Commit 171ca1a0 authored by Jonathan Jenkins's avatar Jonathan Jenkins
message size bump for example programs
parent 43059659
...@@ -24,7 +24,7 @@ PARAMS ...@@ -24,7 +24,7 @@ PARAMS
# - message_size: ROSS expects you to upper bound your event message size. # - message_size: ROSS expects you to upper bound your event message size.
# Going over this size will crash or otherwise destroy your # Going over this size will crash or otherwise destroy your
# simulation. # simulation.
message_size="256"; message_size="368";
# - pe_mem_factor: this is a multiplier to the event memory allocation that # - pe_mem_factor: this is a multiplier to the event memory allocation that
# ROSS does up front (multiplier is per-PE). Increase this # ROSS does up front (multiplier is per-PE). Increase this
# (or change the associated mem_factor variable in # (or change the associated mem_factor variable in
...@@ -27,7 +27,7 @@ LPGROUPS { ...@@ -27,7 +27,7 @@ LPGROUPS {
PARAMS { PARAMS {
## ROSS parameters ## ROSS parameters
message_size="256"; message_size="352";
## global modelnet parameters ## global modelnet parameters
modelnet_order=("simplenet"); modelnet_order=("simplenet");
PARAMS { PARAMS {
modelnet_order=("torus","simplenet"); modelnet_order=("torus","simplenet");
Markdown is supported
0% or
Please register or to comment
