Commit 01aff409 authored by Jonathan Jenkins's avatar Jonathan Jenkins
tweaked install instructions
parent 5f514822
0 - Checkout, build, and install codes-base
0 - Install codes-base, either from the repository or using the 0.3.0 release
tarball (see http://www.mcs.anl.gov/projects/codes/).
git clone git@git.mcs.anl.gov:radix/codes-base
<see codes-base/README.txt>
1 - If this is the first time you are building codes-net, run
1 - If you are building codes-net directly from the repository, run
./prepare.sh
2- Configure codes-net. This can be done in the source directory or in a
dedicated build directory if you prefer out-of-tree builds. The CC
environment variable must refer to an MPI compiler.
2 - Configure codes-net. This can be done in the source directory or in a
./configure --with-codes-base=/path/to/codes-base/install --prefix=/path/to/codes-net/install CC=mpicc
mkdir build
cd build
../configure --with-codes-base=/path/to/codes-base/install --prefix=/path/to/codes-net/install CC=mpicc
3 - Build codes-net
make clean && make
make install
make tests
make && make install
4 - (optional) run test programs
make check
make tests && make check
Markdown is supported
0%
or
Please register or to comment
