Commit 1916b7e7 authored by Philip Carns's avatar Philip Carns
output some timing information for validation
parent 7d2a86f0
...@@ -168,6 +168,17 @@ static void client_finalize( ...@@ -168,6 +168,17 @@ static void client_finalize(
client_state * ns, client_state * ns,
tw_lp * lp) tw_lp * lp)
char buffer[256];
int ret;
/* write out some statistics (the current time of each cn as it
* shuts down)
sprintf(buffer, "cn_lp:%ld\tfinalize_time:%f\n", (long)lp->gid, tw_now(lp));
ret = lp_io_write(lp->gid, "compute_nodes", strlen(buffer)+1, buffer);
assert(ret == 0);
return; return;
...@@ -312,12 +323,12 @@ static void cn_enter_barrier(tw_lp *lp, tw_lpid gid, int count) ...@@ -312,12 +323,12 @@ static void cn_enter_barrier(tw_lp *lp, tw_lpid gid, int count)
void cn_op_complete(tw_lp *lp, tw_lpid gid) void cn_op_complete(tw_lp *lp, tw_stime svc_time, tw_lpid gid)
tw_event *e; tw_event *e;
client_msg *m; client_msg *m;
e = codes_event_new(gid, codes_local_latency(lp), lp); e = codes_event_new(gid, codes_local_latency(lp) + svc_time, lp);
m = tw_event_data(e); m = tw_event_data(e);
m->event_type = CLIENT_OP_COMPLETE; m->event_type = CLIENT_OP_COMPLETE;
tw_event_send(e); tw_event_send(e);
...@@ -12,7 +12,7 @@ ...@@ -12,7 +12,7 @@
extern tw_lptype client_lp; extern tw_lptype client_lp;
void cn_op_complete(tw_lp *lp, tw_lpid gid); void cn_op_complete(tw_lp *lp, tw_stime svc_time, tw_lpid gid);
void cn_op_complete_rc(tw_lp *lp); void cn_op_complete_rc(tw_lp *lp);
void cn_set_params(int num_clients, int num_servers); void cn_set_params(int num_clients, int num_servers);
...@@ -125,32 +125,17 @@ static void svr_finalize( ...@@ -125,32 +125,17 @@ static void svr_finalize(
svr_state * ns, svr_state * ns,
#if 0
char buffer[256]; char buffer[256];
int ret; int ret;
sprintf(buffer, "LP %ld finalize data\n", (long)lp->gid); /* write out some statistics (the current time of each server as it
* shuts down)
sprintf(buffer, "svr_lp:%ld\tfinalize_time:%f\n", (long)lp->gid, tw_now(lp));
/* test having everyone write to same identifier */ ret = lp_io_write(lp->gid, "servers", strlen(buffer)+1, buffer);
ret = lp_io_write(lp->gid, "node_state_pointers", strlen(buffer)+1, buffer);
assert(ret == 0); assert(ret == 0);
/* test having only one lp write to a particular identifier */
if(lp->gid == 3)
ret = lp_io_write(lp->gid, "subset_example", strlen(buffer)+1, buffer);
assert(ret == 0);
/* test having one lp write two buffers to the same id */
if(lp->gid == 5)
sprintf(buffer, "LP %ld finalize data (intentional duplicate)\n", (long)lp->gid);
assert(ret == 0);
#endif
return; return;
...@@ -184,10 +169,13 @@ static void handle_svr_op_event( ...@@ -184,10 +169,13 @@ static void handle_svr_op_event(
svr_msg * m, svr_msg * m,
/* TODO: fill in some stub service time */ /* NOTE: this isn't a real server simulator, but we do want time to
* elapse so that we can do correctness/regression testing. We pick the
* service time by using the op type as the elapsed time.
/* send event back to cn to let it know the operation is done */ /* send event back to cn to let it know the operation is done */
cn_op_complete(lp, m->src); cn_op_complete(lp, m->op.op_type, m->src);
return; return;
Markdown is supported
0%
or
Please register or to comment
