Commit f8ebb23d authored by yangxuserene's avatar yangxuserene
test merge
parents 3d917701 3bfbd0c6
...@@ -11,9 +11,9 @@ ...@@ -11,9 +11,9 @@
* Example: * Example:
* job 0 1 2 * job 0 1 2 (<-- jobmap defined "local" IDs)
* rank 0 1 2 0 1 0 1 2 3 * rank 0 1 2 0 1 0 1 2 3 (<-- jobmap defined "local" IDs)
* ID 0 1 2 3 4 5 6 7 8 (<-- LP relative ID) * ID 0 1 2 3 4 5 6 7 8 (<-- LP relative "global" ID)
* LP A B C D E F G H I (<-- provided by codes-mapping) * LP A B C D E F G H I (<-- provided by codes-mapping)
...@@ -46,10 +46,20 @@ codes_jobmap_configure(enum codes_jobmap_type t, void const * params); ...@@ -46,10 +46,20 @@ codes_jobmap_configure(enum codes_jobmap_type t, void const * params);
void codes_jobmap_destroy(struct codes_jobmap_ctx *c); void codes_jobmap_destroy(struct codes_jobmap_ctx *c);
struct codes_jobmap_id codes_jobmap_lookup( /* main mapping functions - bidirectional mapping is needed:
* - global -> local ID for initialization
* - local -> global ID for communication between local IDs
* functions return {-1, -1} and -1, respectively, for invalid id input */
struct codes_jobmap_id codes_jobmap_to_local_id(
int id, int id,
struct codes_jobmap_ctx const * c); struct codes_jobmap_ctx const * c);
int codes_jobmap_to_global_id(
struct codes_jobmap_id id,
int codes_jobmap_get_num_jobs(struct codes_jobmap_ctx const * c); int codes_jobmap_get_num_jobs(struct codes_jobmap_ctx const * c);
#endif #endif
...@@ -13,10 +13,11 @@ ...@@ -13,10 +13,11 @@
struct codes_jobmap_impl { struct codes_jobmap_impl {
/* returns nonzero on failure (to distinguish between no-state (dummy) and /* returns nonzero on failure (to distinguish between no-state (dummy) and
* failure) */ * failure) */
int (*configure)(void const * params, void ** ctx); int (*configure)(void const * params, void ** ctx);
void (*destroy)(void * ctx); void (*destroy)(void * ctx);
struct codes_jobmap_id (*lookup) (int id, void const * ctx); struct codes_jobmap_id (*to_local) (int id, void const * ctx);
int (*get_num_jobs)(void const * ctx); int (*to_global) (struct codes_jobmap_id id, void const * ctx);
struct codes_jobmap_ctx { struct codes_jobmap_ctx {
...@@ -45,11 +45,18 @@ void codes_jobmap_destroy(struct codes_jobmap_ctx *c) ...@@ -45,11 +45,18 @@ void codes_jobmap_destroy(struct codes_jobmap_ctx *c)
free(c); free(c);
struct codes_jobmap_id codes_jobmap_lookup( struct codes_jobmap_id codes_jobmap_to_local_id(
int id, int id,
struct codes_jobmap_ctx const * c) struct codes_jobmap_ctx const * c)
return c->impl->lookup(id, c->ctx); return c->impl->to_local(id, c->ctx);
return c->impl->to_global(id, c->ctx);
int codes_jobmap_get_num_jobs(struct codes_jobmap_ctx const * c) int codes_jobmap_get_num_jobs(struct codes_jobmap_ctx const * c)
static int jobmap_dummy_configure(void const * params, void ** ctx) static int jobmap_dummy_configure(void const * params, void ** ctx)
int *num_jobs = *ctx; int *num_jobs = malloc(sizeof(*num_jobs));
assert(num_jobs); assert(num_jobs);
*ctx = num_jobs;
struct codes_jobmap_params_dummy const * p = params; struct codes_jobmap_params_dummy const * p = params;
...@@ -27,18 +27,34 @@ static void jobmap_dummy_destroy(void * ctx) ...@@ -27,18 +27,34 @@ static void jobmap_dummy_destroy(void * ctx)
free(ctx); free(ctx);
static struct codes_jobmap_id jobmap_dummy_lookup(int id, void const * ctx)
static struct codes_jobmap_id jobmap_dummy_to_local(int id, void const * ctx)
int const * num_jobs = ctx; int const * num_jobs = ctx;
struct codes_jobmap_id rtn = {-1, -1}; struct codes_jobmap_id rtn;
if (id >= *num_jobs) { if (id < *num_jobs) {
rtn.job = id; rtn.job = id;
rtn.rank = 0; rtn.rank = 0;
else {
rtn.job = -1;
rtn.rank = -1;
return rtn; return rtn;
static int jobmap_dummy_to_global(struct codes_jobmap_id id, void const * ctx)
if (id.job < *num_jobs)
return id.job;
else
return -1;
int jobmap_dummy_get_num_jobs(void const * ctx) int jobmap_dummy_get_num_jobs(void const * ctx)
return *(int const *) ctx; return *(int const *) ctx;
...@@ -47,7 +63,8 @@ int jobmap_dummy_get_num_jobs(void const * ctx) ...@@ -47,7 +63,8 @@ int jobmap_dummy_get_num_jobs(void const * ctx)
struct codes_jobmap_impl jobmap_dummy_impl = { struct codes_jobmap_impl jobmap_dummy_impl = {
jobmap_dummy_configure, jobmap_dummy_configure,
jobmap_dummy_destroy, jobmap_dummy_destroy,
jobmap_dummy_lookup, jobmap_dummy_to_local,
jobmap_dummy_to_global,
jobmap_dummy_get_num_jobs jobmap_dummy_get_num_jobs
...@@ -52,7 +52,7 @@ tests_rc_stack_test_SOURCES = tests/rc-stack-test.c ...@@ -52,7 +52,7 @@ tests_rc_stack_test_SOURCES = tests/rc-stack-test.c
tests_jobmap_test_LDADD = $(testlib) ${ROSS_LIBS} tests_jobmap_test_LDADD = $(testlib) ${ROSS_LIBS}
tests_jobmap_test_LDFLAGS = ${ROSS_LDFLAGS} tests_jobmap_test_LDFLAGS = ${ROSS_LDFLAGS}
tests_jobmap_test_SOURCES = tests/rc-stack-test.c tests_jobmap_test_SOURCES = tests/jobmap-test.c
tests_workload_codes_workload_test_LDADD = $(testlib) ${ROSS_LIBS} tests_workload_codes_workload_test_LDADD = $(testlib) ${ROSS_LIBS}
tests_workload_codes_workload_test_LDFLAGS = ${ROSS_LDFLAGS} tests_workload_codes_workload_test_LDFLAGS = ${ROSS_LDFLAGS}
...@@ -8,41 +8,68 @@ ...@@ -8,41 +8,68 @@
#include "codes/codes-jobmap.h" #include "codes/codes-jobmap.h"
const int N = 10;
int main(int argc, char *argv[])
struct codes_jobmap_ctx *c;
struct codes_jobmap_params_dummy p;
p.num_jobs = N;
#define ERR(str, ...) \ #define ERR(str, ...) \
do { \ do { \
fprintf(stderr, "ERROR: " str "\n", ##__VA_ARGS__); \ fprintf(stderr, "ERROR at %s:%d: " str "\n", __FILE__, __LINE__, ##__VA_ARGS__); \
return 1; \ return 1; \
} while(0) } while(0)
static int test_jobmap_dummy(int num_jobs)
p.num_jobs = num_jobs;
/* initialize */ /* initialize */
c = codes_jobmap_configure(CODES_JOBMAP_DUMMY, &p); c = codes_jobmap_configure(CODES_JOBMAP_DUMMY, &p);
if (c) ERR("jobmap configure failure"); if (!c) ERR("jobmap configure failure");
/* successful lookups */ struct codes_jobmap_id lid;
struct codes_jobmap_id id;
for (int i = 0; i < N; i++) { /* successful local lookups */
id = codes_jobmap_lookup(i, c); for (int i = 0; i < num_jobs; i++) {
if (id.job != i || id.rank != 0) lid = codes_jobmap_to_local_id(i, c);
if (lid.job != i || lid.rank != 0)
ERR("lookup failure for %d: expected (%d,%d), got (%d,%d)", ERR("lookup failure for %d: expected (%d,%d), got (%d,%d)",
i, i, 0, id.job, id.rank); i, i, 0, lid.job, lid.rank);
else {
lid.job = -1;
lid.rank = -1;
/* bad local lookup */
lid = codes_jobmap_to_local_id(num_jobs, c);
if (lid.job != -1 || lid.rank != -1)
ERR("lookup expected failure for %d: expected (%d,%d), got (%d,%d)",
num_jobs, -1,-1, lid.job,lid.rank);
/* successful global lookups */
int gid;
lid.rank = 0;
for (lid.job = 0; lid.job < num_jobs; lid.job++) {
gid = codes_jobmap_to_global_id(lid, c);
if (gid != lid.job)
ERR("lookup failure for (%d,%d): expected %d, got %d",
lid.job, lid.rank, lid.job, gid);
/* bad lookup */ /* bad global lookup */
id = codes_jobmap_lookup(10, c); lid.job = num_jobs;
if (id.job != -1 || id.rank != -1) gid = codes_jobmap_to_global_id(lid, c);
ERR("lookup expected failure for 10: expected (%d,%d), got (%d,%d)", if (gid != -1)
-1,-1, id.job,id.rank); ERR("lookup expected failure for (%d,0): expected -1, got %d",
num_jobs, gid);
/* cleanup */ /* cleanup */
codes_jobmap_destroy(c); codes_jobmap_destroy(c);
#undef ERR return 0;
int rc;
rc = test_jobmap_dummy(10);
if (rc) return rc;
return 0; return 0;
Markdown is supported
0%
or
Please register or to comment
