GitLab maintenance scheduled form Friday, 2021-06-18 5:00pm to Satursday, 2021-06-19 10:00pm CT - Services will be unavailable during this time.
Commit eebf1ab3 authored by Noah Wolfe's avatar Noah Wolfe Committed by Nikhil
Updated fattree_packet_event()
parent 2caf6c9c
...@@ -766,11 +766,32 @@ void switch_init(switch_state * r, tw_lp * lp) ...@@ -766,11 +766,32 @@ void switch_init(switch_state * r, tw_lp * lp)
static void fattree_report_stats() { } static void fattree_report_stats() { }
/* fattree packet event */ /* fattree packet event */
static tw_stime fattree_packet_event(model_net_request* req, char* category, static tw_stime fattree_packet_event(
tw_lpid final_dest_lp, uint64_t packet_size, int is_pull, model_net_request const * req,
uint64_t pull_size, tw_stime offset, const mn_sched_params *sched_params, uint64_t message_offset,
int remote_event_size, const void* remote_event, int self_event_size, uint64_t packet_size,
const void* self_event, tw_lpid src_lp, tw_lp *sender, int is_last_pckt) { tw_stime offset,
mn_sched_params const * sched_params,
void const * remote_event,
void const * self_event,
tw_lp *sender,
int is_last_pckt)
/* model_net_request* req,
char* category,
int is_pull,
uint64_t pull_size,
tw_stime offset,
tw_lpid src_lp,
tw_lp *sender,
int is_last_pckt)
tw_event * e_new; tw_event * e_new;
tw_stime xfer_to_nic_time; tw_stime xfer_to_nic_time;
...@@ -780,16 +801,22 @@ static tw_stime fattree_packet_event(model_net_request* req, char* category, ...@@ -780,16 +801,22 @@ static tw_stime fattree_packet_event(model_net_request* req, char* category,
xfer_to_nic_time = codes_local_latency(sender); xfer_to_nic_time = codes_local_latency(sender);
e_new = model_net_method_event_new(sender->gid, xfer_to_nic_time + offset, e_new = model_net_method_event_new(sender->gid, xfer_to_nic_time + offset,
sender, FATTREE, (void**)&msg, (void**)&tmp_ptr); sender, FATTREE, (void**)&msg, (void**)&tmp_ptr);
strcpy(msg->category, category); strcpy(msg->category, req->category);
msg->final_dest_gid = final_dest_lp; msg->final_dest_gid = req->final_dest_lp;
msg->sender_lp = src_lp; msg->total_size = req->msg_size;
msg->sender_lp = req->src_lp;
msg->sender_mn_lp = sender->gid;
msg->packet_size = packet_size; msg->packet_size = packet_size;
msg->msg_size = req->msg_size; msg->travel_start_time = tw_now(sender);
msg->src_nic = req->src_nic;
msg->uniq_id = req->uniq_id;
msg->remote_event_size_bytes = 0; msg->remote_event_size_bytes = 0;
msg->local_event_size_bytes = 0; msg->local_event_size_bytes = 0;
msg->type = T_GENERATE; msg->type = T_GENERATE;
msg->dest_terminal_id = req->dest_mn_lp;
msg->message_id = req->msg_id;
msg->is_pull = req->is_pull;
msg->pull_size = req->pull_size;
msg->magic = terminal_magic_num;
msg->msg_start_time = req->msg_start_time;
/* Its the last packet so pass in remote and local event information*/ /* Its the last packet so pass in remote and local event information*/
if(is_last_pckt) if(is_last_pckt)
Markdown is supported
0%
or
Please register or to comment
