Commit f2d4cad6 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Fixing ordering issue with waits (should resolve the unmatched sends/receives...
Fixing ordering issue with waits (should resolve the unmatched sends/receives error with traces like minife)
parent 83bc8e21
...@@ -156,7 +156,7 @@ struct codes_workload_op ...@@ -156,7 +156,7 @@ struct codes_workload_op
/* what type of operation this is */ /* what type of operation this is */
enum codes_workload_op_type op_type; int op_type;
/* currently only used by network workloads */ /* currently only used by network workloads */
double start_time; double start_time;
double end_time; double end_time;
...@@ -198,7 +198,7 @@ struct codes_workload_op ...@@ -198,7 +198,7 @@ struct codes_workload_op
int16_t data_type; /* MPI data type to be matched with the recv */ int16_t data_type; /* MPI data type to be matched with the recv */
int count; /* number of elements to be received */ int count; /* number of elements to be received */
int tag; /* tag of the message */ int tag; /* tag of the message */
int32_t req_id; int req_id;
} send; } send;
struct { struct {
/* TODO: not sure why source rank is here */ /* TODO: not sure why source rank is here */
...@@ -208,7 +208,7 @@ struct codes_workload_op ...@@ -208,7 +208,7 @@ struct codes_workload_op
int16_t data_type; /* MPI data type to be matched with the send */ int16_t data_type; /* MPI data type to be matched with the send */
int count; /* number of elements to be sent */ int count; /* number of elements to be sent */
} recv; } recv;
/* TODO: non-stub for other collectives */ /* TODO: non-stub for other collectives */
struct { struct {
...@@ -216,14 +216,14 @@ struct codes_workload_op ...@@ -216,14 +216,14 @@ struct codes_workload_op
} collective; } collective;
struct { struct {
int count; int count;
int32_t* req_ids; int* req_ids;
} waits; } waits;
struct { struct {
} wait; } wait;
struct struct
free; free;
}u; }u;
...@@ -15,6 +15,7 @@ ...@@ -15,6 +15,7 @@
#include "codes/codes-workload.h" #include "codes/codes-workload.h"
#include "codes/quickhash.h" #include "codes/quickhash.h"
#include "codes/codes-jobmap.h" #include "codes/codes-jobmap.h"
#include "codes/jenkins-hash.h"
#include "codes/model-net.h" #include "codes/model-net.h"
#if ENABLE_CORTEX #if ENABLE_CORTEX
...@@ -108,6 +109,12 @@ static inline double time_to_us_lf(dumpi_clock t){ ...@@ -108,6 +109,12 @@ static inline double time_to_us_lf(dumpi_clock t){
static inline double time_to_ns_lf(dumpi_clock t){ static inline double time_to_ns_lf(dumpi_clock t){
return (double) t.sec * 1e9 + (double) t.nsec; return (double) t.sec * 1e9 + (double) t.nsec;
static int32_t get_unique_req_id(int32_t request_id)
uint32_t pc = 0, pb = 0;
bj_hashlittle2(&request_id, sizeof(int32_t), &pc, &pb);
return pc;
/*static inline double time_to_s_lf(dumpi_clock t){ /*static inline double time_to_s_lf(dumpi_clock t){
return (double) t.sec + (double) t.nsec / 1e9; return (double) t.sec + (double) t.nsec / 1e9;
...@@ -340,10 +347,10 @@ int handleDUMPIWaitsome(const dumpi_waitsome *prm, uint16_t thread, ...@@ -340,10 +347,10 @@ int handleDUMPIWaitsome(const dumpi_waitsome *prm, uint16_t thread,
wrkld_per_rank.op_type = CODES_WK_WAITSOME; wrkld_per_rank.op_type = CODES_WK_WAITSOME;
wrkld_per_rank.u.waits.count = prm->count; wrkld_per_rank.u.waits.count = prm->count;
wrkld_per_rank.u.waits.req_ids = (int32_t*)malloc(prm->count * sizeof(int32_t)); wrkld_per_rank.u.waits.req_ids = (int*)malloc(prm->count * sizeof(int));
for( i = 0; i < prm->count; i++ ) for( i = 0; i < prm->count; i++ )
wrkld_per_rank.u.waits.req_ids[i] = (int32_t)prm->requests[i]; wrkld_per_rank.u.waits.req_ids[i] = prm->requests[i];
update_times_and_insert(&wrkld_per_rank, wall, myctx); update_times_and_insert(&wrkld_per_rank, wall, myctx);
return 0; return 0;
...@@ -365,10 +372,10 @@ int handleDUMPIWaitany(const dumpi_waitany *prm, uint16_t thread, ...@@ -365,10 +372,10 @@ int handleDUMPIWaitany(const dumpi_waitany *prm, uint16_t thread,
wrkld_per_rank.op_type = CODES_WK_WAITANY; wrkld_per_rank.op_type = CODES_WK_WAITANY;
return 0; return 0;
...@@ -391,7 +398,7 @@ int handleDUMPIWaitall(const dumpi_waitall *prm, uint16_t thread, ...@@ -391,7 +398,7 @@ int handleDUMPIWaitall(const dumpi_waitall *prm, uint16_t thread,
wrkld_per_rank.op_type = CODES_WK_WAITALL; wrkld_per_rank.op_type = CODES_WK_WAITALL;
wrkld_per_rank.u.waits.req_ids[i] = prm->requests[i]; wrkld_per_rank.u.waits.req_ids[i] = prm->requests[i];
Markdown is supported
0% or .
Please register or to comment
