Commit 081c74bf authored by Shane Snyder's avatar Shane Snyder
Browse files
Update generation of darshan collective events
Now, there is logic for generating collective/indpendent i/o events
from darshan logs. There are a couple minor timing and i/o parameter
bugs that still need to be worked out.
parent 1386ce65
...@@ -68,13 +68,12 @@ static double generate_psx_close_event(struct darshan_file *file, double meta_op ...@@ -68,13 +68,12 @@ static double generate_psx_close_event(struct darshan_file *file, double meta_op
static double generate_barrier_event(struct darshan_file *file, int64_t root, double cur_time, static double generate_barrier_event(struct darshan_file *file, int64_t root, double cur_time,
struct rank_io_context *io_context); struct rank_io_context *io_context);
static double generate_psx_ind_io_events(struct darshan_file *file, int64_t io_ops_this_cycle, static double generate_psx_ind_io_events(struct darshan_file *file, int64_t io_ops_this_cycle,
int64_t open_ndx, double inter_io_delay, double inter_io_delay, double meta_op_time,
double meta_op_time, double cur_time, double cur_time, struct rank_io_context *io_context);
static double generate_psx_coll_io_events(struct darshan_file *file, int64_t ind_io_ops_this_cycle, static double generate_psx_coll_io_events(struct darshan_file *file, int64_t ind_io_ops_this_cycle,
int64_t coll_io_ops_this_cycle, int64_t nprocs, int64_t coll_io_ops_this_cycle, int64_t nprocs,
int64_t aggregator_cnt, int64_t open_ndx, int64_t aggregator_cnt, double inter_io_delay,
double inter_io_delay, double meta_op_time, double cur_time, double meta_op_time, double cur_time,
static void determine_io_params(struct darshan_file *file, int write_flag, int coll_flag, static void determine_io_params(struct darshan_file *file, int write_flag, int coll_flag,
int64_t io_cycles, size_t *io_sz, off_t *io_off); int64_t io_cycles, size_t *io_sz, off_t *io_off);
...@@ -153,6 +152,10 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -153,6 +152,10 @@ static int darshan_io_workload_load(const char *params, int rank)
/* generate collective i/o events and store them in the rank context */ /* generate collective i/o events and store them in the rank context */
generate_psx_coll_file_events(&next_file, my_ctx, job.nprocs, d_params->aggregator_cnt); generate_psx_coll_file_events(&next_file, my_ctx, job.nprocs, d_params->aggregator_cnt);
assert(next_file.counters[CP_POSIX_OPENS] == 0);
assert(next_file.counters[CP_POSIX_READS] == 0);
assert(next_file.counters[CP_POSIX_WRITES] == 0);
if (ret < 0) if (ret < 0)
return -1; return -1;
...@@ -424,7 +427,7 @@ static void generate_psx_ind_file_events( ...@@ -424,7 +427,7 @@ static void generate_psx_ind_file_events(
file->counters[CP_POSIX_OPENS]); file->counters[CP_POSIX_OPENS]);
/* perform the calculated number of i/o operations for this file open */ /* perform the calculated number of i/o operations for this file open */
cur_time = generate_psx_ind_io_events(file, io_ops_this_cycle, i, inter_io_delay, cur_time = generate_psx_ind_io_events(file, io_ops_this_cycle, inter_io_delay,
meta_op_time, cur_time, io_context); meta_op_time, cur_time, io_context);
/* account for potential delay from last io to close */ /* account for potential delay from last io to close */
...@@ -460,7 +463,7 @@ void generate_psx_coll_file_events( ...@@ -460,7 +463,7 @@ void generate_psx_coll_file_events(
int64_t total_coll_io_ops; int64_t total_coll_io_ops;
int64_t ind_io_ops_this_cycle; int64_t ind_io_ops_this_cycle;
int64_t coll_io_ops_this_cycle; int64_t coll_io_ops_this_cycle;
int64_t aggregator_cnt; int64_t rank_cnt;
int create_flag = 0; int create_flag = 0;
double cur_time = file->fcounters[CP_F_OPEN_TIMESTAMP]; double cur_time = file->fcounters[CP_F_OPEN_TIMESTAMP];
double delay_per_cycle; double delay_per_cycle;
...@@ -491,6 +494,9 @@ void generate_psx_coll_file_events( ...@@ -491,6 +494,9 @@ void generate_psx_coll_file_events(
open_cycles = total_coll_opens / nprocs; open_cycles = total_coll_opens / nprocs;
else else
open_cycles = ceil((double)total_ind_opens / nprocs); open_cycles = ceil((double)total_ind_opens / nprocs);
total_ind_io_ops = file->counters[CP_INDEP_READS] + file->counters[CP_INDEP_WRITES];
total_coll_io_ops = (file->counters[CP_COLL_READS] + file->counters[CP_COLL_WRITES]) / nprocs;
else else
...@@ -502,11 +508,19 @@ void generate_psx_coll_file_events( ...@@ -502,11 +508,19 @@ void generate_psx_coll_file_events(
else else
extra_io_ops = total_io_ops % nprocs; extra_io_ops = total_io_ops % nprocs;
if (extra_io_ops != extra_opens)
extra_opens = 0;
extra_io_ops = 0;
total_coll_opens = 0; total_coll_opens = 0;
total_ind_opens = file->counters[CP_POSIX_OPENS] - extra_opens; total_ind_opens = file->counters[CP_POSIX_OPENS] - extra_opens;
total_ind_io_ops = total_io_ops - extra_io_ops;
total_coll_io_ops = 0;
assert(extra_opens <= open_cycles); assert(extra_opens <= open_cycles);
...@@ -521,6 +535,8 @@ void generate_psx_coll_file_events( ...@@ -521,6 +535,8 @@ void generate_psx_coll_file_events(
meta_op_time = file->fcounters[CP_F_POSIX_META_TIME] / ((2 * file->counters[CP_POSIX_OPENS]) + meta_op_time = file->fcounters[CP_F_POSIX_META_TIME] / ((2 * file->counters[CP_POSIX_OPENS]) +
file->counters[CP_POSIX_READS] + file->counters[CP_POSIX_WRITES]); file->counters[CP_POSIX_READS] + file->counters[CP_POSIX_WRITES]);
/* TODO calc delays */
/* it is rare to overwrite existing files, so set the create flag */ /* it is rare to overwrite existing files, so set the create flag */
if (file->counters[CP_BYTES_WRITTEN]) if (file->counters[CP_BYTES_WRITTEN])
...@@ -530,12 +546,8 @@ void generate_psx_coll_file_events( ...@@ -530,12 +546,8 @@ void generate_psx_coll_file_events(
/* generate all events for this collectively opened file */ /* generate all events for this collectively opened file */
for (i = 0; i < open_cycles; i++) for (i = 0; i < open_cycles; i++)
/* TODO: AGG COUNT */
ind_opens_this_cycle = ceil((double)total_ind_opens / (open_cycles - i)); ind_opens_this_cycle = ceil((double)total_ind_opens / (open_cycles - i));
coll_opens_this_cycle = total_coll_opens / (open_cycles - i); coll_opens_this_cycle = total_coll_opens / (open_cycles - i);
total_ind_opens -= ind_opens_this_cycle;
total_coll_opens -= coll_opens_this_cycle;
/* assign any extra opens to rank 0 (these may correspond to file creations or /* assign any extra opens to rank 0 (these may correspond to file creations or
* header reads/writes) * header reads/writes)
...@@ -547,7 +559,12 @@ void generate_psx_coll_file_events( ...@@ -547,7 +559,12 @@ void generate_psx_coll_file_events(
cur_time = generate_psx_open_event(file, create_flag, meta_op_time, cur_time, io_context); cur_time = generate_psx_open_event(file, create_flag, meta_op_time, cur_time, io_context);
create_flag = 0; create_flag = 0;
/* TODO: any extra i/o here -- no delays */ if (!file->counters[CP_COLL_OPENS] && !file->counters[CP_INDEP_OPENS])
cur_time = generate_psx_coll_io_events(file, 1, 0, nprocs, nprocs, 0.0,
extra_io_ops--;
cur_time = generate_psx_close_event(file, meta_op_time, cur_time, io_context); cur_time = generate_psx_close_event(file, meta_op_time, cur_time, io_context);
...@@ -555,26 +572,35 @@ void generate_psx_coll_file_events( ...@@ -555,26 +572,35 @@ void generate_psx_coll_file_events(
file->counters[CP_POSIX_OPENS]--; file->counters[CP_POSIX_OPENS]--;
while (ind_opens_this_cycle > io_context->my_rank) while (ind_opens_this_cycle)
if (ind_opens_this_cycle >= nprocs)
rank_cnt = nprocs;
else
rank_cnt = ind_opens_this_cycle;
cur_time = generate_psx_open_event(file, create_flag, meta_op_time, cur_time = generate_psx_open_event(file, create_flag, meta_op_time,
cur_time, io_context); cur_time, io_context);
/* TODO do delays, set i/o op counts, do i/o, update i/o op counts */ cur_time += first_io_delay;
ind_io_ops_this_cycle = ceil(((double)total_ind_io_ops / total_ind_opens) * rank_cnt);
cur_time = generate_psx_coll_io_events(file, ind_io_ops_this_cycle, 0, nprocs,
rank_cnt, inter_io_delay, meta_op_time,
total_ind_io_ops -= ind_io_ops_this_cycle;
cur_time += close_delay;
if (ind_opens_this_cycle >= nprocs) file->counters[CP_POSIX_OPENS] -= rank_cnt;
{ ind_opens_this_cycle -= rank_cnt;
file->counters[CP_POSIX_OPENS] -= nprocs; total_ind_opens -= rank_cnt;
ind_opens_this_cycle -= nprocs;
} if (file->counters[CP_POSIX_OPENS])
else cur_time += inter_cycle_delay;
file->counters[CP_POSIX_OPENS] -= ind_opens_this_cycle;
ind_opens_this_cycle = 0;
while (coll_opens_this_cycle) while (coll_opens_this_cycle)
...@@ -586,13 +612,34 @@ void generate_psx_coll_file_events( ...@@ -586,13 +612,34 @@ void generate_psx_coll_file_events(
/* TODO: do delays, set i/o counts, do i/o, update i/o counts */ cur_time += first_io_delay;
if (file->counters[CP_INDEP_OPENS])
ind_io_ops_this_cycle = 0;
else
ind_io_ops_this_cycle = ceil((double)total_ind_io_ops /
(file->counters[CP_COLL_OPENS] / nprocs));
coll_io_ops_this_cycle = ceil((double)total_coll_io_ops /
coll_io_ops_this_cycle, nprocs, in_agg_cnt,
total_coll_io_ops -= coll_io_ops_this_cycle;
file->counters[CP_POSIX_OPENS] -= nprocs; file->counters[CP_POSIX_OPENS] -= nprocs;
file->counters[CP_COLL_OPENS] -= nprocs; file->counters[CP_COLL_OPENS] -= nprocs;
coll_opens_this_cycle -= nprocs; coll_opens_this_cycle -= nprocs;
total_coll_opens -= nprocs;
...@@ -670,8 +717,8 @@ static double generate_barrier_event( ...@@ -670,8 +717,8 @@ static double generate_barrier_event(
/* generate all i/o events for one independent file open and store them with the rank context */ /* generate all i/o events for one independent file open and store them with the rank context */
static double generate_psx_ind_io_events( static double generate_psx_ind_io_events(
struct darshan_file *file, int64_t io_ops_this_cycle, int64_t open_ndx, struct darshan_file *file, int64_t io_ops_this_cycle, double inter_io_delay,
double inter_io_delay, double meta_op_time, double cur_time, struct rank_io_context *io_context) double meta_op_time, double cur_time, struct rank_io_context *io_context)
static int rw = -1; /* rw = 1 for write, 0 for read, -1 for uninitialized */ static int rw = -1; /* rw = 1 for write, 0 for read, -1 for uninitialized */
static int64_t io_ops_this_rw; static int64_t io_ops_this_rw;
...@@ -801,8 +848,8 @@ static double generate_psx_ind_io_events( ...@@ -801,8 +848,8 @@ static double generate_psx_ind_io_events(
static double generate_psx_coll_io_events( static double generate_psx_coll_io_events(
struct darshan_file *file, int64_t ind_io_ops_this_cycle, int64_t coll_io_ops_this_cycle, struct darshan_file *file, int64_t ind_io_ops_this_cycle, int64_t coll_io_ops_this_cycle,
int64_t nprocs, int64_t aggregator_cnt, int64_t open_ndx, double inter_io_delay, int64_t nprocs, int64_t aggregator_cnt, double inter_io_delay, double meta_op_time,
double meta_op_time, double cur_time, struct rank_io_context *io_context) double cur_time, struct rank_io_context *io_context)
...@@ -839,28 +886,6 @@ static double generate_psx_coll_io_events( ...@@ -839,28 +886,6 @@ static double generate_psx_coll_io_events(
rw = (file->fcounters[CP_F_READ_START_TIMESTAMP] < rw = (file->fcounters[CP_F_READ_START_TIMESTAMP] <
file->fcounters[CP_F_WRITE_START_TIMESTAMP]) ? 0 : 1; file->fcounters[CP_F_WRITE_START_TIMESTAMP]) ? 0 : 1;
/* determine how many io ops to do before next rw switch */
if (!rw)
if (file->counters[CP_COLL_OPENS])
io_ops_this_rw =
((file->counters[CP_COLL_READS] / nprocs) + file->counters[CP_INDEP_READS]) /
((file->counters[CP_RW_SWITCHES] / (2 * aggregator_cnt)) + 1);
else
io_ops_this_rw = file->counters[CP_POSIX_READS] /
else
io_ops_this_rw =
((file->counters[CP_COLL_WRITES] / nprocs) + file->counters[CP_INDEP_WRITES]) /
else
io_ops_this_rw = file->counters[CP_POSIX_WRITES] /
/* initialize the rd and wr bandwidth values using total io size and time */ /* initialize the rd and wr bandwidth values using total io size and time */
if (file->fcounters[CP_F_POSIX_READ_TIME]) if (file->fcounters[CP_F_POSIX_READ_TIME])
rd_bw = file->counters[CP_BYTES_READ] / file->fcounters[CP_F_POSIX_READ_TIME]; rd_bw = file->counters[CP_BYTES_READ] / file->fcounters[CP_F_POSIX_READ_TIME];
...@@ -868,6 +893,28 @@ static double generate_psx_coll_io_events( ...@@ -868,6 +893,28 @@ static double generate_psx_coll_io_events(
wr_bw = file->counters[CP_BYTES_WRITTEN] / file->fcounters[CP_F_POSIX_WRITE_TIME]; wr_bw = file->counters[CP_BYTES_WRITTEN] / file->fcounters[CP_F_POSIX_WRITE_TIME];
if (!rw)
io_ops_this_rw =
else
else
io_ops_this_rw =
else
if (coll_io_ops_this_cycle) if (coll_io_ops_this_cycle)
ind_ops_remaining = ceil((double)ind_io_ops_this_cycle / coll_io_ops_this_cycle); ind_ops_remaining = ceil((double)ind_io_ops_this_cycle / coll_io_ops_this_cycle);
else else
...@@ -876,46 +923,44 @@ static double generate_psx_coll_io_events( ...@@ -876,46 +923,44 @@ static double generate_psx_coll_io_events(
for (i = 0; i < total_io_ops_this_cycle; i++) for (i = 0; i < total_io_ops_this_cycle; i++)
if (ind_ops_remaining) if (ind_ops_remaining)
ind_coll = 0;
else
ind_coll = 1;
#if 0
if (((double)rand() / (double)(RAND_MAX + 1.0)) < ind_coll_switch)
ind_coll = 0; ind_coll = 0;
tmp_rank = (next_ind_io_rank++) % nprocs; tmp_rank = (next_ind_io_rank++) % nprocs;
io_cnt = 1; io_cnt = 1;
ind_io_ops_this_cycle--;
ind_ops_remaining--;
if (!rw) if (!rw)
file->counters[CP_INDEP_READS]--; file->counters[CP_INDEP_READS]--;
else else
file->counters[CP_INDEP_WRITES]--; file->counters[CP_INDEP_WRITES]--;
else else
ind_coll = 1; ind_coll = 1;
cur_time = generate_barrier_event(file, 0, cur_time, io_context);
tmp_rank = 0; tmp_rank = 0;
coll_io_ops_this_cycle--;
if (!rw) if (!rw)
io_cnt = ceil((double)(file->counters[CP_POSIX_READS] - io_cnt = ceil((double)(file->counters[CP_POSIX_READS] -
file->counters[CP_INDEP_READS]) / file->counters[CP_INDEP_READS]) /
(file->counters[CP_COLL_READS] / nprocs)); (file->counters[CP_COLL_READS] / nprocs));
file->counters[CP_COLL_READS] -= nprocs; file->counters[CP_COLL_READS] -= nprocs;
else else
io_cnt = ceil((double)(file->counters[CP_POSIX_WRITES] - io_cnt = ceil((double)(file->counters[CP_POSIX_WRITES] -
file->counters[CP_INDEP_WRITES]) / file->counters[CP_INDEP_WRITES]) /
(file->counters[CP_COLL_WRITES] / nprocs)); (file->counters[CP_COLL_WRITES] / nprocs));
file->counters[CP_COLL_WRITES] -= nprocs; file->counters[CP_COLL_WRITES] -= nprocs;
coll_io_ops_this_cycle--; assert(io_cnt <= io_ops_this_rw);
else
ind_ops_remaining = ind_io_ops_this_cycle;
for (j = 0; j < io_cnt; j++) for (j = 0; j < io_cnt; j++)
...@@ -970,7 +1015,7 @@ static double generate_psx_coll_io_events( ...@@ -970,7 +1015,7 @@ static double generate_psx_coll_io_events(
max_cur_time = next_io_op.end_time; max_cur_time = next_io_op.end_time;
tmp_rank += ranks_per_aggregator; tmp_rank += ranks_per_aggregator;
if (tmp_rank >= (ranks_per_aggregator * aggregator_cnt)) if (ind_coll && (tmp_rank >= (ranks_per_aggregator * aggregator_cnt)))
cur_time = max_cur_time; cur_time = max_cur_time;
...@@ -979,6 +1024,25 @@ static double generate_psx_coll_io_events( ...@@ -979,6 +1024,25 @@ static double generate_psx_coll_io_events(
io_ops_this_rw--; io_ops_this_rw--;
if (ind_coll)
total_coll_io_ops--;
if (i != (total_io_ops_this_cycle - 1))
cur_time += inter_io_delay;
else
if (tmp_rank == (nprocs - 1))
else
/* determine whether to toggle between reads and writes */ /* determine whether to toggle between reads and writes */
if (!io_ops_this_rw && psx_rw_ops_remaining) if (!io_ops_this_rw && psx_rw_ops_remaining)
...@@ -1010,8 +1074,6 @@ static double generate_psx_coll_io_events( ...@@ -1010,8 +1074,6 @@ static double generate_psx_coll_io_events(
((file->counters[CP_RW_SWITCHES] / (2 * aggregator_cnt)) + 1); ((file->counters[CP_RW_SWITCHES] / (2 * aggregator_cnt)) + 1);
#endif
/* reset the static rw flag if this is the last open-close cycle for this file */ /* reset the static rw flag if this is the last open-close cycle for this file */
...@@ -1020,10 +1082,7 @@ static double generate_psx_coll_io_events( ...@@ -1020,10 +1082,7 @@ static double generate_psx_coll_io_events(
rw = -1; rw = -1;
if (max_cur_time > cur_time) return cur_time;
return max_cur_time;
else
return cur_time;
static void determine_io_params( static void determine_io_params(
Markdown is supported
0% or .
Please register or to comment
