Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
fccb830b
Commit
fccb830b
authored
Aug 10, 2015
by
Jonathan Jenkins
Browse files
Options
Browse Files
Download
Plain Diff
Merge branch 'map-context-api'
Conflicts: src/models/networks/model-net/dragonfly.c tests/conf/modelnet-test-dragonfly.conf
parents
a6c7399d
3467f1c6
Changes
17
Hide whitespace changes
Inline
Side-by-side
Showing
17 changed files
with
226 additions
and
252 deletions
+226
-252
codes/model-net-method.h
+2
-4
codes/model-net.h
codes/model-net.h
+52
-10
codes/net/dragonfly.h
+2
-1
codes/net/loggp.h
codes/net/loggp.h
+2
-0
codes/net/simplenet-upd.h
+2
-0
codes/net/simplep2p.h
+2
-0
+11
-29
src/models/networks/model-net/loggp.c
+19
-43
src/models/networks/model-net/model-net-lp.c
+2
-0
src/models/networks/model-net/model-net-sched-impl.c
+8
-5
src/models/networks/model-net/model-net.c
+73
-45
src/models/networks/model-net/simplenet-upd.c
+17
-43
src/models/networks/model-net/simplep2p.c
+18
-40
src/models/networks/model-net/torus.c
+13
-29
tests/conf/modelnet-p2p-bw-loggp.conf
+1
-1
tests/conf/modelnet-test-loggp.conf
+1
-1
tests/conf/modelnet-test.conf
+1
-1
No files found.
View file @
fccb830b
@@ -29,6 +29,7 @@ struct model_net_method
tw_stime
model_net_method_packet_event
tw_stime
char
const
category
char
const
category
tw_lpid
final_dest_lp
tw_lpid
final_dest_lp
tw_lpid
dest_mn_lp
// destination modelnet lp, computed by sender
uint64_t
packet_size
uint64_t
packet_size
int
is_pull
int
is_pull
uint64_t
pull_size
/* only used when is_pull==1 */
uint64_t
pull_size
@@ -50,6 +51,7 @@ struct model_net_method
tw_stime
model_net_method_recv_msg_event
tw_stime
const
char
category
const
char
category
tw_lpid
final_dest_lp
tw_lpid
final_dest_lp
tw_lpid
src_mn_lp
// the modelnet LP this message came from
uint64_t
msg_size
uint64_t
msg_size
int
is_pull
int
is_pull
uint64_t
pull_size
uint64_t
pull_size
@@ -62,10 +64,6 @@ struct model_net_method
const
tw_lptype
mn_get_lp_type
const
tw_lptype
mn_get_lp_type
int
mn_get_msg_sz
int
mn_get_msg_sz
void
mn_report_stats
void
mn_report_stats
tw_lpid
model_net_method_find_local_device
const
char
annotation
int
ignore_annotations
tw_lpid
sender_gid
void
mn_collective_call
char
const
category
int
message_size
int
remote_event_size
const
void
remote_event
tw_lp
sender
void
mn_collective_call
char
const
category
int
message_size
int
remote_event_size
const
void
remote_event
tw_lp
sender
void
mn_collective_call_rc
int
message_size
tw_lp
sender
void
int
message_size
tw_lp
sender
codes/model-net.h
View file @
fccb830b
@@ -7,10 +7,11 @@
@@ -7,10 +7,11 @@
#ifndef MODELNET_H
#ifndef MODELNET_H
#define MODELNET_H
#define MODELNET_H
#include "ross.h"
#include <ross.h>
#include "codes/lp-type-lookup.h"
#include <codes/lp-type-lookup.h>
#include "codes/configuration.h"
#include <codes/configuration.h>
#include "codes/lp-io.h"
#include <codes/lp-io.h>
#include <codes/codes-mapping-context.h>
#include <stdint.h>
#include <stdint.h>
#define PULL_MSG_SIZE 128
@@ -73,6 +74,7 @@ extern char * model_net_method_names[];
// not the user)
// not the user)
typedef
struct
model_net_request
typedef
struct
model_net_request
tw_lpid
final_dest_lp
tw_lpid
final_dest_lp
tw_lpid
dest_mn_lp
tw_lpid
src_lp
tw_lpid
src_lp
uint64_t
msg_size
uint64_t
msg_size
uint64_t
packet_size
uint64_t
packet_size
@@ -167,10 +169,10 @@ void model_net_event_collective_rc(
* - sender: pointer to the tw_lp structure of the API caller. This is
* identical to the sender argument to tw_event_new().
* The modelnet LP used for communication is
the LP in the same group, same
determined by the default CODES
repetition, using net_id to differentiate different model types. If
map context (see codes-base, codes/codes-mapping-context.h), using net_id
more than one modelnet model of the same type but different annotation exist,
to differentiate different model types. Note that the map context is used
then the first one listed will be used.
when calculating *both* sender and receiver modelnet LPs
// first argument becomes the network ID
void
model_net_event
void
model_net_event
@@ -189,7 +191,8 @@ void model_net_event(
* Unlike model_net_event, this function uses the annotation to differentiate
* multiple modelnet LPs with the same type but different annotation. The caller
* annotation is not consulted here.
* annotation is not consulted here. The corresponding CODES map context is
* CODES_MCTX_GROUP_MODULO with the supplied annotation arguments.
void
model_net_event_annotated
void
int
net_id
int
net_id
@@ -203,10 +206,32 @@ void model_net_event_annotated(
int
self_event_size
int
self_event_size
void
const
self_event
void
const
self_event
tw_lp
sender
tw_lp
sender
* See model_net_event for a general description.
* This variant uses CODES map contexts to calculate the sender and receiver
* modelnet LPs
void
model_net_event_mctx
int
net_id
struct
codes_mctx
const
send_map_ctx
struct
codes_mctx
const
recv_map_ctx
char
const
category
tw_lpid
final_dest_lp
uint64_t
message_size
tw_stime
offset
int
remote_event_size
void
const
remote_event
int
self_event_size
void
const
self_event
tw_lp
sender
/* model_net_find_local_device()
* returns the LP id of the network card attached to the calling LP
* returns the LP id of the network card attached to the calling LP using the
* default CODES mapping context if ignore_annotations is true, and
* CODES_MCTX_GROUP_MODULO with the supplied annotation parameters otherwise
tw_lpid
tw_lpid
int
net_id
int
net_id
@@ -214,6 +239,12 @@ tw_lpid model_net_find_local_device(
int
ignore_annotations
int
ignore_annotations
tw_lpid
sender_gid
tw_lpid
sender_gid
/* same as ^, except use the supplied mapping context */
tw_lpid
model_net_find_local_device_mctx
int
net_id
struct
codes_mctx
const
map_ctx
tw_lpid
sender_gid
int
model_net_get_msg_sz
int
net_id
int
int
net_id
/* model_net_event_rc()
@@ -263,6 +294,17 @@ void model_net_pull_event_annotated(
int
self_event_size
int
self_event_size
void
const
self_event
void
const
self_event
tw_lp
sender
tw_lp
sender
void
model_net_pull_event_mctx
int
net_id
struct
codes_mctx
const
send_map_ctx
struct
codes_mctx
const
recv_map_ctx
char
const
category
tw_lpid
final_dest_lp
uint64_t
message_size
tw_stime
offset
int
self_event_size
void
const
self_event
tw_lp
sender
void
model_net_pull_event_rc
void
int
net_id
int
net_id
tw_lp
sender
tw_lp
sender
View file @
fccb830b
@@ -29,8 +29,9 @@ struct terminal_message
tw_lpid
final_dest_gid
tw_lpid
final_dest_gid
/*sending LP ID from CODES, can be a server or any other LP type */
tw_lpid
sender_lp
tw_lpid
sender_lp
tw_lpid
sender_mn_lp
// source modelnet id
/* destination terminal ID of the dragonfly */
unsigned
int
dest_terminal_id
tw_lpid
dest_terminal_id
/* source terminal ID of the dragonfly */
unsigned
int
src_terminal_id
unsigned
int
src_terminal_id
/* local LP ID to calculate the radix of the sender node/router */
codes/net/loggp.h
View file @
fccb830b
@@ -23,7 +23,9 @@ struct loggp_message
int
magic
/* magic number */
int
magic
/* magic number */
enum
loggp_event_type
event_type
enum
loggp_event_type
event_type
tw_lpid
src_gid
/* who transmitted this msg? */
tw_lpid
src_gid
tw_lpid
src_mn_lp
// src modelnet id, provided by sender
tw_lpid
final_dest_gid
/* who is eventually targetted with this msg? */
tw_lpid
final_dest_gid
tw_lpid
dest_mn_lp
// destination modelnet id, provided by sender
uint64_t
net_msg_size_bytes
/* size of modeled network message */
uint64_t
net_msg_size_bytes
int
event_size_bytes
/* size of simulator event message that will be tunnelled to destination */
int
event_size_bytes
int
local_event_size_bytes
/* size of simulator event message that delivered locally upon local completion */
int
View file @
fccb830b
@@ -21,7 +21,9 @@ struct sn_message
int
magic
/* magic number */
int
magic
/* magic number */
enum
sn_event_type
event_type
enum
sn_event_type
event_type
tw_lpid
src_gid
tw_lpid
src_gid
tw_lpid
src_mn_lp
tw_lpid
final_dest_gid
tw_lpid
final_dest_gid
tw_lpid
dest_mn_lp
uint64_t
net_msg_size_bytes
uint64_t
net_msg_size_bytes
int
event_size_bytes
int
event_size_bytes
int
int
View file @
fccb830b
@@ -20,7 +20,9 @@ struct sp_message
int
magic
/* magic number */
int
magic
/* magic number */
enum
sp_event_type
event_type
enum
sp_event_type
event_type
tw_lpid
src_gid
tw_lpid
src_gid
tw_lpid
src_mn_lp
tw_lpid
final_dest_gid
tw_lpid
final_dest_gid
tw_lpid
dest_mn_lp
/* relative ID of the sending simplep2p message (for latency/bandwidth lookup) */
int
src_mn_rel_id
int
src_mn_rel_id
int
dest_mn_rel_id
/* included to make rc easier */
int
dest_mn_rel_id
View file @
fccb830b
@@ -426,7 +426,7 @@ void dragonfly_collective_init(terminal_state * s,
/* dragonfly packet event , generates a dragonfly packet on the compute node */
static
tw_stime
dragonfly_packet_event
char
category
tw_lpid
final_dest
_lp
uint64_t
packet_size
int
is_pull
uint64_t
pull_size
tw_stime
offset
const
mn_sched_params
sched_params
int
remote_event_size
const
void
remote_event
int
self_event_size
const
void
self_event
tw_lpid
src_lp
tw_lp
sender
int
is_last_pckt
static
tw_stime
char
const
category
tw_lpid
final_dest_lp
tw_lpid
dest_mn
_lp
uint64_t
packet_size
int
is_pull
uint64_t
pull_size
tw_stime
offset
const
mn_sched_params
sched_params
int
remote_event_size
const
void
remote_event
int
self_event_size
const
void
self_event
tw_lpid
src_lp
tw_lp
sender
int
is_last_pckt
tw_event
e_new
tw_event
e_new
tw_stime
xfer_to_nic_time
tw_stime
xfer_to_nic_time
@@ -438,7 +438,9 @@ static tw_stime dragonfly_packet_event(char* category, tw_lpid final_dest_lp, ui
sender
DRAGONFLY
void
msg
void
tmp_ptr
sender
DRAGONFLY
void
msg
void
tmp_ptr
strcpy
msg
category
category
strcpy
msg
category
category
msg
final_dest_gid
final_dest_lp
msg
final_dest_gid
final_dest_lp
msg
dest_terminal_id
dest_mn_lp
msg
sender_lp
src_lp
msg
sender_lp
src_lp
msg
sender_mn_lp
sender
gid
msg
packet_size
packet_size
msg
packet_size
packet_size
msg
remote_event_size_bytes
0
msg
0
msg
0
msg
0
@@ -594,12 +596,7 @@ static void packet_generate(terminal_state * s,
terminal_message
msg
terminal_message
msg
tw_lp
lp
tw_lp
lp
tw_lpid
dest_terminal_id
const
dragonfly_param
p
s
params
dest_terminal_id
DRAGONFLY
s
anno
0
msg
final_dest_gid
msg
dest_terminal_id
dest_terminal_id
const
dragonfly_param
p
s
params
tw_stime
ts
tw_stime
ts
tw_event
e
tw_event
e
@@ -634,7 +631,6 @@ static void packet_generate(terminal_state * s,
e
model_net_method_event_new
lp
gid
i
ts
lp
DRAGONFLY
e
lp
gid
i
ts
lp
DRAGONFLY
void
m
m_data
void
m
m_data
memcpy
m
msg
sizeof
terminal_message
memcpy
m
msg
sizeof
terminal_message
m
dest_terminal_id
dest_terminal_id
void
m_data_src
model_net_method_get_edata
DRAGONFLY
msg
void
m_data_src
DRAGONFLY
msg
if
msg
if
msg
memcpy
m_data
m_data_src
msg
memcpy
m_data
m_data_src
msg
@@ -648,7 +644,6 @@ static void packet_generate(terminal_state * s,
m
saved_vc
0
m
saved_vc
0
m
chunk_id
i
m
chunk_id
i
m
magic
terminal_magic_num
m
magic
terminal_magic_num
/* if(msg->packet_ID == TRACK && msg->chunk_id == num_chunks-1)
printf("\n packet generated %lld at terminal %d chunk id %d ", msg->packet_ID, (int)lp->gid, i);
@@ -881,10 +876,14 @@ if( msg->packet_ID == TRACK && msg->chunk_id == num_chunks-1)
void
tmp_ptr
DRAGONFLY
msg
void
tmp_ptr
DRAGONFLY
msg
ts
g_tw_lookahead
0
1
1
s
params
cn_bandwidth
msg
ts
g_tw_lookahead
0
1
1
s
params
cn_bandwidth
msg
if
msg
is_pull
if
msg
is_pull
struct
codes_mctx
mc_dst
codes_mctx_set_global_direct
msg
sender_mn_lp
struct
codes_mctx
mc_src
lp
gid
int
net_id
model_net_get_id
LP_METHOD_NM
int
net_id
model_net_get_id
LP_METHOD_NM
model_net_event
net_id
msg
category
msg
sender_lp
model_net_event
_mctx
net_id
mc_src
mc_dst
msg
category
msg
pull_size
ts
msg
s
msg
sender_lp
msg
pull_size
t
s
tmp_ptr
0
NULL
lp
msg
tmp_ptr
0
NULL
lp
else
else
e
tw_event_new
msg
final_dest_gid
ts
lp
e
tw_event_new
msg
final_dest_gid
ts
lp
@@ -2071,22 +2070,6 @@ static const tw_lptype* dragonfly_get_router_lp_type(void)
return
dragonfly_lps
1
return
dragonfly_lps
1
static
tw_lpid
dragonfly_find_local_device
const
char
annotation
int
ignore_annotations
tw_lp
sender
int
mapping_grp_id
mapping_rep_id
mapping_type_id
mapping_offset
tw_lpid
dest_id
codes_mapping_get_lp_info
sender
gid
lp_group_name
mapping_grp_id
NULL
mapping_type_id
NULL
mapping_rep_id
mapping_offset
codes_mapping_get_lp_id
lp_group_name
LP_CONFIG_NM
annotation
ignore_annotations
mapping_rep_id
mapping_offset
dest_id
return
dest_id
static
void
dragonfly_register
tw_lptype
base_type
static
void
dragonfly_register
tw_lptype
base_type
lp_type_register
LP_CONFIG_NM
base_type
lp_type_register
LP_CONFIG_NM
base_type
lp_type_register
"dragonfly_router"
dragonfly_lps
1
lp_type_register
"dragonfly_router"
dragonfly_lps
1
@@ -2104,7 +2087,6 @@ struct model_net_method dragonfly_method =
mn_get_lp_type
dragonfly_get_cn_lp_type
mn_get_lp_type
mn_get_msg_sz
dragonfly_get_msg_sz
mn_get_msg_sz
mn_report_stats
dragonfly_report_stats
mn_report_stats
NULL
mn_collective_call
mn_collective_call
dragonfly_collective_rc
View file @
fccb830b
@@ -110,8 +110,9 @@ static void loggp_set_params(const char * config_file, loggp_param * params);
/* Issues a loggp packet event call */
static
tw_stime
loggp_packet_event
static
tw_stime
loggp_packet_event
char
category
char
const
category
tw_lpid
final_dest_lp
tw_lpid
final_dest_lp
tw_lpid
dest_mn_lp
uint64_t
packet_size
uint64_t
packet_size
int
is_pull
int
is_pull
uint64_t
pull_size
uint64_t
pull_size
@@ -129,6 +130,7 @@ static void loggp_packet_event_rc(tw_lp *sender);
tw_stime
loggp_recv_msg_event
tw_stime
const
char
category
const
char
category
tw_lpid
final_dest_lp
tw_lpid
final_dest_lp
tw_lpid
src_mn_lp
uint64_t
msg_size
uint64_t
msg_size
int
is_pull
int
is_pull
uint64_t
pull_size
uint64_t
pull_size
@@ -142,11 +144,6 @@ void loggp_recv_msg_event_rc(tw_lp *sender);
static
void
loggp_report_stats
static
void
loggp_report_stats
static
tw_lpid
loggp_find_local_device
const
char
annotation
int
ignore_annotations
tw_lp
sender
static
const
struct
param_table_entry
find_params
static
const
struct
param_table_entry
find_params
uint64_t
msg_size
uint64_t
msg_size
const
loggp_param
params
const
loggp_param
params
@@ -163,7 +160,6 @@ struct model_net_method loggp_method =
mn_get_lp_type
loggp_get_lp_type
mn_get_lp_type
loggp_get_lp_type
mn_get_msg_sz
loggp_get_msg_sz
mn_get_msg_sz
loggp_get_msg_sz
mn_report_stats
loggp_report_stats
mn_report_stats
loggp_report_stats
NULL
mn_collective_call
loggp_collective
mn_collective_call
loggp_collective
loggp_collective_rc
loggp_collective_rc
@@ -438,10 +434,14 @@ static void handle_msg_ready_event(
//tmp_ptr += loggp_get_msg_sz();
if
m
is_pull
if
m
is_pull
/* call the model-net event */
struct
codes_mctx
mc_dst
m
src_mn_lp
struct
codes_mctx
mc_src
lp
gid
int
net_id
model_net_get_id
LP_METHOD_NM
int
net_id
model_net_get_id
LP_METHOD_NM
model_net_event
net_id
m
category
m
src_gid
m
pull_size
model_net_event
_mctx
net_id
mc_src
mc_dst
m
category
recv_queue_time
m
event_size_bytes
tmp_ptr
0
NULL
m
src_gid
m
pull_size
recv_queue_time
lp
m
event_size_bytes
tmp_ptr
0
NULL
lp
else
else
e_new
tw_event_new
m
final_dest_gid
recv_queue_time
lp
e_new
tw_event_new
m
final_dest_gid
recv_queue_time
lp
@@ -503,9 +503,6 @@ static void handle_msg_start_event(
loggp_message
m_new
loggp_message
m_new
tw_stime
send_queue_time
0
tw_stime
send_queue_time
0
mn_stats
stat
mn_stats
stat
int
mapping_grp_id
mapping_type_id
mapping_rep_id
mapping_offset
tw_lpid
dest_id
char
lp_group_name
MAX_NAME_LENGTH
int
total_event_size
int
total_event_size
double
xmit_time
double
xmit_time
const
struct
param_table_entry
param
const
struct
param_table_entry
param
@@ -549,10 +546,6 @@ static void handle_msg_start_event(
ns
net_send_next_idle
tw_now
lp
ns
net_send_next_idle
tw_now
lp
ns
net_send_next_idle
xmit_time
param
g
1000
0
ns
net_send_next_idle
xmit_time
param
g
1000
0
/* create new event to send msg to receiving NIC */
dest_id
LOGGP
ns
anno
0
m
final_dest_gid
dprintf
"%lu (mn): start msg %lu->%lu, size %lu (%3s last)
\n
dprintf
\n
" now:%0.3le, idle[prev:%0.3le, next:%0.3le], "
"q-time:%0.3le
\n
"q-time:%0.3le
\n
@@ -562,16 +555,13 @@ static void handle_msg_start_event(
send_queue_time
send_queue_time
#if USE_RECV_QUEUE
#if USE_RECV_QUEUE
model_net_method_send_msg_recv_event
m
final_dest_gid
dest_id
m
src_gid
m
final_dest_gid
m
dest_mn_lp
m
net_msg_size_bytes
m
is_pull
m
pull_size
m
src_gid
m
net_msg_size_bytes
m
is_pull
m
pull_size
m
event_size_bytes
m
sched_params
m
category
LOGGP
m
m
event_size_bytes
m
sched_params
m
category
LOGGP
m
send_queue_time
lp
send_queue_time
lp
#else
#else
void
m_data
void
m_data
// printf("\n msg start sending to %d ", dest_id);
e_new
m
dest_mn_lp
send_queue_time
lp
LOGGP
//e_new = tw_event_new(dest_id, send_queue_time, lp);
//m_new = tw_event_data(e_new);
e_new
dest_id
send_queue_time
lp
LOGGP
void
m_new
m_data
void
m_new
m_data
/* copy entire previous message over, including payload from user of
* this module
* this module
@@ -618,8 +608,9 @@ static void handle_msg_start_event(
/*This method will serve as an intermediate layer between loggp and modelnet.
* It takes the packets from modelnet layer and calls underlying loggp methods*/
static
tw_stime
loggp_packet_event
static
tw_stime
loggp_packet_event
char
category
char
const
category
tw_lpid
final_dest_lp
tw_lpid
final_dest_lp
tw_lpid
dest_mn_lp
uint64_t
packet_size
uint64_t
packet_size
int
is_pull
int
is_pull
uint64_t
pull_size
uint64_t
pull_size
@@ -645,7 +636,9 @@ static tw_stime loggp_packet_event(
//msg = tw_event_data(e_new);
strcpy
msg
category
category
strcpy
msg
category
category
msg
final_dest_gid
final_dest_lp
msg
final_dest_gid
final_dest_lp
msg
dest_mn_lp
dest_mn_lp
msg
src_gid
src_lp
msg
src_gid
src_lp
msg
src_mn_lp
sender
gid
msg
magic
loggp_get_magic
msg
magic
loggp_get_magic
msg
net_msg_size_bytes
packet_size
msg
net_msg_size_bytes
packet_size
msg
event_size_bytes
0
msg
event_size_bytes
0
@@ -683,6 +676,7 @@ static tw_stime loggp_packet_event(
tw_stime
tw_stime
const
char
category
const
char
category
tw_lpid
final_dest_lp
tw_lpid
final_dest_lp
tw_lpid
src_mn_lp
uint64_t
msg_size
uint64_t
msg_size
int
is_pull
int
is_pull
uint64_t
pull_size
uint64_t
pull_size
@@ -703,6 +697,7 @@ tw_stime loggp_recv_msg_event(
m
magic
loggp_magic
m
magic
loggp_magic
m
event_type
LG_MSG_READY
m
event_type
LG_MSG_READY
m
src_gid
src_lp
m
src_gid
src_lp
m
src_mn_lp
src_mn_lp
m
final_dest_gid
final_dest_lp
m
final_dest_gid
final_dest_lp
m
net_msg_size_bytes
msg_size
m
net_msg_size_bytes
msg_size
m
event_size_bytes
remote_event_size
m
event_size_bytes
remote_event_size
@@ -834,25 +829,6 @@ static const struct param_table_entry* find_params(
return
params
table
i
return
params
table
i
static
tw_lpid
const
char
annotation
int
ignore_annotations
tw_lp
sender
char
lp_group_name
MAX_NAME_LENGTH
int
mapping_grp_id
mapping_rep_id
mapping_type_id
mapping_offset
tw_lpid
dest_id
//TODO: be annotation-aware
sender
gid
lp_group_name
mapping_grp_id
NULL
mapping_type_id
NULL
mapping_rep_id
mapping_offset
lp_group_name
LP_CONFIG_NM
annotation
ignore_annotations
mapping_rep_id
mapping_offset
dest_id
return
dest_id
* Local variables:
* Local variables:
* c-indent-level: 4
* c-indent-level: 4
View file @
fccb830b
@@ -534,6 +534,8 @@ void model_net_method_send_msg_recv_event(
m
msg
m_base
req
final_dest_lp
final_dest_lp
m
msg
m_base
req
final_dest_lp
final_dest_lp
m
msg
m_base
req
src_lp
src_lp
m
msg
m_base
req
src_lp
src_lp
// for "recv" events, set the "dest" to this LP in the case of a pull event
m
msg
m_base
req
dest_mn_lp
sender
gid
m
msg
m_base
req
msg_size
is_pull
pull_size
msg_size
m
msg
m_base
req
msg_size
is_pull
pull_size
msg_size
m
msg
m_base
req
packet_size
m
msg
m_base
req
msg_size
m
msg
m_base
req
packet_size
m
msg
m_base
req
msg_size
m
msg
m_base
req
net_id
net_id
m
msg
m_base
req
net_id
net_id
View file @
fccb830b
@@ -253,10 +253,12 @@ int fcfs_next(
"from %lu to %lu at %1.5e (last:%d)
\n
\n
lp
gid
psize
q
rem
q
req
src_lp
q
req
final_dest_lp
lp
gid
psize
q
rem
q
req
src_lp
q
req
final_dest_lp
tw_now
lp
is_last_packet
tw_now
lp
is_last_packet
// note: we overloaded on the dest_mn_lp field - it's the dest of the
// soruce in the case of a pull
poffset
s
method
q
req
category
poffset
s
method
q
req
category
q
req
final_dest_lp
psize
q
req
is_pull
q
req
msg_
size
q
req
final_dest_lp
q
req
dest_mn_lp
p
size
0
0
q
req
remote_event_size
q
remote_event
q
req
src_lp
q
req
is_pull
q
req
msg_size
0
0
q
req
remote_event_size
lp
q
remote_event
q
req
src_lp
lp
else
else
dprintf
"%lu (mn): issuing packet of size %lu (of %lu) "
dprintf
@@ -264,8 +266,9 @@ int fcfs_next(
lp
gid
psize
q
rem
q
req
src_lp
q
req
final_dest_lp
lp
gid
psize
q
rem
q
req
src_lp
q
req
final_dest_lp
tw_now
lp
is_last_packet
tw_now
lp
is_last_packet
poffset
s
method
q
req
category
poffset
s
method
q
req
category
q
req
final_dest_lp
psize
q
req
is_pull
q
req
msg_size
q
req
final_dest_lp
q
req
dest_mn_lp
psize
q
req
is_pull
0
0
q
sched_params
q
req
remote_event_size
q
remote_event
q
req
msg_size
0
0
q
sched_params
q
req
remote_event_size
q
remote_event
q
req
self_event_size
q
local_event
q
req
src_lp
lp
q
req
self_event_size
q
local_event
q
req
src_lp
lp
is_last_packet
is_last_packet
View file @
fccb830b
@@ -223,8 +223,8 @@ struct mn_stats* model_net_find_stats(char const * category, mn_stats mn_stats_a
static
void
model_net_event_impl_base
static
void
int
net_id
int
net_id
char
const
annotation
struct
codes_mctx
const
send_map_ctx
int
ignore_annotations
struct
codes_mctx
const
recv_map_ctx
char
const
category
char
const
category
tw_lpid
final_dest_lp
tw_lpid
final_dest_lp
uint64_t
message_size
uint64_t
message_size
@@ -245,15 +245,18 @@ static void model_net_event_impl_base(
return
return
tw_lpid
mn_lp
net_id
annotation
tw_lpid
src_mn_lp
net_id
send_map_ctx
ignore_annotations
sender
gid
sender
gid
tw_lpid
dest_mn_lp
net_id
recv_map_ctx
final_dest_lp
tw_stime
poffset
codes_local_latency
sender
tw_stime
poffset
codes_local_latency
sender
if
mn_in_seqence
if
mn_in_seqence
tw_stime
tmp
mn_msg_offset
tw_stime
tmp
mn_msg_offset
mn_msg_offset
poffset
mn_msg_offset
poffset
poffset
tmp
