Commit f9ee1142 authored by Shane Snyder's avatar Shane Snyder
Browse files
Updated replay tool buffer allocation
parent 0d4cd618
...@@ -194,6 +194,8 @@ int load_workload(char *conf_path, int rank) ...@@ -194,6 +194,8 @@ int load_workload(char *conf_path, int rank)
char* buf = NULL; char* buf = NULL;
int fd = -1;
int op_num = 0;
int main(int argc, char *argv[]) int main(int argc, char *argv[])
...@@ -257,13 +259,6 @@ int main(int argc, char *argv[]) ...@@ -257,13 +259,6 @@ int main(int argc, char *argv[])
goto error_exit; goto error_exit;
buf = malloc(16*1024*1024);
assert(buf);
for(i=0; i<16*1024*1024; i++)
buf[i] = '1';
/* synchronize before replay */ /* synchronize before replay */
MPI_Barrier(MPI_COMM_WORLD); MPI_Barrier(MPI_COMM_WORLD);
...@@ -325,6 +320,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -325,6 +320,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
struct file_info *tmp_list = NULL; struct file_info *tmp_list = NULL;
struct qlist_head *hash_link = NULL; struct qlist_head *hash_link = NULL;
int ret; int ret;
int i;
#if DEBUG_PROFILING #if DEBUG_PROFILING
double start, end; double start, end;
...@@ -417,6 +413,16 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -417,6 +413,16 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
tmp_list->file_descriptor = fildes; tmp_list->file_descriptor = fildes;
qhash_add(fd_table, &(replay_op.u.open.file_id), &(tmp_list->hash_link)); qhash_add(fd_table, &(replay_op.u.open.file_id), &(tmp_list->hash_link));
if (!buf)
assert(buf);
buf[i] = '1';
end = MPI_Wtime(); end = MPI_Wtime();
total_open_time += (end - start); total_open_time += (end - start);
...@@ -467,19 +473,8 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -467,19 +473,8 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
tmp_list = qhash_entry(hash_link, struct file_info, hash_link); tmp_list = qhash_entry(hash_link, struct file_info, hash_link);
fildes = tmp_list->file_descriptor; fildes = tmp_list->file_descriptor;
#if 0
/* perform the write operation */
buf = malloc(replay_op.u.write.size);
if (!buf)
fprintf(stderr, "No memory available for write buffer\n");
return -1;
#endif
ret = pwrite(fildes, buf, replay_op.u.write.size, replay_op.u.write.offset); ret = pwrite(fildes, buf, replay_op.u.write.size, replay_op.u.write.offset);
#if 0
free(buf);
#endif
if (ret < 0) if (ret < 0)
fprintf(stderr, "Rank %d failure on operation %lld [WRITE: %s]\n", fprintf(stderr, "Rank %d failure on operation %lld [WRITE: %s]\n",
...@@ -507,19 +502,8 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -507,19 +502,8 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
#if 0
buf = malloc(replay_op.u.read.size);
if (!buf)
return -1;
#endif
ret = pread(fildes, buf, replay_op.u.read.size, replay_op.u.read.offset); ret = pread(fildes, buf, replay_op.u.read.size, replay_op.u.read.offset);
#if 0
free(buf);
#endif
fprintf(stderr, "Rank %d failure on operation %lld [READ: %s]\n", fprintf(stderr, "Rank %d failure on operation %lld [READ: %s]\n",
Markdown is supported
0% or .
Please register or to comment
