Commit ee56819b authored by Misbah Mubarak's avatar Misbah Mubarak
Adding the torus network plugin with modelnet API, see...
Adding the torus network plugin with modelnet API, see model-net/README_MN_TEST.txt for instructions to run the test
parent b13d30f4
#include "codes/torus.h" #include "codes/torus.h"
/* setup the torus model */ /* setup the torus model, initialize global parameters */
static void torus_setup(const void* net_params) static void torus_setup(const void* net_params)
int i; int i;
...@@ -25,7 +25,7 @@ static void torus_packet_event_rc(tw_lp *sender) ...@@ -25,7 +25,7 @@ static void torus_packet_event_rc(tw_lp *sender)
return; return;
/* torus mode packet event */ /* torus packet event , generates a torus packet on the compute node */
static void torus_packet_event(char* category, tw_lpid final_dest_lp, int packet_size, int remote_event_size, const void* remote_event, int self_event_size, const void* self_event, tw_lp *sender, int is_last_pckt) static void torus_packet_event(char* category, tw_lpid final_dest_lp, int packet_size, int remote_event_size, const void* remote_event, int self_event_size, const void* self_event, tw_lp *sender, int is_last_pckt)
tw_event * e_new; tw_event * e_new;
...@@ -170,6 +170,7 @@ static void torus_init( nodes_state * s, ...@@ -170,6 +170,7 @@ static void torus_init( nodes_state * s,
s->packet_counter = 0; s->packet_counter = 0;
/* returns the torus message size */
static int torus_get_msg_sz(void) static int torus_get_msg_sz(void)
return sizeof(nodes_message); return sizeof(nodes_message);
...@@ -229,8 +230,12 @@ static void dimension_order_routing( nodes_state * s, ...@@ -229,8 +230,12 @@ static void dimension_order_routing( nodes_state * s,
codes_mapping_get_lp_id("MODELNET_GRP", "modelnet_torus", dest_id, 0, dst_lp); codes_mapping_get_lp_id("MODELNET_GRP", "modelnet_torus", dest_id, 0, dst_lp);
/*Generates a packet. If there are two buffer slots available, then the packet is
injected in the network. Else, the packet is placed in the injection queue */ /*Generates a packet. If there is a buffer slot available, then the packet is
injected in the network. Else, a buffer overflow exception is thrown.
TODO: We might want to modify this so that if the buffer is full, the packet
injection is delayed in turn slowing down the injection rate. The average achieved
injection rate can be reported at the end of the simulation. */
static void packet_generate( nodes_state * s, static void packet_generate( nodes_state * s,
tw_bf * bf, tw_bf * bf,
nodes_message * msg, nodes_message * msg,
...@@ -287,6 +292,8 @@ static void packet_generate( nodes_state * s, ...@@ -287,6 +292,8 @@ static void packet_generate( nodes_state * s,
else else
printf("\n %d Packet queued in line increase buffer space, dir %d dim %d buffer space %d dest LP %d ", (int)lp->gid, tmp_dir, tmp_dim, s->buffer[ tmp_dir + ( tmp_dim * 2 ) ][ 0 ], (int)msg->dest_lp); printf("\n %d Packet queued in line increase buffer space, dir %d dim %d buffer space %d dest LP %d ", (int)lp->gid, tmp_dir, tmp_dim, s->buffer[ tmp_dir + ( tmp_dim * 2 ) ][ 0 ], (int)msg->dest_lp);
MPI_Finalize();
exit(-1);
...@@ -387,10 +394,16 @@ static void packet_send( nodes_state * s, ...@@ -387,10 +394,16 @@ static void packet_send( nodes_state * s,
} // end if } // end if
else else
printf("\n buffer overflown "); printf("\n buffer overflown ");
MPI_Finalize();
exit(-1);
/*Processes the packet after it arrives from the neighboring torus node */ /*Processes the packet after it arrives from the neighboring torus node
* routes it to the next compute node if this is not the destination
* OR if this is the destination then a remote event at the server is issued. */
static void packet_arrive( nodes_state * s, static void packet_arrive( nodes_state * s,
...@@ -456,10 +469,13 @@ final( nodes_state * s, tw_lp * lp ) ...@@ -456,10 +469,13 @@ final( nodes_state * s, tw_lp * lp )
free(s->buffer); free(s->buffer);
/* increments the buffer count after a credit arrives from the remote compute node */
static void packet_buffer_process( nodes_state * s, tw_bf * bf, nodes_message * msg, tw_lp * lp ) static void packet_buffer_process( nodes_state * s, tw_bf * bf, nodes_message * msg, tw_lp * lp )
s->buffer[ msg->source_direction + ( msg->source_dim * 2 ) ][ 0 ]--; s->buffer[ msg->source_direction + ( msg->source_dim * 2 ) ][ 0 ]--;
/* reverse handler */
static void node_rc_handler(nodes_state * s, tw_bf * bf, nodes_message * msg, tw_lp * lp) static void node_rc_handler(nodes_state * s, tw_bf * bf, nodes_message * msg, tw_lp * lp)
switch(msg->type) switch(msg->type)
...@@ -516,6 +532,7 @@ static void node_rc_handler(nodes_state * s, tw_bf * bf, nodes_message * msg, tw ...@@ -516,6 +532,7 @@ static void node_rc_handler(nodes_state * s, tw_bf * bf, nodes_message * msg, tw
/* forward event handler */
static void event_handler(nodes_state * s, tw_bf * bf, nodes_message * msg, tw_lp * lp) static void event_handler(nodes_state * s, tw_bf * bf, nodes_message * msg, tw_lp * lp)
*(int *) bf = (int) 0; *(int *) bf = (int) 0;
...@@ -549,6 +566,7 @@ tw_lptype torus_lp = ...@@ -549,6 +566,7 @@ tw_lptype torus_lp =
sizeof(nodes_state), sizeof(nodes_state),
/* returns the torus lp type for lp registration */
static const tw_lptype* torus_get_lp_type(void) static const tw_lptype* torus_get_lp_type(void)
return(&torus_lp); return(&torus_lp);
Markdown is supported
0%
or
Please register or to comment
