Commit 03cc9c23 authored by Misbah Mubarak's avatar Misbah Mubarak
Merge branch 'master' into 'master'
Bug fix in dfly routing
Change-Id: I53f278953f2e287bf122cf20694a7db3bd1fd336
See merge request !7
parents 52903ae2 09bf4ffa
...@@ -3022,7 +3022,7 @@ void router_buf_update_rc(router_state * s, ...@@ -3022,7 +3022,7 @@ void router_buf_update_rc(router_state * s,
prepend_to_terminal_message_list(s->queued_msgs[indx], prepend_to_terminal_message_list(s->queued_msgs[indx],
s->queued_msgs_tail[indx], output_chan, head); s->queued_msgs_tail[indx], output_chan, head);
s->vc_occupancy[indx][output_chan] -= s->params->chunk_size; s->vc_occupancy[indx][output_chan] -= s->params->chunk_size;
s->queued_count[indx] -= s->params->chunk_size; s->queued_count[indx] += s->params->chunk_size;
if(bf->c2) { if(bf->c2) {
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
...@@ -3054,7 +3054,7 @@ void router_buf_update(router_state * s, tw_bf * bf, terminal_message * msg, tw_ ...@@ -3054,7 +3054,7 @@ void router_buf_update(router_state * s, tw_bf * bf, terminal_message * msg, tw_
append_to_terminal_message_list(s->pending_msgs[indx], append_to_terminal_message_list(s->pending_msgs[indx],
s->pending_msgs_tail[indx], output_chan, head); s->pending_msgs_tail[indx], output_chan, head);
s->vc_occupancy[indx][output_chan] += s->params->chunk_size; s->vc_occupancy[indx][output_chan] += s->params->chunk_size;
s->queued_count[indx] += s->params->chunk_size; s->queued_count[indx] -= s->params->chunk_size;
if(s->in_send_loop[indx] == 0 && s->pending_msgs[indx][output_chan] != NULL) { if(s->in_send_loop[indx] == 0 && s->pending_msgs[indx][output_chan] != NULL) {
bf->c2 = 1; bf->c2 = 1;
Markdown is supported
0% or
Please register or to comment
