Commit fc323efd authored by Neil McGlohon's avatar Neil McGlohon
Browse files
Connection Manager: Update Schema
parent 029b7f2b
...@@ -33,8 +33,12 @@ enum ConnectionType ...@@ -33,8 +33,12 @@ enum ConnectionType
struct Connection struct Connection
int port; //port ID of the connection int port; //port ID of the connection
int other_id; //id of the destination - depends on type of connection int src_lid; //local id of the source
int group_id; //group id of the destination int src_gid; //global id of the source
int src_group_id; //group id of the source
int dest_lid; //local id of the destination
int dest_gid; //global id of the destination
int dest_group_id; //group id of the destination
ConnectionType conn_type; //type of the connection: CONN_LOCAL, CONN_GLOBAL, or CONN_TERMINAL ConnectionType conn_type; //type of the connection: CONN_LOCAL, CONN_GLOBAL, or CONN_TERMINAL
...@@ -89,11 +93,10 @@ public: ...@@ -89,11 +93,10 @@ public:
* @brief Adds a connection to the manager * @brief Adds a connection to the manager
* @param dest_id the ID of the destination router, local if type is local, global if type is global * @param dest_gid the global ID of the destination router
* @param group_id the group id of the destination router
* @param type the type of the connection, CONN_LOCAL, CONN_GLOBAL, or CONN_TERMINAL * @param type the type of the connection, CONN_LOCAL, CONN_GLOBAL, or CONN_TERMINAL
void add_connection(int dest_id, int group_id, ConnectionType type); void add_connection(int dest_gid, ConnectionType type);
// * @brief adds knowledge of what next hop routers have connections to specific groups // * @brief adds knowledge of what next hop routers have connections to specific groups
...@@ -162,13 +165,18 @@ public: ...@@ -162,13 +165,18 @@ public:
int get_used_ports_for(ConnectionType type); int get_used_ports_for(ConnectionType type);
* @brief returns the type of connection associated with said port
* @param port_num the number of the port in question
ConnectionType get_port_type(int port_num);
* @brief returns a vector of connections to the destination ID based on the connection type * @brief returns a vector of connections to the destination ID based on the connection type
* @param dest_id the ID of the destination depending on the type * @param dest_id the ID of the destination depending on the type
* @note note that the method is called get connections to router but could also apply to terminal connections
vector< Connection > get_connections_to_router(int dest_id, ConnectionType type); vector< Connection > get_connections_to_gid(int dest_id, ConnectionType type);
* @brief returns a vector of connections to the destination group. connections will be of type CONN_GLOBAL * @brief returns a vector of connections to the destination group. connections will be of type CONN_GLOBAL
...@@ -210,30 +218,35 @@ ConnectionManager::ConnectionManager(int src_id_local, int src_id_global, int sr ...@@ -210,30 +218,35 @@ ConnectionManager::ConnectionManager(int src_id_local, int src_id_global, int sr
_num_routers_per_group = num_router_per_group; _num_routers_per_group = num_router_per_group;
void ConnectionManager::add_connection(int dest_id, int dest_group, ConnectionType type) void ConnectionManager::add_connection(int dest_gid, ConnectionType type)
Connection conn; Connection conn;
conn.src_lid = _source_id_local;
conn.src_gid = _source_id_global;
conn.src_group_id = _source_group;
conn.conn_type = type; conn.conn_type = type;
conn.other_id = dest_id; conn.dest_lid = dest_gid % _num_routers_per_group;
conn.group_id = dest_group; conn.dest_gid = dest_gid;
conn.dest_group_id = dest_gid / _num_routers_per_group;
switch (type) switch (type)
case CONN_LOCAL: case CONN_LOCAL:
conn.port = this->get_used_ports_for(CONN_LOCAL); conn.port = this->get_used_ports_for(CONN_LOCAL);
intraGroupConnections[dest_id].push_back(conn); intraGroupConnections[conn.dest_lid].push_back(conn);
_used_intra_ports++; _used_intra_ports++;
break; break;
case CONN_GLOBAL: case CONN_GLOBAL:
conn.port = _max_intra_ports + this->get_used_ports_for(CONN_GLOBAL); conn.port = _max_intra_ports + this->get_used_ports_for(CONN_GLOBAL);
globalConnections[dest_id].push_back(conn); globalConnections[conn.dest_gid].push_back(conn);
_used_inter_ports++; _used_inter_ports++;
break; break;
case CONN_TERMINAL: case CONN_TERMINAL:
conn.port = _max_intra_ports + _max_inter_ports + this->get_used_ports_for(CONN_TERMINAL); conn.port = _max_intra_ports + _max_inter_ports + this->get_used_ports_for(CONN_TERMINAL);
terminalConnections[dest_id].push_back(conn); conn.dest_group_id = _source_group;
terminalConnections[conn.dest_gid].push_back(conn);
_used_terminal_ports++; _used_terminal_ports++;
break; break;
...@@ -284,7 +297,7 @@ int ConnectionManager::get_source_id(ConnectionType type) ...@@ -284,7 +297,7 @@ int ConnectionManager::get_source_id(ConnectionType type)
vector<int> ConnectionManager::get_ports(int dest_id, ConnectionType type) vector<int> ConnectionManager::get_ports(int dest_id, ConnectionType type)
vector< Connection > conns = this->get_connections_to_router(dest_id, type); vector< Connection > conns = this->get_connections_to_gid(dest_id, type);
vector< int > ports_used; vector< int > ports_used;
vector< Connection >::iterator it = conns.begin(); vector< Connection >::iterator it = conns.begin();
...@@ -356,16 +369,22 @@ int ConnectionManager::get_used_ports_for(ConnectionType type) ...@@ -356,16 +369,22 @@ int ConnectionManager::get_used_ports_for(ConnectionType type)
vector< Connection > ConnectionManager::get_connections_to_router(int dest_id, ConnectionType type) ConnectionType ConnectionManager::get_port_type(int port_num)
return _portMap[port_num].conn_type;
vector< Connection > ConnectionManager::get_connections_to_gid(int dest_gid, ConnectionType type)
return intraGroupConnections[dest_id]; return intraGroupConnections[dest_gid%_num_routers_per_group];
return globalConnections[dest_id]; return globalConnections[dest_gid];
return terminalConnections[dest_id]; return terminalConnections[dest_gid];
default: default:
assert(false); assert(false);
// TW_ERROR(TW_LOC, "get_connections(type): Undefined connection type\n"); // TW_ERROR(TW_LOC, "get_connections(type): Undefined connection type\n");
...@@ -382,7 +401,7 @@ vector< Connection > ConnectionManager::get_connections_to_group(int dest_group_ ...@@ -382,7 +401,7 @@ vector< Connection > ConnectionManager::get_connections_to_group(int dest_group_
vector< Connection >::iterator conns_to_router; vector< Connection >::iterator conns_to_router;
for(conns_to_router = (it->second).begin(); conns_to_router != (it->second).end(); conns_to_router++) //iterate over each connection to a specific router for(conns_to_router = (it->second).begin(); conns_to_router != (it->second).end(); conns_to_router++) //iterate over each connection to a specific router
if ((*conns_to_router).group_id == dest_group_id) { if ((*conns_to_router).dest_group_id == dest_group_id) {
conns_to_group.push_back(*conns_to_router); conns_to_group.push_back(*conns_to_router);
...@@ -441,7 +460,24 @@ void ConnectionManager::print_connections() ...@@ -441,7 +460,24 @@ void ConnectionManager::print_connections()
printf(" Port | Dest_ID | Group\n"); printf(" Port | Dest_ID | Group\n");
printf(" %d -> %d : %d \n", it->first, it->second.other_id, it->second.group_id); int port_num = it->first;
int group_id = it->second.dest_group_id;
int id,gid;
if( get_port_type(port_num) == CONN_LOCAL )
id = it->second.dest_lid;
gid = it->second.dest_gid;
printf(" %d -> (%d,%d) : %d \n", port_num, id, gid, group_id);
else {
printf(" %d -> %d : %d \n", port_num, id, group_id);
ports_printed++; ports_printed++;
Markdown is supported
0% or .
Please register or to comment
