Commit f5d74ad8 authored by Shane Snyder's avatar Shane Snyder
Browse files
Modify delay calculation in darshan
Delay calculation now estimates duration of barriers (collective
communication).
parent 458a3637
...@@ -15,7 +15,7 @@ ...@@ -15,7 +15,7 @@
#define DEF_INTER_IO_DELAY_PCT 0.4 #define DEF_INTER_IO_DELAY_PCT 0.4
#define DEF_INTER_CYC_DELAY_PCT 0.2 #define DEF_INTER_CYC_DELAY_PCT 0.2
#define DARSHAN_NEGLIGIBLE_DELAY 0.001 #define DARSHAN_NEGLIGIBLE_DELAY 0.00001
#define RANK_HASH_TABLE_SIZE 397 #define RANK_HASH_TABLE_SIZE 397
...@@ -78,7 +78,8 @@ static double generate_psx_ind_io_events(struct darshan_file *file, int64_t io_o ...@@ -78,7 +78,8 @@ static double generate_psx_ind_io_events(struct darshan_file *file, int64_t io_o
static double generate_psx_coll_io_events(struct darshan_file *file, int64_t ind_io_ops_this_cycle, static double generate_psx_coll_io_events(struct darshan_file *file, int64_t ind_io_ops_this_cycle,
int64_t coll_io_ops_this_cycle, int64_t nprocs, int64_t coll_io_ops_this_cycle, int64_t nprocs,
int64_t aggregator_cnt, double inter_io_delay, int64_t aggregator_cnt, double inter_io_delay,
double cur_time, struct rank_io_context *io_context); double meta_op_time, double cur_time,
static void determine_io_params(struct darshan_file *file, int write_flag, int64_t io_this_op, static void determine_io_params(struct darshan_file *file, int write_flag, int64_t io_this_op,
int64_t proc_count, size_t *io_sz, off_t *io_off); int64_t proc_count, size_t *io_sz, off_t *io_off);
static void determine_coll_io_params(struct darshan_file *file, int write_flag, int64_t coll_op_cnt, static void determine_coll_io_params(struct darshan_file *file, int write_flag, int64_t coll_op_cnt,
...@@ -112,7 +113,6 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -112,7 +113,6 @@ static int darshan_io_workload_load(const char *params, int rank)
struct darshan_job job; struct darshan_job job;
struct darshan_file next_file; struct darshan_file next_file;
struct rank_io_context *my_ctx; struct rank_io_context *my_ctx;
struct darshan_io_op end_op;
int ret; int ret;
if (!d_params) if (!d_params)
...@@ -184,12 +184,6 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -184,12 +184,6 @@ static int darshan_io_workload_load(const char *params, int rank)
darshan_log_close(logfile_fd); darshan_log_close(logfile_fd);
/* tack a workload end file on the end of the events list */
/* NOTE: this helps us generate a delay from the last close to program termination */
end_op.codes_op.op_type = CODES_WK_END;
end_op.start_time = end_op.end_time = job.end_time - job.start_time + 1;
darshan_insert_next_io_op(my_ctx->io_op_dat, &end_op);
/* finalize the rank's i/o context so i/o ops may be retrieved later (in order) */ /* finalize the rank's i/o context so i/o ops may be retrieved later (in order) */
darshan_finalize_io_op_dat(my_ctx->io_op_dat); darshan_finalize_io_op_dat(my_ctx->io_op_dat);
...@@ -548,8 +542,20 @@ void generate_psx_coll_file_events( ...@@ -548,8 +542,20 @@ void generate_psx_coll_file_events(
assert(file->counters[CP_POSIX_OPENS] >= nprocs); assert(file->counters[CP_POSIX_OPENS] >= nprocs);
total_delay = file->fcounters[CP_F_CLOSE_TIMESTAMP] -
file->fcounters[CP_F_OPEN_TIMESTAMP] -
file->fcounters[CP_F_SLOWEST_RANK_TIME];
if (file->counters[CP_COLL_OPENS] || file->counters[CP_INDEP_OPENS]) if (file->counters[CP_COLL_OPENS] || file->counters[CP_INDEP_OPENS])
/* Subtract a portion of MPI r/w overhead from the total delay.
* This accounts for time spent synchronizing, since we generate barrier events.
* Note: 60% of mpi read/write time seems to be an appropriate approx of sync duration.
total_delay -= ((((file->fcounters[CP_F_MPI_READ_TIME] +
file->fcounters[CP_F_MPI_WRITE_TIME]) / nprocs) -
file->fcounters[CP_F_SLOWEST_RANK_TIME]) * .6);
extra_opens = file->counters[CP_POSIX_OPENS] - file->counters[CP_COLL_OPENS] - extra_opens = file->counters[CP_POSIX_OPENS] - file->counters[CP_COLL_OPENS] -
file->counters[CP_INDEP_OPENS]; file->counters[CP_INDEP_OPENS];
...@@ -561,12 +567,6 @@ void generate_psx_coll_file_events( ...@@ -561,12 +567,6 @@ void generate_psx_coll_file_events(
if (file->counters[CP_COLL_OPENS]) if (file->counters[CP_COLL_OPENS])
total_delay = (file->fcounters[CP_F_CLOSE_TIMESTAMP] -
(file->fcounters[CP_F_POSIX_READ_TIME] / in_agg_cnt) -
(file->fcounters[CP_F_POSIX_WRITE_TIME] / in_agg_cnt) -
(file->fcounters[CP_F_POSIX_META_TIME] / in_agg_cnt));
open_cycles = total_coll_opens / nprocs; open_cycles = total_coll_opens / nprocs;
calc_io_delays(file, ceil(((double)(total_coll_opens + total_ind_opens)) / nprocs), calc_io_delays(file, ceil(((double)(total_coll_opens + total_ind_opens)) / nprocs),
total_coll_io_ops + ceil((double)total_ind_io_ops / nprocs), total_delay, total_coll_io_ops + ceil((double)total_ind_io_ops / nprocs), total_delay,
...@@ -574,12 +574,6 @@ void generate_psx_coll_file_events( ...@@ -574,12 +574,6 @@ void generate_psx_coll_file_events(
else else
(file->fcounters[CP_F_POSIX_READ_TIME] / nprocs) -
(file->fcounters[CP_F_POSIX_WRITE_TIME] / nprocs) -
(file->fcounters[CP_F_POSIX_META_TIME] / nprocs));
open_cycles = ceil((double)total_ind_opens / nprocs); open_cycles = ceil((double)total_ind_opens / nprocs);
calc_io_delays(file, open_cycles, ceil((double)total_ind_io_ops / nprocs), total_delay, calc_io_delays(file, open_cycles, ceil((double)total_ind_io_ops / nprocs), total_delay,
&first_io_delay, &close_delay, &inter_cycle_delay, &inter_io_delay); &first_io_delay, &close_delay, &inter_cycle_delay, &inter_io_delay);
...@@ -608,12 +602,6 @@ void generate_psx_coll_file_events( ...@@ -608,12 +602,6 @@ void generate_psx_coll_file_events(
total_ind_io_ops = total_io_ops - extra_io_ops; total_ind_io_ops = total_io_ops - extra_io_ops;
total_coll_io_ops = 0; total_coll_io_ops = 0;
...@@ -621,7 +609,8 @@ void generate_psx_coll_file_events( ...@@ -621,7 +609,8 @@ void generate_psx_coll_file_events(
assert(extra_opens <= open_cycles); assert(extra_opens <= open_cycles);
/* calculate average meta op time (for i/o and opens/closes) */ /* calculate average meta op time (for i/o and opens/closes) */
meta_op_time = file->fcounters[CP_F_POSIX_META_TIME] / (2 * file->counters[CP_POSIX_OPENS]); meta_op_time = file->fcounters[CP_F_POSIX_META_TIME] / ((2 * file->counters[CP_POSIX_OPENS]) +
file->counters[CP_POSIX_READS] + file->counters[CP_POSIX_WRITES]);
/* it is rare to overwrite existing files, so set the create flag */ /* it is rare to overwrite existing files, so set the create flag */
if (file->counters[CP_BYTES_WRITTEN]) if (file->counters[CP_BYTES_WRITTEN])
...@@ -648,7 +637,7 @@ void generate_psx_coll_file_events( ...@@ -648,7 +637,7 @@ void generate_psx_coll_file_events(
/* TODO: we probably want to use ind_io here */ /* TODO: we probably want to use ind_io here */
cur_time = generate_psx_coll_io_events(file, 1, 0, nprocs, nprocs, 0.0, cur_time = generate_psx_coll_io_events(file, 1, 0, nprocs, nprocs, 0.0,
cur_time, io_context); meta_op_time, cur_time, io_context);
extra_io_ops--; extra_io_ops--;
...@@ -673,7 +662,8 @@ void generate_psx_coll_file_events( ...@@ -673,7 +662,8 @@ void generate_psx_coll_file_events(
ind_io_ops_this_cycle = ceil(((double)total_ind_io_ops / total_ind_opens) * rank_cnt); ind_io_ops_this_cycle = ceil(((double)total_ind_io_ops / total_ind_opens) * rank_cnt);
cur_time = generate_psx_coll_io_events(file, ind_io_ops_this_cycle, 0, nprocs, cur_time = generate_psx_coll_io_events(file, ind_io_ops_this_cycle, 0, nprocs,
nprocs, inter_io_delay, cur_time, io_context); nprocs, inter_io_delay, meta_op_time,
total_ind_io_ops -= ind_io_ops_this_cycle; total_ind_io_ops -= ind_io_ops_this_cycle;
cur_time += close_delay; cur_time += close_delay;
...@@ -710,7 +700,8 @@ void generate_psx_coll_file_events( ...@@ -710,7 +700,8 @@ void generate_psx_coll_file_events(
(file->counters[CP_COLL_OPENS] / nprocs)); (file->counters[CP_COLL_OPENS] / nprocs));
cur_time = generate_psx_coll_io_events(file, ind_io_ops_this_cycle, cur_time = generate_psx_coll_io_events(file, ind_io_ops_this_cycle,
coll_io_ops_this_cycle, nprocs, in_agg_cnt, coll_io_ops_this_cycle, nprocs, in_agg_cnt,
inter_io_delay, cur_time, io_context); inter_io_delay, meta_op_time, cur_time,
io_context);
total_coll_io_ops -= coll_io_ops_this_cycle; total_coll_io_ops -= coll_io_ops_this_cycle;
...@@ -933,8 +924,8 @@ static double generate_psx_ind_io_events( ...@@ -933,8 +924,8 @@ static double generate_psx_ind_io_events(
static double generate_psx_coll_io_events( static double generate_psx_coll_io_events(
struct darshan_file *file, int64_t ind_io_ops_this_cycle, int64_t coll_io_ops_this_cycle, struct darshan_file *file, int64_t ind_io_ops_this_cycle, int64_t coll_io_ops_this_cycle,
int64_t nprocs, int64_t aggregator_cnt, double inter_io_delay, double cur_time, int64_t nprocs, int64_t aggregator_cnt, double inter_io_delay, double meta_op_time,
struct rank_io_context *io_context) double cur_time, struct rank_io_context *io_context)
static int rw = -1; /* rw = 1 for write, 0 for read, -1 for uninitialized */ static int rw = -1; /* rw = 1 for write, 0 for read, -1 for uninitialized */
static int64_t io_ops_this_rw; static int64_t io_ops_this_rw;
...@@ -1070,7 +1061,7 @@ static double generate_psx_coll_io_events( ...@@ -1070,7 +1061,7 @@ static double generate_psx_coll_io_events(
else else
io_op_time = (io_sz / rd_bw); io_op_time = (io_sz / rd_bw);
next_io_op.end_time = cur_time + io_op_time; next_io_op.end_time = cur_time + io_op_time + meta_op_time;
file->counters[CP_POSIX_READS] -= tmp_coll_cnt; file->counters[CP_POSIX_READS] -= tmp_coll_cnt;
else else
...@@ -1088,7 +1079,7 @@ static double generate_psx_coll_io_events( ...@@ -1088,7 +1079,7 @@ static double generate_psx_coll_io_events(
else else
io_op_time = (io_sz / wr_bw); io_op_time = (io_sz / wr_bw);
file->counters[CP_POSIX_WRITES] -= tmp_coll_cnt; file->counters[CP_POSIX_WRITES] -= tmp_coll_cnt;
...@@ -1813,9 +1804,10 @@ static void file_sanity_check( ...@@ -1813,9 +1804,10 @@ static void file_sanity_check(
file->counters[CP_POSIX_SEEKS] += file->counters[CP_POSIX_FSEEKS]; file->counters[CP_POSIX_SEEKS] += file->counters[CP_POSIX_FSEEKS];
/* reduce total meta time by percentage of ops not currently implemented */ /* reduce total meta time by percentage of ops not currently implemented */
ops_not_implemented = file->counters[CP_POSIX_SEEKS] + file->counters[CP_POSIX_STATS] + /* NOTE: we lump fseeks and r/w operations together when setting op durations ... */
file->counters[CP_POSIX_FSYNCS]; ops_not_implemented = file->counters[CP_POSIX_STATS] + file->counters[CP_POSIX_FSYNCS];
ops_total = ops_not_implemented + (2 * file->counters[CP_POSIX_OPENS]); ops_total = ops_not_implemented + (2 * file->counters[CP_POSIX_OPENS]) +
file->counters[CP_POSIX_SEEKS];
file->fcounters[CP_F_POSIX_META_TIME] *= (1 - ((double)ops_not_implemented / ops_total)); file->fcounters[CP_F_POSIX_META_TIME] *= (1 - ((double)ops_not_implemented / ops_total));
return; return;
Markdown is supported
0% or .
Please register or to comment
