Commit f82e8e42 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
adding updated config files
parent c1935e46
...@@ -12,8 +12,10 @@ LPGROUPS ...@@ -12,8 +12,10 @@ LPGROUPS
PARAMS PARAMS
adaptive_threshold="8192"; adaptive_threshold="131072";
# minimal-bias="1"; num_qos_levels="2";
qos_bandwidth="30,70";
minimal-bias="1";
df-dally-vc = "1"; df-dally-vc = "1";
# packet size in the network # packet size in the network
packet_size="4096"; packet_size="4096";
...@@ -47,7 +49,7 @@ PARAMS ...@@ -47,7 +49,7 @@ PARAMS
# Number of column channels # Number of column channels
num_col_chans="1"; num_col_chans="1";
# ROSS message size # ROSS message size
message_size="640"; message_size="656";
# number of compute nodes connected to router, dictated by dragonfly config # number of compute nodes connected to router, dictated by dragonfly config
# file # file
num_cns_per_router="8"; num_cns_per_router="8";
...@@ -13,6 +13,9 @@ LPGROUPS ...@@ -13,6 +13,9 @@ LPGROUPS
PARAMS PARAMS
num_qos_levels="2";
modelnet_order=( "dragonfly_plus","dragonfly_plus_router" ); modelnet_order=( "dragonfly_plus","dragonfly_plus_router" );
# scheduler options # scheduler options
...@@ -43,19 +46,19 @@ PARAMS ...@@ -43,19 +46,19 @@ PARAMS
# bandwidth in GiB/s for compute node-router channels # bandwidth in GiB/s for compute node-router channels
cn_bandwidth="25.0"; cn_bandwidth="25.0";
message_size="624"; message_size="656";
# file # file
num_cns_per_router="16"; num_cns_per_router="16";
# number of global channels per router # number of global channels per router
num_global_connections="16"; num_global_connections="16";
# network config file for intra-group connections # network config file for intra-group connections
intra-group-connections="/home/mmubarak/codes-online/codes/src/network-workloads/conf/dragonfly-custom/dfp_8k_intra"; intra-group-connections="/home/mubarak/codes-online/codes/src/network-workloads/conf/dragonfly-custom/dfp_8k_intra";
# network config file for inter-group connections # network config file for inter-group connections
inter-group-connections="/home/mmubarak/codes-online/codes/src/network-workloads/conf/dragonfly-custom/dfp_8k_inter"; inter-group-connections="/home/mubarak/codes-online/codes/src/network-workloads/conf/dragonfly-custom/dfp_8k_inter";
# routing protocol to be used # routing protocol to be used
routing="prog-adaptive"; routing="prog-adaptive";
# route scoring protocol to be used - options are 'alpha' or 'beta' # route scoring protocol to be used - options are 'alpha' or 'beta'
route_scoring_metric="alpha"; route_scoring_metric="delta";
Markdown is supported
0% or .
Please register or to comment
