Commit fe8283b4 authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
updated test to allow 'pulling'
- currently stupid, stats don't really mean
  anything when pulling
- enable manually by setting do_pull = 1 (no
  cmdline option yet)
parent f384820a
...@@ -32,6 +32,9 @@ static int num_routers = 0; ...@@ -32,6 +32,9 @@ static int num_routers = 0;
static int num_servers = 0; static int num_servers = 0;
static int offset = 2; static int offset = 2;
/* whether to pull instead of push */
static int do_pull = 0;
typedef struct svr_msg svr_msg; typedef struct svr_msg svr_msg;
typedef struct svr_state svr_state; typedef struct svr_state svr_state;
...@@ -317,7 +320,7 @@ static void handle_kickoff_event( ...@@ -317,7 +320,7 @@ static void handle_kickoff_event(
m_local->src = lp->gid; m_local->src = lp->gid;
memcpy(m_remote, m_local, sizeof(svr_msg)); memcpy(m_remote, m_local, sizeof(svr_msg));
m_remote->svr_event_type = REQ; m_remote->svr_event_type = (do_pull) ? ACK : REQ;
//printf("handle_kickoff_event(), lp %llu.\n", (unsigned long long)lp->gid); //printf("handle_kickoff_event(), lp %llu.\n", (unsigned long long)lp->gid);
/* record when transfers started on this server */ /* record when transfers started on this server */
...@@ -329,7 +332,13 @@ static void handle_kickoff_event( ...@@ -329,7 +332,13 @@ static void handle_kickoff_event(
/* each server sends a request to the next highest server */ /* each server sends a request to the next highest server */
int dest_id = (lp->gid + offset + opt_offset)%(num_servers*2 + num_routers); int dest_id = (lp->gid + offset + opt_offset)%(num_servers*2 + num_routers);
model_net_event(net_id, "test", dest_id, PAYLOAD_SZ, 0.0, sizeof(svr_msg), (const void*)m_remote, sizeof(svr_msg), (const void*)m_local, lp); if (do_pull){
model_net_pull_event(net_id, "test", dest_id, PAYLOAD_SZ, 0.0,
sizeof(svr_msg), (const void*)m_remote, lp);
else{
ns->msg_sent_count++; ns->msg_sent_count++;
...@@ -358,7 +367,12 @@ static void handle_req_rev_event( ...@@ -358,7 +367,12 @@ static void handle_req_rev_event(
tw_lp * lp) tw_lp * lp)
ns->msg_recvd_count--; ns->msg_recvd_count--;
model_net_event_rc(net_id, lp, PAYLOAD_SZ); if (do_pull){
model_net_pull_event_rc(net_id, lp);
else{
return; return;
...@@ -372,7 +386,12 @@ static void handle_kickoff_rev_event( ...@@ -372,7 +386,12 @@ static void handle_kickoff_rev_event(
ns->msg_sent_count--; ns->msg_sent_count--;
else{
return; return;
...@@ -407,7 +426,7 @@ static void handle_ack_event( ...@@ -407,7 +426,7 @@ static void handle_ack_event(
// printf("handle_ack_event(), lp %llu.\n", (unsigned long long)lp->gid); // printf("handle_ack_event(), lp %llu.\n", (unsigned long long)lp->gid);
...@@ -417,12 +436,26 @@ static void handle_ack_event( ...@@ -417,12 +436,26 @@ static void handle_ack_event(
if(net_id == DRAGONFLY && lp->gid % 5) if(net_id == DRAGONFLY && lp->gid % 5)
opt_offset = 3; opt_offset = 3;
assert(m->src == (lp->gid + offset + opt_offset)%(num_servers*2 + num_routers)); tw_lpid dest_id = (lp->gid + offset + opt_offset)%(num_servers*2 + num_routers);
/* in the "pull" case, src should actually be self */
if (do_pull){
assert(m->src == lp->gid);
else{
assert(m->src == dest_id);
if(ns->msg_sent_count < NUM_REQS) if(ns->msg_sent_count < NUM_REQS)
/* send another request */ /* send another request */
model_net_event(net_id, "test", m->src, PAYLOAD_SZ, 0.0, sizeof(svr_msg), (const void*)m_remote, sizeof(svr_msg), (const void*)m_local, lp); if (do_pull){
else{
m->incremented_flag = 1; m->incremented_flag = 1;
...@@ -434,13 +467,16 @@ static void handle_ack_event( ...@@ -434,13 +467,16 @@ static void handle_ack_event(
return; return;
/* handle receiving request */ /* handle receiving request
* (note: this should never be called when doing the "pulling" version of
* the program) */
static void handle_req_event( static void handle_req_event(
svr_state * ns, svr_state * ns,
tw_bf * b, tw_bf * b,
svr_msg * m, svr_msg * m,
assert(!do_pull);
svr_msg * m_local = malloc(sizeof(svr_msg)); svr_msg * m_local = malloc(sizeof(svr_msg));
svr_msg * m_remote = malloc(sizeof(svr_msg)); svr_msg * m_remote = malloc(sizeof(svr_msg));
Markdown is supported
0% or .
Please register or to comment
