Commit f8e08380 authored by Jonathan Jenkins's avatar Jonathan Jenkins
fix multiple lsm msg ordering in single event
uses the same approach as was employed in model-net (MN_START_SEQ/END_SEQ)
parent 2b89b25f
...@@ -11,6 +11,21 @@ ...@@ -11,6 +11,21 @@
#define LSM_NAME "lsm" #define LSM_NAME "lsm"
/* HACK: problems arise when some LP sends multiple messages as part of an
* event and expects FCFS ordering. One could simply set a higher delay in
* delay, but that is hacky as well (and relies on knowing bounds on internal
* codes_local_latency bounds. Hence, expose explicit start-sequence and
* stop-sequence markers */
extern int in_sequence;
extern tw_stime lsm_msg_offset;
#define LSM_START_SEQ() do {\
in_sequence = 1; \
lsm_msg_offset = 0.0; \
} while (0)
#define LSM_END_SEQ() do {\
in_sequence = 0;\
} while (0)
* lsm_event_t * lsm_event_t
* - events supported by the local storage model * - events supported by the local storage model
...@@ -17,6 +17,8 @@ ...@@ -17,6 +17,8 @@
#define CATEGORY_NAME_MAX 16 #define CATEGORY_NAME_MAX 16
#define CATEGORY_MAX 12 #define CATEGORY_MAX 12
int in_sequence = 0;
tw_stime mn_msg_offset = 0.0;
* wrapped_event_t * wrapped_event_t
...@@ -294,6 +296,7 @@ tw_event* lsm_event_new(const char* category, ...@@ -294,6 +296,7 @@ tw_event* lsm_event_new(const char* category,
tw_event *e; tw_event *e;
lsm_message_t *m; lsm_message_t *m;
tw_lpid lsm_gid; tw_lpid lsm_gid;
tw_stime delta;
assert(strlen(category) < CATEGORY_NAME_MAX-1); assert(strlen(category) < CATEGORY_NAME_MAX-1);
assert(strlen(category) > 0); assert(strlen(category) > 0);
...@@ -303,7 +306,13 @@ tw_event* lsm_event_new(const char* category, ...@@ -303,7 +306,13 @@ tw_event* lsm_event_new(const char* category,
lsm_gid = lsm_find_local_device(sender); lsm_gid = lsm_find_local_device(sender);
e = codes_event_new(lsm_gid, codes_local_latency(sender)+delay, sender); delta = codes_local_latency(sender) + delay;
if (in_sequence) {
tw_stime tmp = lsm_msg_offset;
lsm_msg_offset += delta;
delta += tmp;
e = codes_event_new(lsm_gid, delta, sender);
m = tw_event_data(e); m = tw_event_data(e);
m->magic = lsm_magic; m->magic = lsm_magic;
m->event = io_type; m->event = io_type;
Markdown is supported
0%
or
Please register or to comment
