus.C \ src/networks/model-net/dragonfly-plus.C \
src/networks/model-net/slimfly.c \ src/networks/model-net/slimfly.c \
src/networks/model-net/fattree.c \ src/networks/model-net/fattree.c \
src/networks/model-net/network-graph.c \
src/networks/model-net/loggp.c \ src/networks/model-net/loggp.c \
src/networks/model-net/simplep2p.c \ src/networks/model-net/simplep2p.c \
src/networks/model-net/model-net-lp.c \ src/networks/model-net/model-net-lp.c \
...@@ -385,6 +385,10 @@ void model_net_base_configure(){ ...@@ -385,6 +385,10 @@ void model_net_base_configure(){
offsetof(model_net_wrap_msg, msg.m_em); offsetof(model_net_wrap_msg, msg.m_em);
msg_offsets[EXPRESS_MESH_ROUTER] = msg_offsets[EXPRESS_MESH_ROUTER] =
msg_offsets[NETWORK_GRAPH] =
offsetof(model_net_wrap_msg, msg.m_ng);
msg_offsets[NETWORK_GRAPH_ROUTER] =
// perform the configuration(s) // perform the configuration(s)
// This part is tricky, as we basically have to look up all annotations that // This part is tricky, as we basically have to look up all annotations that
...@@ -406,7 +410,7 @@ void model_net_base_configure(){ ...@@ -406,7 +410,7 @@ void model_net_base_configure(){
if (a == num_params){ if (a == num_params){
// found a new annotation // found a new annotatio
annos[num_params++] = amap->annotations[n].ptr; annos[num_params++] = amap->annotations[n].ptr;
...@@ -32,6 +32,10 @@ extern struct model_net_method dragonfly_custom_router_method; ...@@ -32,6 +32,10 @@ extern struct model_net_method dragonfly_custom_router_method;
extern struct model_net_method loggp_method; extern struct model_net_method loggp_method;
extern struct model_net_method express_mesh_method; extern struct model_net_method express_mesh_method;
extern struct model_net_method express_mesh_router_method; extern struct model_net_method express_mesh_router_method;
extern struct model_net_method network_graph_method;
extern struct model_net_method network_graph_router_method;
#define X(a,b,c,d) b, #define X(a,b,c,d) b,
char * model_net_lp_config_names[] = { char * model_net_lp_config_names[] = {
This diff is collapsed.
Markdown is supported
0% or
Please register or to comment
