Commit 19f999d1 authored by Misbah Mubarak's avatar Misbah Mubarak
adding fixes to reverse handler
parent 6a26562f
...@@ -28,7 +28,7 @@ ...@@ -28,7 +28,7 @@
#define DUMP_CONNECTIONS 0 #define DUMP_CONNECTIONS 0
#define PRINT_CONFIG 1 #define PRINT_CONFIG 1
#define CREDIT_SIZE 8 #define CREDIT_SIZE 8
#define DFLY_HASH_TABLE_SIZE 100000 #define DFLY_HASH_TABLE_SIZE 4999
// debugging parameters // debugging parameters
#define BW_MONITOR 1 #define BW_MONITOR 1
#define DEBUG_LP 892 #define DEBUG_LP 892
...@@ -1125,6 +1125,9 @@ void issue_bw_monitor_event_rc(terminal_state * s, tw_bf * bf, terminal_custom_m ...@@ -1125,6 +1125,9 @@ void issue_bw_monitor_event_rc(terminal_state * s, tw_bf * bf, terminal_custom_m
s->rc_index--; s->rc_index--;
if(bf->c1)
return;
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
/* resets the bandwidth numbers recorded so far */ /* resets the bandwidth numbers recorded so far */
...@@ -1152,8 +1155,10 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_custom_mess ...@@ -1152,8 +1155,10 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_custom_mess
if(tw_now(lp) > max_qos_monitor) if(tw_now(lp) > max_qos_monitor)
bf->c1 = 1;
return; return;
terminal_custom_message * m; terminal_custom_message * m;
tw_stime bw_ts = bw_reset_window + codes_local_latency(lp); tw_stime bw_ts = bw_reset_window + codes_local_latency(lp);
tw_event * e = model_net_method_event_new(lp->gid, bw_ts, lp, DRAGONFLY_CUSTOM, tw_event * e = model_net_method_event_new(lp->gid, bw_ts, lp, DRAGONFLY_CUSTOM,
...@@ -1269,7 +1274,6 @@ void reset_bw_counters(terminal_state * s, ...@@ -1269,7 +1274,6 @@ void reset_bw_counters(terminal_state * s,
if(msg->type == T_BANDWIDTH && s->rc_index > 0) if(msg->type == T_BANDWIDTH && s->rc_index > 0)
s->rc_index = 0;
for(int i = 0; i < num_rc_windows; i++) for(int i = 0; i < num_rc_windows; i++)
for(int j = 0; j < s->params->num_qos_levels; j++) for(int j = 0; j < s->params->num_qos_levels; j++)
...@@ -1278,6 +1282,7 @@ void reset_bw_counters(terminal_state * s, ...@@ -1278,6 +1282,7 @@ void reset_bw_counters(terminal_state * s,
s->last_qos_data[i][j] = 0; s->last_qos_data[i][j] = 0;
s->rc_index = 0;
/* initialize a dragonfly compute node terminal */ /* initialize a dragonfly compute node terminal */
...@@ -2303,8 +2308,12 @@ static void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_custom_mes ...@@ -2303,8 +2308,12 @@ static void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_custom_mes
if(bf->c7) if(bf->c7)
//assert(!hash_link); //assert(!hash_link);
if(bf->c8) if(bf->c8)
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
if(bf->c4)
model_net_event_rc2(lp, &msg->event_rc);
N_finished_msgs--; N_finished_msgs--;
s->finished_msgs--; s->finished_msgs--;
total_msg_sz -= msg->total_size; total_msg_sz -= msg->total_size;
...@@ -2323,8 +2332,6 @@ static void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_custom_mes ...@@ -2323,8 +2332,6 @@ static void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_custom_mes
hash_link = &(d_entry_pop->hash_link); hash_link = &(d_entry_pop->hash_link);
tmp = d_entry_pop; tmp = d_entry_pop;
if(bf->c4)
assert(tmp); assert(tmp);
...@@ -3883,23 +3890,23 @@ static void router_packet_receive_rc(router_state * s, ...@@ -3883,23 +3890,23 @@ static void router_packet_receive_rc(router_state * s,
if(bf->c1) if(bf->c1)
s->is_monitoring_bw = 1; s->is_monitoring_bw = 0;
if(bf->c15) if(bf->c8)
if(bf->c18) if(bf->c18)
if(bf->c3) if(bf->c15)
if(bf->c20) if(bf->c20)
...@@ -3932,8 +3939,8 @@ static void router_packet_receive_rc(router_state * s, ...@@ -3932,8 +3939,8 @@ static void router_packet_receive_rc(router_state * s,
if(bf->c21) if(bf->c21)
if(bf->c2) { if(bf->c2) {
terminal_custom_message_list * tail = return_tail(s->pending_msgs[output_port], s->pending_msgs_tail[output_port], output_chan); terminal_custom_message_list * tail = return_tail(s->pending_msgs[output_port], s->pending_msgs_tail[output_port], output_chan);
...@@ -4016,7 +4023,7 @@ router_packet_receive( router_state * s, ...@@ -4016,7 +4023,7 @@ router_packet_receive( router_state * s,
if(cur_chunk->msg.my_l_hop == max_lvc_src_g) if(cur_chunk->msg.my_l_hop == max_lvc_src_g)
bf->c3 = 1; bf->c8 = 1;
vector<int> direct_rtrs = get_indirect_conns(s, lp, dest_grp_id); vector<int> direct_rtrs = get_indirect_conns(s, lp, dest_grp_id);
assert(direct_rtrs.size() > 0); assert(direct_rtrs.size() > 0);
int indxa = tw_rand_integer(lp->rng, 0, direct_rtrs.size() - 1); int indxa = tw_rand_integer(lp->rng, 0, direct_rtrs.size() - 1);
...@@ -4517,7 +4524,6 @@ static void router_buf_update(router_state * s, tw_bf * bf, terminal_custom_mess ...@@ -4517,7 +4524,6 @@ static void router_buf_update(router_state * s, tw_bf * bf, terminal_custom_mess
int indx = msg->vc_index; int indx = msg->vc_index;
int output_chan = msg->output_chan; int output_chan = msg->output_chan;
s->vc_occupancy[indx][output_chan] -= s->params->chunk_size; s->vc_occupancy[indx][output_chan] -= s->params->chunk_size;
if(s->last_buf_full[indx] > 0.0) if(s->last_buf_full[indx] > 0.0)
Markdown is supported
0% or
Please register or to comment
